It is currently Sat Sep 21, 2024 11:37 pm
 Post subject: a little interpreter
PostPosted: Tue Jan 20, 2015 11:24 am
hi guys
i have coded a little-interpreter, which i wanted to call "L"
"L" stands for "Little", it is a very small interpreter similar to pascal, it can be useful for scripting in robotic, embedded and non-embedded applications.
It is written in C++, a port in C is available (i have to upload new sources), and it has been tested on x86-32, x86-64, powerpc, arm, ultrasparc, HP-PA and blackfin processors and is easy to port to new targets.
Very alpha stage, but ... it will be improved. It may be useful to learn something about "interpreter".
enjoy!
 Post subject: Re: a little interpreter
PostPosted: Mon Feb 09, 2015 4:30 pm
i added few examples
Program factorial
Begin
    Input n
    factorial = 1
    While n > 1
    Begin
        factorial = factorial * n
        n = n - 1
    End
    Output factorial
End
Program test_prime
Begin
   Input n
   c = 2
   is_prime = 1
   While (c < n / 2) & is_prime
   Begin
      If n % c == 0
      Begin
         is_prime = 0
      End
      c = c + 1
   End
   Output is_prime
End
PostPosted: Tue Apr 14, 2015 11:09 am
i added a sub-repo with a standalone project about a mini calculator
PostPosted: Tue Jul 28, 2015 12:45 pm
any comment ?
PostPosted: Tue Jul 28, 2015 1:21 pm
Isn't code.google.com going away? You might need to find a new repository.
See http://google-opensource.blogspot.com/2015/03/farewell-to-google-code.html
I'll take a look at your code to see if I can learn anything new about interpreter design. But personally I think I'd prefer something like Forth for robotics on a 6502 due to system constraints.
Update: After a quick look you would need a way to address raw memory for it to be useful on something like a 6502 or microcontroller. The reason is that most I/O peripherals are memory mapped and in BASIC you use PEEK and POKE to manipulate them. So to achieve similar utility you'll need those keywords.
PostPosted: Wed Jul 29, 2015 12:29 pm
I might implement these features :D
actually I am working on advanced lexer, planning to support an advanced interpreter (with functions, type checking, etc)
# eval 1+(2.2*3.0E9+ ( 0xdeadbeaf logicalAnd 0xffffffff ) )
yards analysis: PASSED
stack analysis: PASSED
rpn_v[]={ 0 3 5 4 8 10 9 6 1 }
[1] 1 token_DecValue, type12
[2.2] 1 token_FloatinPointENGValue, type15
[3.0E9] 1 token_FloatinPointSCIValue, type16
[*] -1 token_Asterisk, type55
[0xdeadbeaf] 1 token_HexValue, type13
[0xffffffff] 1 token_HexValue, type13
[logicalAnd] -1 token_LogicalAnd, type41
[+] -1 token_Plus, type53
#    good expression    #
# eval 1.1 + 2.2 * 3.0E9
rpn_v[]={ 0 2 4 3 1 }
[1.1] 1 token_FloatinPointENGValue, type15
#    good expression    #
# eval 1+2+
stack analysis: FAILED
#    bad  expression    #
# eval 1+2+(2+3
Error: parentheses mismatched/case1
yards analysis: FAILED
#    bad  expression    #
# eval Fa(Fb(1,2,3,4,5),Fc(6,7,8,9),0)
function_pool has 3 functions
 + function1 [Fa] { typeRet typeRet type12 } 3 args
 + function2 [Fb] { type12 type12 type12 type12 type12 } 5 args
 + function3 [Fc] { type12 type12 type12 type12 } 4 args
rpn_v[]={ 4 6 8 10 12 2 17 19 21 23 15 26 0 }
[2] 1 token_DecValue, type12
[3] 1 token_DecValue, type12
[4] 1 token_DecValue, type12
[5] 1 token_DecValue, type12
[Fb] -4 token_StrictAlphaNum, type19
[6] 1 token_DecValue, type12
[7] 1 token_DecValue, type12
[8] 1 token_DecValue, type12
[9] 1 token_DecValue, type12
[Fc] -3 token_StrictAlphaNum, type19
[0] 1 token_DecValue, type12
[Fa] -2 token_StrictAlphaNum, type19
#    good expression    #
I am considering the RPN method as the hypothetical way to transform a math expression into machine opcodes, crazy idea for AS. I do not like methods like Recursive Descent.
