It is currently Sun Oct 06, 2024 12:01 pm
Post new topic Reply to topic  [ 1 post ]
PostPosted: Sat Dec 28, 2013 12:19 pm
Hello everyone,
i have implemented a printf* family (C-like style) functions in assembler for 65816:
http://65xx.unet.bz/mb01/B1603.zip
look at F8/vprint.asm for source code.
;; C-like format function (as printf())
;;   FORMAT STRING
;;   '%'[flag][width]['.'precision][modifier]type
;;   flags ::=    '-' | '+' | ' ' | '#' | '0' | ','
;;   width ::=       '*' | number (8 bit) (if * byte passd by arg)
;;   precision ::=   '*' | number (8 bit) (if * byte passd by arg)
;;   modifier ::=   'l' | 'h' | 'b' | 'H' | 'B'
;;   type ::=   'c' | 's' | 'd' | 'i' | 'u' | 'x' | 'X' | 'p' | 'P' |
;;         'f' | 'F' | 'e' | 'E' | 'g' | 'G'
;;   flag '#'   - alternate form for hex (C-style:prefix with 0x or 0X)
;;   flag '-'   - left justify (default)
;;   flag '+'   - right justify
;;   flag ' ' or '0' - fill field with blank or '0'
;;   flag ','   - only for d,i,u types - group thousands with
;;           ',' as seperator
;;   c      - character (no modifier allowed)
;;   s      - ASCIZ string (NULL terminated string)
;;   Bs      - Pascal/Basic string
;;   d,i      - signed integer 32 bit (in decimal)
;;   u      - unsigned integer 32 bit (in decimal)
;;   ld, li      - long signed integer 64 bit (in decimal)
;;   lu      - long unsigned integer 64 bit (in decimal)
;;   hd, hi      - short signed integer 16 bit (in decimal)
;;   hu      - short unsigned integer 16 bit (in decimal)
;;   bd, bi      - byte signed integer (in decimal)
;;   bu      - byte unsigned integer (in decimal)
;;   x,X      - unsigned integer 32 bit in hex (nocaps/caps)
;;   lx,lX      - long unsigned integer 64 bit in hex (nocaps/caps)
;;   hx,hX      - short unsigned integer 16 bit in hex (nocaps/caps)
;;   bx,bX      - unsigned byte in hex (nocaps/caps)
;;   p,P      - long pointer (3 bytes) in hex (nocaps/caps)
;;   f,F,e,E,g,G   - float point number (see sprintf())
Look at F8/fpemu.asm for implementation of 4 basic operation for float encoded in 80 bit (19/20 significance digits) and at F8/intp.asm for implementation of integer (signed/unsigned) operations.
Parameters are passed by a frame stack (see source code) and caller will create frame stack before calling and clean frame stack after return.
Marco
http://65xx.unet.bz/ - Hardware & Software 65XX family
