It is currently Sat Sep 21, 2024 8:40 am
PostPosted: Sun Jun 08, 2014 7:22 pm
Before:
twoplus
2    clc
3    lda tos
2    adc #2
3    sta tos
3/2  bcc twoplus01
0/5  inc tos+1
twoplus01
3    jmp next ;[14 bytes/16 cycles]
twominus
2    sec
3    lda tos
2    sbc #2
3    sta tos
3/2  bcs twominus01
0/5  dec tos+1
twominus01
After:
twoplus
2    lda #2
twopm
3    ldy tos+1
2    clc
3    adc tos
3/2  bcc twoplus01
0/2  iny
twoplus01
3    jmp put   ;[13 bytes/25 cycles]         ; TOS = YA
twominus
5    dec tos+1
2    lda #$fe
3    bne twopm ;[6 bytes/29 cycles]         ; bra
put
3    sty tos+1
3    sta tos
3    jmp next
PostPosted: Sun Jun 08, 2014 9:10 pm
Does your new 'detached header' structure allow you to overlap words? If so, you may be able to take advantage of this in several primitives, right?
Another thing just occurred to me. You're carrying a modified SWEET16, so could you pull some tricks by putting TOS in R0?
twoplus:
        BRK  ; to SWEET16
        INR  0
        INR  0
        RTN
        JMP  next
Mike
PostPosted: Sun Jun 08, 2014 9:18 pm
Mike
With nothing but code in the dictionary, fallthrough works. Here's what I did with DROP 2DROP 3DROP 4DROP and poptwo pop put used by primitives. Mostly I'm focusing right now on getting FIND and the outer interpreter to work again, so I can change my cold banner message to something other than
.asc "VERSION PRE-ALPHA 2014-06-02",CR
.asc "455 SACK OF ROME: VANDALS ENTER ROME,",CR
.asc " AND PLUNDER THE CITY FOR TWO WEEKS",CR
;       2DROP
#ifdef HEADERS
twodroplfa
    .byt $de,$ad
    .byt (twodrop-*-1)|bit7
    .asc "2DRO","P"|bit7
#endif
twodrop
poptwo
    inx
;       DROP   ( n -- )
; * 83 nucleus
#ifdef HEADERS
droplfa
    .byt $de,$ad
    .byt (drop-*-1)|bit7
    .asc "DRO","P"|bit7
#endif
drop
pops
    ldy stackh,x
    lda stackl,x
    inx
put
    sty tos+1
    sta tos
    jmp next
;      4DROP   ( -- )
; description
#ifdef HEADERS
fourdroplfa
   .byt $de,$ad
   .byt (fourdrop-*-1)|bit7
   .asc "4DRO","P"|bit7
#endif
fourdrop
   inx
;       3DROP   ( a b c -- )
; * 83 nucleus
#ifdef HEADERS
threedroplfa
    .byt $de,$ad
    .byt (threedrop-*-1)|bit7
    .asc "3DRO","P"|bit7
#endif
threedrop
    inx
    bne poptwo
PostPosted: Sun Jun 08, 2014 9:23 pm
Regarding your original post, if small size rather than highest speed is your aim, how about this:
twominus:   ; 19 bytes
  dec tos+1
  lda #-2   ; aka #$FE, or any number of other ways to specify it
  .byte $CD ; 'cmp absolute', although 'bit absolute' is also popular
twoplus:    ; 14 bytes
  lda #2
  clc
  adc tos
  sta tos
  bcc :+
  inc tos+1
  jmp next
PostPosted: Sun Jun 08, 2014 9:38 pm
Well played, teamtempest! Winner!
;       3-
#ifdef HEADERS
threeminuslfa
    .byt $de,$ad
    .byt (threeminus-*-1)|bit7
    .asc "3","-"|bit7
#endif
threeminus
    lda #$fd
   .byt $2c ; BIT absolute instruction, fall through to twominus
;       2-
#ifdef HEADERS
twominuslfa
    .byt $de,$ad
    .byt (twominus-*-1)|bit7
    .asc "2","-"|bit7
#endif
twominus
    lda #$fe
    dec tos+1
    .byt $2c ; BIT absolute instruction, fall through to twoplus
;       2+
#ifdef HEADERS
twopluslfa
    .byt $de,$ad
    .byt (twoplus-*-1)|bit7
    .asc "2","+"|bit7
#endif
twoplus
    lda #2
nplus
    clc
    adc tos
    sta tos
    bcc twoplus01
    inc tos+1
twoplus01
    jmp next
;       3+
#ifdef HEADERS
threepluslfa
    .byt $de,$ad
    .byt (threeplus-*-1)|bit7
    .asc "3","+"|bit7
#endif
threeplus
    lda #3
   bne nplus               ; bra
PostPosted: Sun Jun 08, 2014 10:01 pm
twoplus:
        BRK  ; to SWEET16
        INR  0
        INR  0
        RTN
        JMP  next
Mike
JMP NEXT is a new Sweet16 opcode, and LDD/POPD have the side effect of double-incrementing or double-decrementing the pointer, so these would work. I'm not going to use them because 2+ 2- are invoked fairly often and the CPU overhead of doing this in Sweet16 would be hundreds of cycles, much higher than I'm willing to tolerate for saving a few bytes. It's okay for code that runs infrequently, some compiler code, or code that runs at human speed (editor functions) but I'm avoiding it in the parts that should run fast. It's a balancing act. Potential unwanted side effects could occur if TOS is pointing at an I/O chip like the 6522 VIA, where hitting it with a read does other things on the chip
twoplus
        brk ; Sweet16
        .byt ldd | TOS  ; TOS is in R4, I don't always want to modify TOS. R0 will be discarded.
        .byt nxt
twominus
        brk ; Sweet16
        .byt popd | TOS
        .byt nxt
threeminus
        brk ; Sweet16
        .byt popd | TOS
        .byt dcr | TOS
        .byt nxt
threeplus
        brk ; Sweet16
        .byt ldd | TOS
        .byt inr | TOS
        .byt nxt
PostPosted: Mon Jun 09, 2014 3:50 am
Those unwanted side effects can also result from the trick teamtempest used. I don't condemn the idea, but it's good to be aware of what'll happen.
twoplus:
  lda #2
is one byte shorter (and one cycle slower) than
  BRA $+2
twoplus:
  lda #2
but results in a spurious read. In this case the "address" that gets read is lda #2, or $02A9. If you edit the code then of course some other address could get hit. One way or the other it could really bite you if you're not careful!
PostPosted: Mon Jun 09, 2014 7:32 am
Would it be better to have machine code primitives for I/O access? I know the 6502 has memory-mapped I/O, but that doesn't mean it's wise to allow arbitrary access as if the I/O were memory.
PostPosted: Mon Jun 09, 2014 12:45 pm
In my situation, I'm letting the PET Kernel ROM do most of the heavy lifting. I'm reusing it's clock, tape, disk, screen and keyboard I/O ROM as much as possible.
As for the BIT branch trick, I've given it some thought and decided it's extremely unlikely, and not worth worrying about, that it will hit something bad and bite me in the butt. There are chips at $E810-E813 (PIA1), $E820-E823 (PIA2), $E840-E84F (VIA), and possibly a CRTC controller (which I do not have) starting at $E880. The addresses are incompletely decoded so lots of opcodes would work, either directly or at a 'mirror' address. The reason I don't worry at all is that the second byte immediately following would have to be $E8-EF to hit the I/O page, which is in the middle of the zero page screen linewrap table stored from $E0-$F8. Forth doesn't (and shouldn't) do a lot of error checking, instead it takes more of a go-fast no-bozos approach. If it fails, I get to figure out why and fix it.
