Joined: Thu May 28, 2009 9:46 pm Posts: 8411 Location: Midwestern USA
James_Parsons wrote: Im using Kowalski assembler and I type Code: .ORG *= $0300
.ORG is a pseudo-op that is an alternative to *=. Use one or the other and make sure there is whitespace (a tab will do) between the pseudo-op and the left margin. Here's a program, written to generate 65C816 object code, that illustrates a lot of what you can do in the simulator. Note the extensive use of macros, an assembly language programmer's second best friend:Code: .opt proc65c02,caseinsensitive ;* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * ;* * ;* W65C816S PROOF OF CONCEPT SINGLE-BOARD COMPUTER * ;* * ;* DISPLAY DATE, TIME OF DAY & UP TIME * ;* ——————————————————————————————————————————————————————————————————————————————— * ;* Copyright ©1991-2013 by BCS Technology Limited. All rights reserved. * ;* * ;* Permission is hereby granted to use, copy, modify and distribute this software, * ;* provided this copyright notice remains in the source code and proper attribu- * ;* tion is given. Redistribution, regardless of form, must be at no charge to the * ;* end user. This code or any part thereof, including any derivation, MAY NOT be * ;* incorporated into any package intended for sale, unless written permission has * ;* been given by the copyright holder. * ;* * ;* THERE IS NO WARRANTY OF ANY KIND WITH THIS SOFTWARE. The user assumes all risk * ;* in connection with the incorporation of this software into any system. * ;* * ;* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * ; .include "include\816macs.65s" .include "include\convenmacs.65s" .include "include\atomic.65s" .include "include\stdascii.65s" .include "include\sys\macros_console.65s" .include "include\architecture.65s" .include "include\sys\bios.65s" .include "lib\date\atomic.65s" ;=============================================================================== ; ;LOCAL DECLARATIONS ; _origin_ =$00c000 ; a_qmark ='?' ;ASC conversion base n_asc =3 ;chars in day or month n_shfdcd =5 ;day or month decode shifts stckptr =1 ;base stack offset reference pbnk =$0c ;transfer bank for experimenting tbnk =$1f ;data bank for experimenting _faca_ =$80 ;accumulator base ; ; ; accumulator transfer banks... ; dbnk =tbnk sbnk =pbnk ; .include "lib\math\atomic.65s" ;=============================================================================== ; ;RTC BUFFER DEFINITIONS ; rtcsec =0 ;seconds rtcmin =rtcsec+s_byte ;minutes rtchrs =rtcmin+s_byte ;hours rtcdow =rtchrs+s_byte ;day of week rtcdat =rtcdow+s_byte ;date rtcmon =rtcdat+s_byte ;month rtcylo =rtcmon+s_byte ;year LSB rtcyhi =rtcylo+s_byte ;year MSB ; s_rtcbuf =rtcyhi+s_byte ;RTC buffer size ; ;=============================================================================== ; ;LOCAL MACROS ; mem_faca .macro .s,.m ;copy integer to FACA longr ldaw .s ldxw .m jsr imemfaca .endm ; mem_facb .macro .s,.m ;copy integer to FACB longr ldaw .s ldxw .m jsr imemfacb .endm ; faca_mem .macro .s,.m ;copy FACA to integer longr ldaw .s ldxw .m jsr ifacamem .endm ; ;=============================================================================== ; ;MAINLINE ; * = _origin_ ; dpydat longa ldaw dstkptr ;default stack pointer tcs ;reset to top of stack shortr lda #tbnk pha plb ;set default data bank ldx #<rtcbuf ;RTC buffer LSB ldy #>rtcbuf ;RTC buffer MSB jsr getdtr ;get date & time from RTC jsr getutim ;get up time stx uptime ;save up time LSW sty uptime+s_word ;save up time MSW shortr ;8 bit registers lda dow ;day of week and #_dayswk_ ;mask out-of range DOW tay ;day index longa ldaw dowtab ;decode table pointer ldx #0 ;starting buffer index jsr cvtdm ;convert day jsr insrtblk ;add a blank lda month jsr bcdbdig ;convert to binary cmp #_monsyr_+1 bcc .0000010 ;in range ; lda #0 ;unknown month ; .0000010 tay ;month index longa ldaw montab ;table pointer jsr cvtdm ;convert day jsr insrtblk ;add a blank lda date ;get date jsr bcdasc ;change to ASCII beq .0000020 ;skip leading zero ; jsr insrtCOM ;add 10s to buffer ; .0000020 xba jsr insrtCOM ;add 1s to buffer jsr insrtblk lda hours ;get hour jsr addtostr ;add to string jsr insrtcol ;add a colon to string lda minutes ;get minute jsr addtostr ;add to string jsr insrtcol ;add a colon to string lda seconds ;get seconds jsr addtostr ;add to string jsr insrtblk ;add a blank ldy #0 ; .0000030 lda timezone,y ;timezone string beq .0000040 ; sta strgbuf,x ;add to string inx iny bra .0000030 ; .0000040 jsr insrtblk lda yearhi ;year MSB jsr addtostr ;add to string lda yearlo ;year LSB jsr addtostr ;add to string stz strgbuf,x ;terminate string printstr preamble ;print newline, etc. printstr strgbuf ;print date & time printstr uptimea ;"Up..." jsr brkutim ;break down uptime longa shortx lda udays ;uptime days beq .0000050 ;up less than a day ; mem_faca s_dword,udays jsr binasc ;convert days &... printstr strgbuf ;print printstr uptdays ;"day" longa lda udays ;uptime days jsr pplural ;pluralize if necessary jsr pcomma ;print a comma longa ; .0000050 lda uhours ;uptime hours beq .0000060 ;zero ; mem_faca s_dword,uhours jsr binasc ;convert hours &... printstr strgbuf ;print printstr upthours ;"hour" longa lda uhours ;uptime hours jsr pplural ;pluralize if necessary jsr pcomma ;print a comma longa ; .0000060 lda umins ;uptime minutes beq .0000070 ;zero ; mem_faca s_dword,umins jsr binasc ;convert minutes &... printstr strgbuf ;print printstr uptmins ;"minute" longa lda umins ;uptime minutes jsr pplural ;pluralize if necessary jsr pcomma ;print a comma longa ; .0000070 lda uptime ;seconds beq .0000080 ;zero ; mem_faca s_dword,uptime jsr binasc ;convert seconds &... printstr strgbuf ;print printstr uptsecs ;"second" longa lda uptime ;seconds jsr pplural ;pluralize if necessary ; .0000080 printstr endofstg ;end of string .rept 4 brk .endr ; ;================================================================================ ; ;CONVERT BCD DIGIT TO ASCII DIGITS ; bcdasc pha ;save digit and #m_bcdlo ;extract LSN ora #m_binasc ;change to ASCII xba ;hide units pla ;get digit .rept s_bnybbl ;extract MSN lsr .endr ora #m_binasc ;change to ASCII cmp #m_binasc ;condition .Z rts ; ;================================================================================ ; ;CONVERT BCD DIGIT TO BINARY EQUIVALENT ; bcdbdig php shorta cld ;ensure binary mode xba pha ;save .B entry value xba ;recover input value &... pha ;buffer xba ;save pla ;get input value and #m_bcdhi ;extract 10s lsr ;now *8 pha ;store *8 lsr lsr ;now *2 clc adcs 1 ;*8 stas 1 ;*10 xba ;get original value and #m_bcdlo ;extract units clc adcs 1 ;add 10s xba ;protect result pla ;flush stack pla ;get old .B &... xba ;restore it plp pha ;condition .Z pla rts ; ;=============================================================================== ; ;binasc: CONVERT 32 BIT BINARY INTEGER TO ASCII STRING ; ; —————————————————————————————————————————— ; Preparatory Ops : value to convert in FACA ; ; Returns: Null-terminated string in STRGBUF ; ; Register Returns: All registers used ; ; MPU Flags: NVmxDIZC ; |||||||| ; ||||||++———> undefined ; |||||+—————> entry value ; ||||+——————> 0 ; ||++———————> 1 ; ++—————————> undefined ; ; Notes: 1) FACA is not preserved. FACB is ; used. ; —————————————————————————————————————————— ; binasc jsr clrfacb ;clear sec accum longa shortx sed ;decimal addition ldy #s_dword*s_bibyte ;bits to process ; .0000020 phy ;save bit counter asl faca ;get a bit from... rol faca+s_word ;binary value ldx #0 ;addition index ldy #s_ifac/s_word ;BCD words to process ; .0000030 lda facb,x ;propagate new bit... adc facb,x ;throughout sum &... sta facb,x ;double .rept s_word ;step number index inx .endr dey ;step word counter bne .0000030 ;next ; ply ;get bit counter dey ;a bit's been processed bne .0000020 ;not done ; cld ;binary mode shorta ;8 bits at a time ldx #s_ifac-s_byte ;BCD workspace index ldy #0 ;string assembly index ; binasc01 lda facb,x ;get BCD byte bne .0000010 ;non-zero, must convert ; cpy #0 ;start of string? beq .0000040 ;yes, drop leading zeros ; .0000010 jsr bcdasc ;convert BCD to ASCII bne .0000020 ;both digits significant ; cpy #0 ;start of string? beq .0000030 ;yes, drop leading zero ; .0000020 sta strgbuf,y ;add 10s numeral to buffer iny ; .0000030 xba sta strgbuf,y ;add 1s numeral to buffer iny ; .0000040 dex bpl binasc01 ;next BCD byte ; tyx ;final string index stz strgbuf,x ;terminate string rts ; ;=============================================================================== ; ;brkutim: BREAK DOWN UPTIME TO DAYS, HOURS, MINS & SECS ; ; ———————————————————————————— ; Calculations are as follows: ; ; DAYS = INT(SECS/SPD) ; SECS = SECS-DAYS*SPD ; HOURS = INT(SECS/SPH) ; SECS = SECS-HOURS*SPH ; MINS = INT(SECS/SPM) ; SECS = SECS-MINS*SPM ; ; where: ; ; SPD = seconds per day ; SPH = seconds per hour ; SPM = seconds per minute ; ———————————————————————————— ; ; brkutim mem_faca s_dword,uptime ;SECS to pri accum mem_facb s_dword,spd ;secs-per-day to sec accum jsr idiv ;integer division faca_mem s_dword,udays ;pri accum to DAYS ; jsr imul ;DAYS*SPD jsr facafacb ;DAYS*SPD to sec accum mem_faca s_dword,uptime jsr isub ;integer subtraction faca_mem s_dword,uptime ;pri accum to SECS ; mem_facb s_dword,sph ;secs-per-hour to sec accum jsr idiv faca_mem s_dword,uhours ;pri accum to HOURS ; jsr imul ;HOURS*SPH jsr facafacb mem_faca s_dword,uptime jsr isub faca_mem s_dword,uptime ; mem_facb s_dword,spm ;secs-per-minute to sec accum jsr idiv faca_mem s_dword,umins ;pri accum to MINS ; jsr imul ;MINS*SPM jsr facafacb mem_faca s_dword,uptime jsr isub faca_mem s_dword,uptime shortr rts ; ;================================================================================ ; ;ADD CHARACTERS TO STRING ; addtostr jsr bcdasc ;change BCD to ASCII sta strgbuf,x ;add 10s to buffer inx xba bra insrtCOM ;add 1s to buffer ; ;=============================================================================== ; ;INSERT COLON IN DATE STRING ; insrtcol lda #':' bra insrtCOM ; ;=============================================================================== ; ;INSERT BLANK IN DATE STRING ; insrtblk lda #' ' ; insrtCOM sta strgbuf,x inx rts ; ;================================================================================ ; ;CONVERT DAY or MONTH & ADD TO STRING BUFFER ; ; —————————————————————————————————————————————— ; Preparatory Ops : .A: 16 bit table pointer ; .X: 8 bit buffer index ; .Y: 8 bit day or month index ; ; Register Returns: .A: used ; .B: used ; .X: new buffer index ; .Y: used ; ; MPU Flags: NVmxDIZC ; |||||||| ; |||||||+———> undefined ; ||||||+————> undefined ; |||||+—————> undefined ; ||||+——————> undefined ; |||+———————> undefined ; ||+————————> undefined ; |+—————————> undefined ; +——————————> undefined ; —————————————————————————————————————————————— ; cvtdm pha ;save table pointer ; ;——————————————————————————————— .table =1 ;——————————————————————————————— ; shortr ;8 bit registers tya ;day or month index asl ;now table offset tay ldasi .table ;get code LSB sta miscwork ;copy to work area iny ldasi .table ;get code MSB sta miscwork+s_byte ;copy to work area ldy #n_asc ;chars to be generated ; .0000010 jsr unpack ;decode a char &... cpy #n_asc ;1st char? beq .0000020 ;no, skip case conversion ; ora #a_uctolc ;convert to lower case ; .0000020 jsr insrtCOM ;insert into buffer dey bne .0000010 ;next ; pla ;clean up... pla ;stack rts ; ;================================================================================ ; ;pplural: PLURALIZE TIME UNIT IF NECESSARY ; ; —————————————————————————————————————————————— ; Preparatory Ops : .C: 16 value to test ; ; Register Returns: .A: used ; .B: used ; .X: used ; .Y: used ; ; MPU Flags: NVmxDIZC ; |||||||| ; |||||||+———> undefined ; ||||||+————> undefined ; |||||+—————> entry value ; ||||+——————> undefined ; |||+———————> 1 ; ||+————————> 1 ; |+—————————> undefined ; +——————————> undefined ; —————————————————————————————————————————————— ; pplural longa cmpw 1 ;1 unit? shortr beq .0000010 ;zero or multiple units ; lda #'s' jmp bsouta ;"units" ; .0000010 rts ; ;================================================================================ ; ;PRINT A COMMA & BLANK ; pcomma ldx #<comma ;", " ldy #>comma jmp sprint ; ;================================================================================ ; ;UNPACK DAY or MONTH CODE ; ; ————————————————————————————————————————————— ; MISCWORK = packed code in little-endian order ; ————————————————————————————————————————————— ; .A = unpacked character ; .X = entry value ; .Y = entry value ; —————————————————————————————————————————————————————————————————————— ; Each call to this subroutine decodes a character & returns it as lower ; case ASCII in the range $61 - $6A. ; ; The packed code consists of 2 bytes, into which bits 0-4 of an ASCII ; character have been shifted 5 times. The result is that 3 characters ; are compressed into 2 bytes. ; —————————————————————————————————————————————————————————————————————— ; unpack phy ;protect counter lda #0 ;starting character ldy #n_shfdcd ;iterations to unpack ; .0000010 asl miscwork ;left shifts will extract... rol miscwork+s_byte ;the bits needed to form... rol ;a UC character dey bne .0000010 ; clc adc #a_qmark ;convert to UC ASCII ply ;restore counter rts ; .include "lib\math\clrfac.65s" .include "lib\math\clrovrfl.65s" .include "lib\math\facafacb.65s" .include "lib\math\ifacamem.65s" .include "lib\math\imemfaca.65s" .include "lib\math\imemfacb.65s" .include "lib\math\idiv.65s" .include "lib\math\imul.65s" .include "lib\math\isub.65s" ;=============================================================================== ; ;STATIC DATA ; spd dwordadr _secday_ ;seconds per day sph dwordadr _sechr_ ;seconds per hour spm dwordadr _secmin_ ;seconds per minute ; dowtab .byte $00,$00 ;invalid .byte $9e,$a5 ;Sun .byte $1e,$74 ;Mon .byte $8c,$ad ;Tue .byte $8a,$c1 ;Wed .byte $6c,$aa ;Thu .byte $d4,$3c ;Fri .byte $aa,$a0 ;Sat ; montab .byte $00,$00 ;invalid .byte $9e,$58 ;Jan .byte $86,$39 ;Feb .byte $a6,$70 ;Mar .byte $66,$14 ;Apr .byte $b4,$70 ;May .byte $9e,$5d ;Jun .byte $9a,$5d ;Jul .byte $90,$15 ;Aug .byte $a2,$a1 ;Sep .byte $2a,$81 ;Oct .byte $2e,$7c ;Nov .byte $88,$29 ;Dec ; ;=============================================================================== ; ;TEXT STRINGS ; preamble .byte a_cr bf .byte " ",0 ; timezone .byte "UTC",0 ; uptimea .byte " " lf .byte " Up ",0 ; uptdays .byte " day",0 ; upthours .byte " hour",0 ; uptmins .byte " minute",0 ; uptsecs .byte " second",0 ; comma .byte ", ",0 ; endofstg .byte " " er .byte 0 ; ;=============================================================================== ; ;STORAGE ; uptime =* ;uptime from BIOS *=*+s_utcnt udays =* ;uptime days *=*+s_dword uhours =* ;uptime hours *=*+s_dword umins =* ;uptime minutes *=*+s_dword miscwork =* ;scratch work area *=*+s_word rtcbuf =* ;date & time buffer... ; seconds =rtcbuf+rtcsec ;seconds minutes =rtcbuf+rtcmin ;minutes hours =rtcbuf+rtchrs ;hours dow =rtcbuf+rtcdow ;day of week date =rtcbuf+rtcdat ;date month =rtcbuf+rtcmon ;month yearlo =rtcbuf+rtcylo ;year LSB yearhi =rtcbuf+rtcyhi ;year MSB *=*+s_rtcbuf ; strgbuf =* ;string assembly buffer ; ;=============================================================================== .end The above example also illustrates a style of code entry that you may find useful. Be sure to include the very first line in all programs you write in the Kowalski simulator. It tells the simulator that all non-quoted text is to be treated the same regardless of case, and that 65C02 instructions are legal (change 65C02 to 6502 for accurate NMOS simulation).
See below for a list of the simulator's pseudo-ops.Code: KOWALSKI SIMULATOR ASSEMBLER DIRECTIVES — BigDumbDinosaur 2012/07/01
IO_AREA ;define console I/O area address (no leading dot in IO_AREA) .ASCII .BYTE .DB ;generate static data, such as strings, tables, etc. .ASCIS ;generate character string w/bit 7 of last byte set .DBYTE .DD ;assemble big-endian word .DCB ;equivalent to * = * + N, where N is arg to .DCB,... ;w/optional initialization pattern, e.g., .DCB 10,$FF, which will ;reserve 10 bytes & fill them with $FF .DS .RS ;equivalent to * = * + N, where N is arg to .DS or .RS .DW .WORD ;assemble little-endian word .ELSE ;conditional assembly directive .END ;mark end of source file, optional .ENDIF ;mark end of conditional assembly .ENDM ;mark end of macro definition .ENDR ;mark end of repeated text .ERROR ;emit an error message & halt assembly,... ;e.g., .ERROR "!!! operand out of range !!!" .EXITM ;halt macro expansion .IF ;start conditional assembly .INCLUDE ;insert contents of named source file... ;e.g., .INCLUDE "include\atomic.65s" .IO_WND ;define console I/O window size (cols, rows) .MACRO ;mark start of macro definition, w/optional comma-separated parameters .OPT ;set global assembly options .ORG ;set start of assembly address, same as * = <addr> .PARAMTYPE ;determine macro parameter type: 1 = numeric, 2 = string,... ;.IF .PARAMTYPE(.op) == 1 .REF ;determine if label/symbol was defined,... ;e.g., .IF .REF(ABC) evaluates true if... ;ABC has been defined; logic can be reversed... ;with !.REF (ABC) .REPEAT .REPT ;repeat following text N times .ROM_AREA ;set simulator's write-protected address range .SET ;(re)define variable value, e.g., .SET .= .START ;set simulator start of execution address .STR .STRING ;generate text string, 1st byte is length, 255 bytes maximum .STRLEN ;determine macro parameter string length
.IF evaluations can use the following binary operators:
== is equal to != is not equal to > is greater than < is less than
.IF .op means "if .op is non-zero".
_________________ x86? We ain't got no x86. We don't NEED no stinking x86!
Last edited by BigDumbDinosaur on Thu Aug 08, 2013 9:17 pm, edited 1 time in total.
