It is currently Sun Apr 28, 2024 10:40 pm
PostPosted: Sun Jan 29, 2012 8:48 pm
EDIT: sorry, i meant to post this in the emulation section not programming!
i originally wrote this for my NES emulator, but i've also used it in a few other things. it works very well, so i figured i might as well post it, in case anybody else wants to make use of it.
questions, comments, or find a bug.. let me know please! :)
/* Fake6502 CPU emulator core v1.1 *******************
 * (c)2011 Mike Chambers (miker00lz@gmail.com)       *
 * v1.1 - Small bugfix in BIT opcode, but it was the *
 *        difference between a few games in my NES   *
 *        emulator working and being broken!         *
 *        I went through the rest carefully again    *
 *        after fixing it just to make sure I didn't *
 *        have any other typos! (Dec. 17, 2011)      *
 * v1.0 - First release (Nov. 24, 2011)              *
 * LICENSE: This source code is released into the    *
 * public domain, but if you use it please do give   *
 * credit. I put a lot of effort into writing this!  *
 * Fake6502 is a MOS Technology 6502 CPU emulation   *
 * engine in C. It was written as part of a Nintendo *
 * Entertainment System emulator I've been writing.  *
 * It has been pretty well-tested in the NES emu,    *
 * and the clock-cycle timing in particular has been *
 * VERY thoroughly checked out. It matches with the  *
 * real 6502 processor 100%.                         *
 * A couple important things to know about are two   *
 * defines in the code. One is "UNDOCUMENTED" which, *
 * when defined, allows Fake6502 to compile with     *
 * full support for the more predictable             *
 * undocumented instructions of the 6502. If it is   *
 * undefined, undocumented opcodes just act as NOPs. *
 * The other define is "NES_CPU", which causes the   *
 * code to compile without support for binary-coded  *
 * decimal (BCD) support for the ADC and SBC         *
 * opcodes. The Ricoh 2A03 CPU in the NES does not   *
 * support BCD, but is otherwise identical to the    *
 * standard MOS 6502. (Note that this define is      *
 * disabled in this file if you haven't changed it   *
 * yourself. If you're emulating a NES, you          *
 * should uncomment it.)                             *
 * If you do discover an error in timing accuracy,   *
 * or operation in general please e-mail me at the   *
 * address above so that I can fix it. Thank you!    *
 * Usage:                                            *
 * Fake6502 requires you to provide two external     *
 * functions:                                        *
 * uint8_t read6502(uint16_t address)                *
 * void write6502(uint16_t address, uint8_t value)   *
 * You may optionally pass Fake6502 the pointer to a *
 * function which you want to be called after every  *
 * emulated instruction. This function should be a   *
 * void with no parameters expected to be passed to  *
 * it.                                               *
 * This can be very useful. For example, in a NES    *
 * emulator, you check the number of clock ticks     *
 * that have passed so you can know when to handle   *
 * APU events.                                       *
 * To pass Fake6502 this pointer, use the            *
 * hookexternal(void *funcptr) function provided.    *
 * To disable the hook later, pass NULL to it.       *
 * Useful functions in this emulator:                *
 * void reset6502()                                  *
 *   - Call this once before you begin execution.    *
 * void exec6502(uint32_t tickcount)                 *
 *   - Execute 6502 code up to the next specified    *
 *     count of clock ticks.                         *
 * void step6502()                                   *
 *   - Execute a single instrution.                  *
 * void irq6502()                                    *
 *   - Trigger a hardware IRQ in the 6502 core.      *
 * void nmi6502()                                    *
 *   - Trigger an NMI in the 6502 core.              *
 * void hookexternal(void *funcptr)                  *
 *   - Pass a pointer to a void function taking no   *
 *     parameters. This will cause Fake6502 to call  *
 *     that function once after each emulated        *
 *     instruction.                                  *
 * Useful variables in this emulator:                *
 * uint32_t clockticks6502                           *
 *   - A running total of the emulated cycle count.  *
 * uint32_t instructions                             *
 *   - A running total of the total emulated         *
 *     instruction count. This is not related to     *
 *     clock cycle timing.                           *
#include <stdio.h>
#include <stdint.h>
//6502 defines
#define UNDOCUMENTED //when this is defined, undocumented opcodes are handled.
                     //otherwise, they're simply treated as NOPs.
//#define NES_CPU      //when this is defined, the binary-coded decimal (BCD)
                     //status flag is not honored by ADC and SBC. the 2A03
                     //CPU in the Nintendo Entertainment System does not
                     //support BCD operation.
#define FLAG_CARRY     0x01
#define FLAG_ZERO      0x02
#define FLAG_INTERRUPT 0x04
#define FLAG_DECIMAL   0x08
#define FLAG_BREAK     0x10
#define FLAG_CONSTANT  0x20
#define FLAG_OVERFLOW  0x40
#define FLAG_SIGN      0x80
#define BASE_STACK     0x100
#define saveaccum(n) a = (uint8_t)((n) & 0x00FF)
//flag modifier macros
#define setcarry() status |= FLAG_CARRY
#define clearcarry() status &= (~FLAG_CARRY)
#define setzero() status |= FLAG_ZERO
#define clearzero() status &= (~FLAG_ZERO)
#define setinterrupt() status |= FLAG_INTERRUPT
#define clearinterrupt() status &= (~FLAG_INTERRUPT)
#define setdecimal() status |= FLAG_DECIMAL
#define cleardecimal() status &= (~FLAG_DECIMAL)
#define setoverflow() status |= FLAG_OVERFLOW
#define clearoverflow() status &= (~FLAG_OVERFLOW)
#define setsign() status |= FLAG_SIGN
#define clearsign() status &= (~FLAG_SIGN)
//flag calculation macros
#define zerocalc(n) {\
    if ((n) & 0x00FF) clearzero();\
        else setzero();\
#define signcalc(n) {\
    if ((n) & 0x0080) setsign();\
        else clearsign();\
#define carrycalc(n) {\
    if ((n) & 0xFF00) setcarry();\
        else clearcarry();\
#define overflowcalc(n, m, o) { /* n = result, m = accumulator, o = memory */ \
    if (((n) ^ (uint16_t)(m)) & ((n) ^ (o)) & 0x0080) setoverflow();\
        else clearoverflow();\
//6502 CPU registers
uint16_t pc;
uint8_t sp, a, x, y, status;
//helper variables
uint32_t instructions = 0; //keep track of total instructions executed
uint32_t clockticks6502 = 0, clockgoal6502 = 0;
uint16_t oldpc, ea, reladdr, value, result;
uint8_t opcode, oldstatus;
//externally supplied functions
extern uint8_t read6502(uint16_t address);
extern void write6502(uint16_t address, uint8_t value);
//a few general functions used by various other functions
void push16(uint16_t pushval) {
    write6502(BASE_STACK + sp, (pushval >> 8) & 0xFF);
    write6502(BASE_STACK + ((sp - 1) & 0xFF), pushval & 0xFF);
    sp -= 2;
void push8(uint8_t pushval) {
    write6502(BASE_STACK + sp--, pushval);
uint16_t pull16() {
    uint16_t temp16;
    temp16 = read6502(BASE_STACK + ((sp + 1) & 0xFF)) | ((uint16_t)read6502(BASE_STACK + ((sp + 2) & 0xFF)) << 8);
    sp += 2;
    return(temp16);
uint8_t pull8() {
    return (read6502(BASE_STACK + ++sp));
void reset6502() {
    pc = (uint16_t)read6502(0xFFFC) | ((uint16_t)read6502(0xFFFD) << 8);
    a = 0;
    x = 0;
    y = 0;
    sp = 0xFD;
    status |= FLAG_CONSTANT;
static void (*addrtable[256])();
static void (*optable[256])();
uint8_t penaltyop, penaltyaddr;
//addressing mode functions, calculates effective addresses
static void imp() { //implied
static void acc() { //accumulator
static void imm() { //immediate
    ea = pc++;
static void zp() { //zero-page
    ea = (uint16_t)read6502((uint16_t)pc++);
static void zpx() { //zero-page,X
    ea = ((uint16_t)read6502((uint16_t)pc++) + (uint16_t)x) & 0xFF; //zero-page wraparound
static void zpy() { //zero-page,Y
    ea = ((uint16_t)read6502((uint16_t)pc++) + (uint16_t)y) & 0xFF; //zero-page wraparound
static void rel() { //relative for branch ops (8-bit immediate value, sign-extended)
    reladdr = (uint16_t)read6502(pc++);
    if (reladdr & 0x80) reladdr |= 0xFF00;
static void abso() { //absolute
    ea = (uint16_t)read6502(pc) | ((uint16_t)read6502(pc+1) << 8);
    pc += 2;
static void absx() { //absolute,X
    uint16_t startpage;
    ea = ((uint16_t)read6502(pc) | ((uint16_t)read6502(pc+1) << 8));
    startpage = ea & 0xFF00;
    ea += (uint16_t)x;
    if (startpage != (ea & 0xFF00)) { //one cycle penlty for page-crossing on some opcodes
        penaltyaddr = 1;
    pc += 2;
static void absy() { //absolute,Y
    uint16_t startpage;
    ea += (uint16_t)y;
        penaltyaddr = 1;
    pc += 2;
static void ind() { //indirect
    uint16_t eahelp, eahelp2;
    eahelp = (uint16_t)read6502(pc) | (uint16_t)((uint16_t)read6502(pc+1) << 8);
    eahelp2 = (eahelp & 0xFF00) | ((eahelp + 1) & 0x00FF); //replicate 6502 page-boundary wraparound bug
    ea = (uint16_t)read6502(eahelp) | ((uint16_t)read6502(eahelp2) << 8);
    pc += 2;
static void indx() { // (indirect,X)
    uint16_t eahelp;
    eahelp = (uint16_t)(((uint16_t)read6502(pc++) + (uint16_t)x) & 0xFF); //zero-page wraparound for table pointer
    ea = (uint16_t)read6502(eahelp & 0x00FF) | ((uint16_t)read6502((eahelp+1) & 0x00FF) << 8);
static void indy() { // (indirect),Y
    uint16_t eahelp, eahelp2, startpage;
    eahelp = (uint16_t)read6502(pc++);
    eahelp2 = (eahelp & 0xFF00) | ((eahelp + 1) & 0x00FF); //zero-page wraparound
    ea += (uint16_t)y;
        penaltyaddr = 1;
static uint16_t getvalue() {
    if (addrtable[opcode] == acc) return((uint16_t)a);
        else return((uint16_t)read6502(ea));
static uint16_t getvalue16() {
    return((uint16_t)read6502(ea) | ((uint16_t)read6502(ea+1) << 8));
static void putvalue(uint16_t saveval) {
    if (addrtable[opcode] == acc) a = (uint8_t)(saveval & 0x00FF);
        else write6502(ea, (saveval & 0x00FF));
//instruction handler functions
static void adc() {
    penaltyop = 1;
    value = getvalue();
    result = (uint16_t)a + value + (uint16_t)(status & FLAG_CARRY);
    carrycalc(result);
    zerocalc(result);
    overflowcalc(result, a, value);
    signcalc(result);
    #ifndef NES_CPU
    if (status & FLAG_DECIMAL) {
        clearcarry();
        if ((a & 0x0F) > 0x09) {
            a += 0x06;
        if ((a & 0xF0) > 0x90) {
            a += 0x60;
            setcarry();
        clockticks6502++;
    #endif
    saveaccum(result);
static void and() {
    penaltyop = 1;
    value = getvalue();
    result = (uint16_t)a & value;
    zerocalc(result);
    signcalc(result);
    saveaccum(result);
static void asl() {
    value = getvalue();
    result = value << 1;
    carrycalc(result);
    zerocalc(result);
    signcalc(result);
    putvalue(result);
static void bcc() {
    if ((status & FLAG_CARRY) == 0) {
        oldpc = pc;
        pc += reladdr;
        if ((oldpc & 0xFF00) != (pc & 0xFF00)) clockticks6502 += 2; //check if jump crossed a page boundary
            else clockticks6502++;
static void bcs() {
    if ((status & FLAG_CARRY) == FLAG_CARRY) {
        oldpc = pc;
        pc += reladdr;
static void beq() {
    if ((status & FLAG_ZERO) == FLAG_ZERO) {
        oldpc = pc;
        pc += reladdr;
static void bit() {
    value = getvalue();
    zerocalc(result);
    status = (status & 0x3F) | (uint8_t)(value & 0xC0);
static void bmi() {
    if ((status & FLAG_SIGN) == FLAG_SIGN) {
        oldpc = pc;
        pc += reladdr;
static void bne() {
    if ((status & FLAG_ZERO) == 0) {
        oldpc = pc;
        pc += reladdr;
static void bpl() {
    if ((status & FLAG_SIGN) == 0) {
        oldpc = pc;
        pc += reladdr;
static void brk() {
    pc++;
    push16(pc); //push next instruction address onto stack
    push8(status | FLAG_BREAK); //push CPU status to stack
    setinterrupt(); //set interrupt flag
    pc = (uint16_t)read6502(0xFFFE) | ((uint16_t)read6502(0xFFFF) << 8);
static void bvc() {
    if ((status & FLAG_OVERFLOW) == 0) {
        oldpc = pc;
        pc += reladdr;
static void bvs() {
    if ((status & FLAG_OVERFLOW) == FLAG_OVERFLOW) {
        oldpc = pc;
        pc += reladdr;
static void clc() {
    clearcarry();
static void cld() {
    cleardecimal();
static void cli() {
    clearinterrupt();
static void clv() {
    clearoverflow();
static void cmp() {
    penaltyop = 1;
    value = getvalue();
    result = (uint16_t)a - value;
    if (a >= (uint8_t)(value & 0x00FF)) setcarry();
        else clearcarry();
    if (a == (uint8_t)(value & 0x00FF)) setzero();
        else clearzero();
    signcalc(result);
static void cpx() {
    value = getvalue();
    result = (uint16_t)x - value;
    if (x >= (uint8_t)(value & 0x00FF)) setcarry();
        else clearcarry();
    if (x == (uint8_t)(value & 0x00FF)) setzero();
        else clearzero();
    signcalc(result);
static void cpy() {
    value = getvalue();
    result = (uint16_t)y - value;
    if (y >= (uint8_t)(value & 0x00FF)) setcarry();
        else clearcarry();
    if (y == (uint8_t)(value & 0x00FF)) setzero();
        else clearzero();
    signcalc(result);
static void dec() {
    value = getvalue();
    result = value - 1;
    zerocalc(result);
    signcalc(result);
    putvalue(result);
static void dex() {
    x--;
    zerocalc(x);
    signcalc(x);
static void dey() {
    y--;
    zerocalc(y);
    signcalc(y);
static void eor() {
    penaltyop = 1;
    value = getvalue();
    result = (uint16_t)a ^ value;
    zerocalc(result);
    signcalc(result);
    saveaccum(result);
static void inc() {
    value = getvalue();
    result = value + 1;
    zerocalc(result);
    signcalc(result);
    putvalue(result);
static void inx() {
    x++;
    zerocalc(x);
    signcalc(x);
static void iny() {
    y++;
    zerocalc(y);
    signcalc(y);
static void jmp() {
    pc = ea;
static void jsr() {
    push16(pc - 1);
    pc = ea;
static void lda() {
    penaltyop = 1;
    value = getvalue();
    a = (uint8_t)(value & 0x00FF);
    zerocalc(a);
    signcalc(a);
static void ldx() {
    penaltyop = 1;
    value = getvalue();
    x = (uint8_t)(value & 0x00FF);
    zerocalc(x);
    signcalc(x);
static void ldy() {
    penaltyop = 1;
    value = getvalue();
    y = (uint8_t)(value & 0x00FF);
    zerocalc(y);
    signcalc(y);
static void lsr() {
    value = getvalue();
    result = value >> 1;
    if (value & 1) setcarry();
        else clearcarry();
    zerocalc(result);
    signcalc(result);
    putvalue(result);
static void nop() {
    switch (opcode) {
        case 0x1C:
        case 0x3C:
        case 0x5C:
        case 0x7C:
        case 0xDC:
        case 0xFC:
            penaltyop = 1;
            break;
static void ora() {
    penaltyop = 1;
    value = getvalue();
    result = (uint16_t)a | value;
    zerocalc(result);
    signcalc(result);
    saveaccum(result);
static void pha() {
    push8(a);
static void php() {
static void pla() {
    a = pull8();
    zerocalc(a);
    signcalc(a);
static void plp() {
    status = pull8() | FLAG_CONSTANT;
static void rol() {
    value = getvalue();
    result = (value << 1) | (status & FLAG_CARRY);
    carrycalc(result);
    zerocalc(result);
    signcalc(result);
    putvalue(result);
static void ror() {
    value = getvalue();
    result = (value >> 1) | ((status & FLAG_CARRY) << 7);
        else clearcarry();
    zerocalc(result);
    signcalc(result);
    putvalue(result);
static void rti() {
    status = pull8();
    value = pull16();
    pc = value;
static void rts() {
    value = pull16();
    pc = value + 1;
static void sbc() {
    penaltyop = 1;
    value = getvalue() ^ 0x00FF;
    carrycalc(result);
    zerocalc(result);
    signcalc(result);
    #ifndef NES_CPU
        clearcarry();
        a -= 0x66;
            a += 0x06;
            a += 0x60;
            setcarry();
        clockticks6502++;
    #endif
    saveaccum(result);
static void sec() {
    setcarry();
static void sed() {
    setdecimal();
static void sei() {
    setinterrupt();
static void sta() {
    putvalue(a);
static void stx() {
    putvalue(x);
static void sty() {
    putvalue(y);
static void tax() {
    x = a;
    zerocalc(x);
    signcalc(x);
static void tay() {
    y = a;
    zerocalc(y);
    signcalc(y);
static void tsx() {
    x = sp;
    zerocalc(x);
    signcalc(x);
static void txa() {
    a = x;
    zerocalc(a);
    signcalc(a);
static void txs() {
    sp = x;
static void tya() {
    a = y;
    zerocalc(a);
    signcalc(a);
//undocumented instructions
#ifdef UNDOCUMENTED
    static void lax() {
        lda();
        ldx();
    static void sax() {
        sta();
        stx();
        putvalue(a & x);
        if (penaltyop && penaltyaddr) clockticks6502--;
    static void dcp() {
        dec();
        cmp();
    static void isb() {
        inc();
        sbc();
    static void slo() {
        asl();
        ora();
    static void rla() {
        rol();
        and();
    static void sre() {
        lsr();
        eor();
    static void rra() {
        ror();
        adc();
#else
    #define lax nop
    #define sax nop
    #define dcp nop
    #define isb nop
    #define slo nop
    #define rla nop
    #define sre nop
    #define rra nop
#endif
static void (*addrtable[256])() = {
/*        |  0  |  1  |  2  |  3  |  4  |  5  |  6  |  7  |  8  |  9  |  A  |  B  |  C  |  D  |  E  |  F  |     */
/* 0 */     imp, indx,  imp, indx,   zp,   zp,   zp,   zp,  imp,  imm,  acc,  imm, abso, abso, abso, abso, /* 0 */
/* 1 */     rel, indy,  imp, indy,  zpx,  zpx,  zpx,  zpx,  imp, absy,  imp, absy, absx, absx, absx, absx, /* 1 */
/* 2 */    abso, indx,  imp, indx,   zp,   zp,   zp,   zp,  imp,  imm,  acc,  imm, abso, abso, abso, abso, /* 2 */
/* 3 */     rel, indy,  imp, indy,  zpx,  zpx,  zpx,  zpx,  imp, absy,  imp, absy, absx, absx, absx, absx, /* 3 */
/* 4 */     imp, indx,  imp, indx,   zp,   zp,   zp,   zp,  imp,  imm,  acc,  imm, abso, abso, abso, abso, /* 4 */
/* 5 */     rel, indy,  imp, indy,  zpx,  zpx,  zpx,  zpx,  imp, absy,  imp, absy, absx, absx, absx, absx, /* 5 */
/* 6 */     imp, indx,  imp, indx,   zp,   zp,   zp,   zp,  imp,  imm,  acc,  imm,  ind, abso, abso, abso, /* 6 */
/* 7 */     rel, indy,  imp, indy,  zpx,  zpx,  zpx,  zpx,  imp, absy,  imp, absy, absx, absx, absx, absx, /* 7 */
/* 8 */     imm, indx,  imm, indx,   zp,   zp,   zp,   zp,  imp,  imm,  imp,  imm, abso, abso, abso, abso, /* 8 */
/* 9 */     rel, indy,  imp, indy,  zpx,  zpx,  zpy,  zpy,  imp, absy,  imp, absy, absx, absx, absy, absy, /* 9 */
/* A */     imm, indx,  imm, indx,   zp,   zp,   zp,   zp,  imp,  imm,  imp,  imm, abso, abso, abso, abso, /* A */
/* B */     rel, indy,  imp, indy,  zpx,  zpx,  zpy,  zpy,  imp, absy,  imp, absy, absx, absx, absy, absy, /* B */
/* C */     imm, indx,  imm, indx,   zp,   zp,   zp,   zp,  imp,  imm,  imp,  imm, abso, abso, abso, abso, /* C */
/* D */     rel, indy,  imp, indy,  zpx,  zpx,  zpx,  zpx,  imp, absy,  imp, absy, absx, absx, absx, absx, /* D */
/* E */     imm, indx,  imm, indx,   zp,   zp,   zp,   zp,  imp,  imm,  imp,  imm, abso, abso, abso, abso, /* E */
/* F */     rel, indy,  imp, indy,  zpx,  zpx,  zpx,  zpx,  imp, absy,  imp, absy, absx, absx, absx, absx  /* F */
static void (*optable[256])() = {
/* 0 */      brk,  ora,  nop,  slo,  nop,  ora,  asl,  slo,  php,  ora,  asl,  nop,  nop,  ora,  asl,  slo, /* 0 */
/* 1 */      bpl,  ora,  nop,  slo,  nop,  ora,  asl,  slo,  clc,  ora,  nop,  slo,  nop,  ora,  asl,  slo, /* 1 */
/* 2 */      jsr,  and,  nop,  rla,  bit,  and,  rol,  rla,  plp,  and,  rol,  nop,  bit,  and,  rol,  rla, /* 2 */
/* 3 */      bmi,  and,  nop,  rla,  nop,  and,  rol,  rla,  sec,  and,  nop,  rla,  nop,  and,  rol,  rla, /* 3 */
/* 4 */      rti,  eor,  nop,  sre,  nop,  eor,  lsr,  sre,  pha,  eor,  lsr,  nop,  jmp,  eor,  lsr,  sre, /* 4 */
/* 5 */      bvc,  eor,  nop,  sre,  nop,  eor,  lsr,  sre,  cli,  eor,  nop,  sre,  nop,  eor,  lsr,  sre, /* 5 */
/* 6 */      rts,  adc,  nop,  rra,  nop,  adc,  ror,  rra,  pla,  adc,  ror,  nop,  jmp,  adc,  ror,  rra, /* 6 */
/* 7 */      bvs,  adc,  nop,  rra,  nop,  adc,  ror,  rra,  sei,  adc,  nop,  rra,  nop,  adc,  ror,  rra, /* 7 */
/* 8 */      nop,  sta,  nop,  sax,  sty,  sta,  stx,  sax,  dey,  nop,  txa,  nop,  sty,  sta,  stx,  sax, /* 8 */
/* 9 */      bcc,  sta,  nop,  nop,  sty,  sta,  stx,  sax,  tya,  sta,  txs,  nop,  nop,  sta,  nop,  nop, /* 9 */
/* A */      ldy,  lda,  ldx,  lax,  ldy,  lda,  ldx,  lax,  tay,  lda,  tax,  nop,  ldy,  lda,  ldx,  lax, /* A */
/* B */      bcs,  lda,  nop,  lax,  ldy,  lda,  ldx,  lax,  clv,  lda,  tsx,  lax,  ldy,  lda,  ldx,  lax, /* B */
/* C */      cpy,  cmp,  nop,  dcp,  cpy,  cmp,  dec,  dcp,  iny,  cmp,  dex,  nop,  cpy,  cmp,  dec,  dcp, /* C */
/* D */      bne,  cmp,  nop,  dcp,  nop,  cmp,  dec,  dcp,  cld,  cmp,  nop,  dcp,  nop,  cmp,  dec,  dcp, /* D */
/* E */      cpx,  sbc,  nop,  isb,  cpx,  sbc,  inc,  isb,  inx,  sbc,  nop,  sbc,  cpx,  sbc,  inc,  isb, /* E */
/* F */      beq,  sbc,  nop,  isb,  nop,  sbc,  inc,  isb,  sed,  sbc,  nop,  isb,  nop,  sbc,  inc,  isb  /* F */
static const uint32_t ticktable[256] = {
/* 0 */      7,    6,    2,    8,    3,    3,    5,    5,    3,    2,    2,    2,    4,    4,    6,    6,  /* 0 */
/* 1 */      2,    5,    2,    8,    4,    4,    6,    6,    2,    4,    2,    7,    4,    4,    7,    7,  /* 1 */
/* 2 */      6,    6,    2,    8,    3,    3,    5,    5,    4,    2,    2,    2,    4,    4,    6,    6,  /* 2 */
/* 3 */      2,    5,    2,    8,    4,    4,    6,    6,    2,    4,    2,    7,    4,    4,    7,    7,  /* 3 */
/* 4 */      6,    6,    2,    8,    3,    3,    5,    5,    3,    2,    2,    2,    3,    4,    6,    6,  /* 4 */
/* 5 */      2,    5,    2,    8,    4,    4,    6,    6,    2,    4,    2,    7,    4,    4,    7,    7,  /* 5 */
/* 6 */      6,    6,    2,    8,    3,    3,    5,    5,    4,    2,    2,    2,    5,    4,    6,    6,  /* 6 */
/* 7 */      2,    5,    2,    8,    4,    4,    6,    6,    2,    4,    2,    7,    4,    4,    7,    7,  /* 7 */
/* 8 */      2,    6,    2,    6,    3,    3,    3,    3,    2,    2,    2,    2,    4,    4,    4,    4,  /* 8 */
/* 9 */      2,    6,    2,    6,    4,    4,    4,    4,    2,    5,    2,    5,    5,    5,    5,    5,  /* 9 */
/* A */      2,    6,    2,    6,    3,    3,    3,    3,    2,    2,    2,    2,    4,    4,    4,    4,  /* A */
/* B */      2,    5,    2,    5,    4,    4,    4,    4,    2,    4,    2,    4,    4,    4,    4,    4,  /* B */
/* C */      2,    6,    2,    8,    3,    3,    5,    5,    2,    2,    2,    2,    4,    4,    6,    6,  /* C */
/* D */      2,    5,    2,    8,    4,    4,    6,    6,    2,    4,    2,    7,    4,    4,    7,    7,  /* D */
/* E */      2,    6,    2,    8,    3,    3,    5,    5,    2,    2,    2,    2,    4,    4,    6,    6,  /* E */
/* F */      2,    5,    2,    8,    4,    4,    6,    6,    2,    4,    2,    7,    4,    4,    7,    7   /* F */
void nmi6502() {
    push16(pc);
    push8(status);
    status |= FLAG_INTERRUPT;
    pc = (uint16_t)read6502(0xFFFA) | ((uint16_t)read6502(0xFFFB) << 8);
void irq6502() {
    push16(pc);
    push8(status);
uint8_t callexternal = 0;
void (*loopexternal)();
void exec6502(uint32_t tickcount) {
    clockgoal6502 += tickcount;
    while (clockticks6502 < clockgoal6502) {
        opcode = read6502(pc++);
        penaltyop = 0;
        penaltyaddr = 0;
        (*addrtable[opcode])();
        (*optable[opcode])();
        clockticks6502 += ticktable[opcode];
        if (penaltyop && penaltyaddr) clockticks6502++;
        instructions++;
        if (callexternal) (*loopexternal)();
void step6502() {
    penaltyop = 0;
    penaltyaddr = 0;
    clockgoal6502 = clockticks6502;
    instructions++;
void hookexternal(void *funcptr) {
    if (funcptr != (void *)NULL) {
        loopexternal = funcptr;
        callexternal = 1;
    } else callexternal = 0;
PostPosted: Tue Apr 07, 2015 12:37 pm
Thanks Mike - added to http://6502.org/tools/emu/
(It would be good to run Klaus' testsuite on this engine - maybe I'll get around to that some day...)
Ref: https://github.com/Klaus2m5/6502_65C02_functional_tests
and viewtopic.php?f=2&t=2241
(Hat tip to Damian Peckett)
PostPosted: Wed Apr 08, 2015 4:09 pm
Hey Mike, I know that code, pretty sure that's your code running currently on my arduino uno with ehbasic LOL btw you can bumps the 1536 bytes of ram for the emulator to 1800 bytes on the UNO gives you a woop of 1031 bytes free for the basic.
PostPosted: Tue Apr 21, 2015 12:23 pm
I ran the tests: good news is that all is well ... except for BCD (decimal mode) - which is normal. I thought I might try to patch in a BCD implementation, but haven't got around to it. All the correct BCD code I'm aware of is licensed with an open-source license, which isn't compatible with this public-domain code.
PostPosted: Tue Apr 21, 2015 3:03 pm
... All the correct BCD code I'm aware of is licensed with an open-source license, which isn't compatible with this public-domain code.
I would like to publicly announce that I have placed my attempted correction in the public domain:
viewtopic.php?f=3&t=3083&p=35119&hilit=mike+chambers#p35119
I am unsure if it reacts appropriately to invalid inputs, but I most certainly won't be surprised or offended if a better or more accurate solution can be found.
Mike B.
PostPosted: Tue Apr 21, 2015 3:25 pm
Oh, well done, and thank you! Have you yet done any testing with this code? If not I can give it a spin.
PostPosted: Tue Apr 21, 2015 4:49 pm
It has seen limited testing, and seems to provide valid BCD results for valid BCD inputs. The SBC instruction is a slightly different matter, and needs to be addressed also. I'm at work right now, but I'll spend some time tonight working on an appropriate patch for it.
Mike B.
PostPosted: Tue Apr 21, 2015 4:51 pm
That would be great!
PostPosted: Wed Apr 22, 2015 3:32 am
Okay, the following two functions are offered in the public domain, and are intended to replace the functions of the same names in the code provided by Mike Chambers above, in the hope that they will provide more suitable BCD results. They are alleged to do so, but without warranty, and with the caveat that they are not guaranteed to provide accumulator and condition code results that are identical to the actual target hardware. This caveat includes, but is not limited to, the results that may arise from inputs which are not valid BCD, and these functions may not even provide valid BCD output in those cases.
static void adc() {
    penaltyop = 1;
    value = getvalue();
    zerocalc(result);
    signcalc(result);
    #ifndef NES_CPU
    if (status & FLAG_DECIMAL)       /* detect and apply BCD nybble carries */
        result += ((((result + 0x66) ^ (uint16_t)a ^ value) >> 3) & 0x22) * 3;
    #endif
    carrycalc(result);
    saveaccum(result);
static void sbc() {
    penaltyop = 1;
    value = getvalue() ^ 0x00FF;     /* ones complement */
    #ifndef NES_CPU
    if (status & FLAG_DECIMAL)       /* use nines complement for BCD */
        value -= 0x0066;
    #endif
    zerocalc(result);
    signcalc(result);
    #ifndef NES_CPU
    #endif
    carrycalc(result);
    saveaccum(result);
Comments and/or corrections are welcome.
Mike B.
PostPosted: Wed Apr 22, 2015 8:05 am
Very nice, thanks Mike - that passes Klaus' testsuite now, which means it's all AOK for legal BCD inputs.
PostPosted: Wed Apr 22, 2015 11:17 am
I seem to remember having seen some code which depended on the processor's behaviour for 'illegal' BCD values though..
-Tor
PostPosted: Wed Apr 22, 2015 11:20 am
There's a fast ASCII conversion (or hex conversion?) which uses BCD to add (or maybe to subtract) six.
PostPosted: Wed Apr 22, 2015 12:55 pm
Yes, I think that was the one I saw. Thanks Ed.
-Tor
PostPosted: Wed Apr 22, 2015 3:15 pm
Ah, found it, in Bruce's article at http://www.6502.org/tutorials/decimal_mode.html#6
