and here are the details of how to wire the IDE disk to the AA connector on a SYM-1.
This was done by my associate on the Symbiosys project cjb, seen also on this forum with his parallel port data transfer system for connection the SYM to the lpt port on a linux machine, he also wrote the IDE device sector R/W driver in Symbiosys. So this is where the whole thing started a little less than a year ago now.
No additional hardware is necessary for the IDE interface.
Connecting a 6522 VIA to an ATA IDE bus
Designed for a Synertek SYM-1, and its AA Expansion connector.
PORTB0-7 maps to DATA0-7 on IDE
PORTA0 = ADDR0
PORTA1 = ADDR1
PORTA2 = ADDR2
PORTA3 = /RD
PORTA4 = /WR
PORTA5 = /CS0
AA-pin AAname* IDE
1 GND 2,19,22,24,26,30,40,Power-
3 A1 15 (DATA1)
7 B5 37 (/CS0)
8 B3 25 (/RD)
9 B1 33 (ADDR1)
10 A7 3 (DATA7)
11 A5 7 (DATA5)
12 A3 11 (DATA3)
13 RESET 1 (jumpered)
A Vcc Power+
C A2 13 (DATA2)
D A0 17 (DATA0)
J B4 23 (/WR)
K B2 36 (ADDR2)
L B0 35 (ADDR0)
M A6 5 (DATA6)
N A4 9 (DATA4)
27 (IORDY) - tie low 10kR
29 (DMACK) - tie high 1kR
38 (/CS1) - tie high 1kR
39 (DASP) - LED+180R to Vcc
*: as I discovered when debugging the code, what
the SYM1 calls PORT A on its AA expansion bus, is
actually PORTB to the 6522. The pinout is no different,
since I ended up changing the code to suit.
Chris Baird,, <cjb@brushtail.apana.org.au> Feb2010.
Corrected IORDY and DASP: 2010-Jul-31
