I'm also thinking on SD-card interfacing (and other SPI devices btw) but not with bit-banging which seems to be too slow for my taste.
Do you have a particular speed goal?
Here's part of the SPI-bitbanging code I have posted on my website:
CLK_UP: MACRO ; NOTE! Accum is not preserved!
LDA #1
TSB VIA3PB
ENDM
CLK_DN: MACRO ; NOTE! Accum is not preserved!
LDA #1
TRB VIA3PB
ENDM
CLK_LO_PULSE: MACRO ; NOTE! Clock must already be known to be high!
DEC VIA3PB
INC VIA3PB
ENDM
CLK_HI_PULSE: MACRO ; NOTE! Clock must already be known to be low!
INC VIA3PB
DEC VIA3PB
ENDM
MOSI_UP: MACRO ; NOTE! Accum is not preserved!
LDA #2
TSB VIA3PB
ENDM
MOSI_DN: MACRO ; NOTE! Accum is not preserved!
LDA #2
TRB VIA3PB
ENDM
; For SEND_BYT and RCV_BYT below, I use program structures discussed in my web page
; http://wilsonminesco.com/StructureMacros/index.html . The source code for implementing them on the C32 assembler is at
; http://wilsonminesco.com/StructureMacros/STRUCMAC.ASM , but you can undoubtedly see what they will assemble if you want to do it
; without the macros. I used them here to make it more clear what is happening.
SEND_BYT: ; Start with byte in A. Slave must already be selected.
PHA ; Put the input number on the stack because we need A for the TRB/TSB mask below.
CLK_DN ; Prepare for mode-0 transmit, and for high clock pulse with INC DEC.
TSX ; Put the stack pointer in X for shifting below without bringing it back into the accum.
LDA #2 ; 2 is the value of the MOSI bit for TSB & TRB.
FOR_Y 8, DOWN_TO, 0 ; 8 is the number of bits we will shift out and test in the loop.
ASL 101,X ; Shift the input number left, since transmission is msb-first.
IF_C_CLR ; The bit gets put in the carry flag.
TRB VIA3PB ; If the bit was a 0, clear the MOSI bit in VIA3PB,
ELSE_ ; otherwise
TSB VIA3PB ; (ie, the bit was a 1), set the MOSI bit in VIA3PB.
END_IF
CLK_HI_PULSE ; Pulse the clock line. The INC/DEC does not affect A.
NEXT_Y ; Decr the counter and see if we need to repeat the loop.
PLA ; Remove the number from the stack. (We don't need it anymore, but we need the stack cleaned up.)
RTS
RCV_BYT: ; Slave must already be selected, and first bit must already be waiting on MISO. Output is in A.
CLK_DN ; Prepare for mode-0 receive, and for high clk pulse with INC DEC.
LDA #0 ; We will build up the byte in A, so init it to 0.
FOR_Y 8, DOWN_TO, 0 ; 8 is the number of bits we will shift in in the loop.
BIT VIA3PB ; MISO is on VIA3PB6, which BIT reflects in the V flag.
CLC
IF_V_SET
SEC ; Transfer V flag into C flag,
END_IF
ROL A ; then rotate it into the accum.
CLK_HI_PULSE ; Pulse the clock to get the next bit ready, even if it won't get read
NEXT_Y ; until the next RCV_BYT . Decr the counter and see if we need to repeat.
RTS ; Output is in accum.
< now build the routines specific to the SPI ICs you want to use >
Note that it only takes two instructions for a complete clock pulse, and that in the sending, the MOSI is set or cleared using only one instruction, not having to read, AND/OR, and then store back. It's still bit-banging of course, but probably quicker than many might think. For further speed-up, you could straight-line it to eliminate the DEY, BNE (which are what the "NEXT_Y" macro assembles) so it's no longer a loop.
I know SPI allows sending and receiving at the same time, but none of the SPI ICs I've used so far do that. They only do one at a time.
Option2: Let's use a dedicated SPI interface IC. Unfortunately there is not so many ... Unlike UARTs, they're quite rate [rare?]. To be precise I only know about 65SPI, but it would be harder/more expensive to get one from Hungary, also maybe it's too 65xx specific, I'd like something I can use in my Z80 projects as well. I don't know if 65SPI can be used with outer [other?] CPUs easily or not.
Contact Daryl here on the forum and get one or more 65SPI's directly from him. I know he won't charge you abusive amounts for shipping like some companies do, and he can probably send it out within a day of when you ask. I'm sure you'll find him to be very easy to do business with.
