It is currently Fri Nov 22, 2024 11:53 pm
PostPosted: Fri Dec 03, 2010 8:35 am
Hallo allemaal,
I don't know who copied my test program for the 6502 but I found a huge bug in it. Please have a look at the following example:
          ldx  #0
L039i
          bne  L039i   ; error, ->
L039j
          bmi  L039j   ; error, ->
It looks as if the program tests if X is loaded with the value zero. Coincidentally I saw an error in the core: in this specific case X would never be loaded with the read value. So I wondered how RB65 could pass the test ???
Studying the above piece of code and the core I realised that the ALU tested the loaded value, not what was stored in X. To test the actual value in X I have to add the instruction "CPX #0". I did and now the program ended with an error.
After correcting the error, the program ended well. But knowing now that my program certainly isn't as good as I thought, I wonder if my VHDL is OK. Back to the drawing board..... :(
    ___
   / __|__
  / /  |_/     Groetjes, Ruud
  \ \__|_\
   \___|       URL: www.baltissen.org
PostPosted: Fri Dec 03, 2010 9:22 am
I'm confused: that doesn't look wrong to me. Did you mean
  LDX $0
which loads from zero page, or did you really mean
  LDX #0
which loads the constant value zero, and does indeed update the flags?
PostPosted: Fri Dec 03, 2010 1:09 pm
.. or did you really mean
  LDX #0
In reality it was the "LDX $nn,Y" instruction that went wrong. I just used the immediate instruction as example.
During LDx instructions the ALU is loaded with the read value as well because I need to (re)set the Zero and Negative flag. The ALU saw a Zero, set the Zero flag etc. and the branches were not taken (=no error in this case). But in this particular case X wasn't loaded with the value. I only found out that there was an error by adding the CPX instruction.
The core of the message was that just checking the Flags is not sufficient some times.
    ___
   / __|__
  \ \__|_\
PostPosted: Fri Dec 03, 2010 2:29 pm
Ah, I see! Sorry, I could have read the post more carefully.
It's an interesting aspect of test programs - to some extent you're operating with a model of what might go wrong. Most 6502 tests wouldn't bother to check that a LDX left Y unchanged, say, or that a TXA hadn't ORed in some other register. But these bugs could arise in a homebrew.
(And then there's the extra problem of self checking code, when you wouldn't want one bug to mask out another.)
