It is currently Fri Nov 22, 2024 9:39 pm
PostPosted: Wed Jan 08, 2014 8:36 am
I say quirk since I am not sure it is a bug although I am inclined to say it it.
My Orwell computer is using MS Basic. I took the OSI version and have been modifying and adding to that as I work though my reviews of the 80s Usborne books. I just found some interesting behavior in a listing from "Creepy Computer Games" in a game called Ghost Guzzler.
This game prints a number on screen that moves across to the right. On the right is a : (your ghost guzzler) and another number you control. You make your number match the moving one and when the moving one hits the guzzler it eats it if it's the same. If different you lose a life. The line of code in BASIC of interest is this:
120 PRINT TAB(I);N;TAB(18);":";Y
Where I is the position of the number. N is the number and Y is your changing number.
I starts at 1.
When I run this it it starts printing the number in the third column, not the first one. This seems to be for two reasons.
1. In this version of MS Basic TAB seem indexed from 0. So TAB(0) is the first column, TAB(1) is the second column.
2. When you print a numeric variable it will print it with a space in front of it.
These two things together mean the first character is actually printed in column 3.
Out of interest I found an online Vic 20 emulator and that shows the same behaviour. I also found an online Applesoft emulator and that doesn't. It handles TABs differently and also doesn't print a space before variables.
So I compared the assembly. The relevant bits are below:
MS BASIC (My Orwell BASIC):
L29DE:
        lda     POSX
        cmp     Z18
        bcc     L29EA
        jsr     CRDO
        jmp     L2A0D
L29EA:
        sec
L29EB:
        sbc     #$0E
        bcs     L29EB
        eor     #$FF
        adc     #$01
        bne     L2A08
L29F5:
        pha
        jsr     GTBYTC
        cmp     #')'
        bne     SYNERR4
        pla
        cmp     #TOKEN_TAB
        bne     L2A0A
        txa
        sbc     POSX
        bcc     L2A0D
        beq     L2A0D
L2A08:
        tax
L2A0A:
        jsr     OUTSP
        dex
        bne     L2A0A
L2A0D:
        jsr     CHRGET
        jmp     PRINT2
Applesoft Basic:
                    1320 *--------------------------------
                    1330 *      TAB TO NEXT COMMA COLUMN
                    1340 *      <<< NOTE BUG IF WIDTH OF WINDOW LESS THAN 33 >>>
                    1350 PR.COMMA
DB03- A5 24    1360        LDA MON.CH
DB05- C9 18    1370        CMP #24      <<< BUG:  IT SHOULD BE 32 >>>
DB07- 90 05    1380        BCC .1       NEXT COLUMN, SAME LINE
DB09- 20 FB DA 1390        JSR CRDO     FIRST COLUMN, NEXT LINT
DB0C- D0 21    1400        BNE PR.NEXT.CHAR  ...ALWAYS
DB0E- 69 10    1410 .1     ADC #16
DB10- 29 F0    1420        AND #$F0     ROUND TO 16 OR 32
DB12- 85 24    1430        STA MON.CH
DB14- 90 19    1440        BCC PR.NEXT.CHAR  ...ALWAYS
                    1450 *--------------------------------
                    1460 PR.TAB.OR.SPC
DB16- 08       1470        PHP          C=0 FOR SPC(, C=1 FOR TAB(
DB17- 20 F5 E6 1480        JSR GTBYTC   GET VALUE
DB1A- C9 29    1490        CMP #')'     TRAILING PARENTHESIS
DB1C- F0 03    1500        BEQ .1       GOOD
DB1E- 4C C9 DE 1510        JMP SYNERR   NO, SYNTAX ERROR
DB21- 28       1520 .1     PLP          TAB( OR SPC(
DB22- 90 07    1530        BCC .2       SPC(
DB24- CA       1540        DEX          TAB(
DB25- 8A       1550        TXA          CALCULATE SPACES NEEDED FOR TAB(
DB26- E5 24    1560        SBC MON.CH
DB28- 90 05    1570        BCC PR.NEXT.CHAR  ALREADY PAST THAT COLUMN
DB2A- AA       1580        TAX          NOW DO A SPC( TO THE SPECIFIED COLUMN
DB2B- E8       1590 .2     INX
DB2C- CA       1600 NXSPC  DEX
DB2D- D0 06    1610        BNE DOSPC    MORE SPACES TO PRINT
               1620 *--------------------------------
               1630 PR.NEXT.CHAR
DB2F- 20 B1 00 1640        JSR CHRGET
DB32- 4C D7 DA 1650        JMP PRINT2   CONTINUE PARSING PRINT LIST
               1660 *--------------------------------
DB35- 20 57 DB 1670 DOSPC  JSR OUTSP
DB38- D0 F2    1680        BNE NXSPC    ...ALWAYS
It seems there is a difference in how it checks for how many spaces to print and when it does the decrement of the counter for the number of spaces (which is in x) but I haven't quite got my head around why in the first case it always prints one extra space?
So, would you call this a bug or not? I think it is. Interestingly it means if you enter the listing as it is in the book the program won't work properly on VIC20s!
I am writing up the actual review to the book now and will post the link here when done.
Simon
PostPosted: Wed Jan 08, 2014 9:01 am
Take a look here: http://www.pagetable.com/?p=46
It describes differences and bugfixes between MS Basic versions. Maybe you can find something there.
-Tor
PostPosted: Wed Jan 08, 2014 11:01 am
-Tor
Yep, that's where I originally got my version from but it doesn't mention this specific issue.
I put up my latest Usborne book review here. Is late here so not checked for typos yet!
http://www.asciimation.co.nz/bb/2014/01/08/review-usborne-creepy-computer-games
Simon
PostPosted: Wed Jan 08, 2014 12:16 pm
I remember stumbling over the leading space in PRINTing a variable for almost every BASIC I used at the time. It is the absence of a negative sign in the number which causes a space to be printed instead of a plus sign. Try printing a negative variable and see, if you still get a space ahead of it!
And no, I don't think it qualifies as a bug. A shift of a tabbed number between rows because of changing sign is not very nice to look at.
PostPosted: Wed Jan 08, 2014 5:28 pm
That's it exactly! I tried it with a negative number and yes you are correct, it prints with no space. Thank you!
I also decided that the TAB indexing isn't a bug either since the TAB in MS Basic is saying move the cursor this many spaces. Saying move 0 spaces, TAB(0), is a valid thing to do.
Thanks again. I knew someone would have seen this.
Simon
PostPosted: Thu Jan 09, 2014 1:50 am
I've used both flavors of MS-BASIC over the last 30+ years, and I can tell you that it's less frustrating figuring out how to add the leading space character than figuring out how to eliminate it, especially in tight spots.
Mike
