It is currently Tue May 14, 2024 7:42 am
 Post subject: xa65 update
PostPosted: Wed Dec 28, 2011 8:12 pm
Hi there,
the maintainer of xa65 still is Cameron Kaiser, but we discussed to put up the xa65 cross assembler to github, as I had some updates and Cameron is currently busy with other tasks.
You can find it on
https://github.com/fachat/xa65
The "master" is the stable branch. The "listing" branch adds some ca65 compatibility options, and also a long-awaited feature: assembler listings.
The "listing" needs more testing though, esp. with the 65816 code (I had to change something in the 65816 part that I did not really understand), I only tested the 6502 code so far.
André
 Post subject: Re: xa65 update
PostPosted: Fri Jun 08, 2012 4:17 am
André
I ran across this post while looking for something else and am curious if I can help in resolving whatever it is with the 65C816 part. Pleas advise.
PostPosted: Fri Jun 08, 2012 4:24 pm
I ran across this post while looking for something else and am curious if I can help in resolving whatever it is with the 65C816 part. Pleas advise.[/size]
Well, that would be great! I have modified the current xa65 version to include some improvements, mostly the listing feature - but in this process I found that the 65816 extension to the original assembler was not made to the original structure (IIRC it did some out-of-band communication between components), which I fixed (had to to implement the listing).
However, as I don't do 65816 at the moment - actually never done extensively - I can't say if I really broke it. I wrote a small test program, but that is not a replacement for a full-featured test.
So it would be great if you (or others) could test the 65816 side of that extension!
André
PostPosted: Fri Jun 08, 2012 4:42 pm
Looking at the code again, if I see that correctly now, the critical part is the one where values are cast to a specific length, esp. the "@"
PostPosted: Tue Dec 30, 2014 4:20 am
Gravedigging: I finished the 2.3.7 update with some bug fixes and an expanded test case. I'm trying to work on the '816 side and there are some test vectors now.
http://www.floodgap.com/retrotech/xa/
Machine room: http://www.floodgap.com/etc/machines.html
PostPosted: Sun Apr 12, 2015 3:46 pm
FYI I have updated my copy to work with Visual Studio 2012 instead of 2005
PostPosted: Sun Apr 12, 2015 3:52 pm
I also got rid of the 2 compiler warnings
