It is currently Sat Nov 23, 2024 5:25 am
PostPosted: Fri Dec 14, 2012 5:38 pm
I'm working on re-creating a bit of code in 6502 assembly for a large project I'm working on. This one little line has sort of stumped me.
steep := abs(y1 - y0) > abs(x1 - x0)
I'm sure you can see what is supposed to happen here. The trouble is the need for absolutes. Now obviously I can create a routine that would have several CMP instructions to figure out which variable is larger and then reverse them before performing the subtraction. But it just seems to be there must be an easier way to accomplish this.
First of all, none of the variables will be larger than 255 so I don't need to deal with any 16-bit numbers. All I really need is to find the quickest way to determine the difference between y1 and y0, regardless of which one is larger.
Any suggestions?
PostPosted: Fri Dec 14, 2012 6:21 pm
As subtract and compare are pretty much the same thing, I'd suggest
Subtract
Check for negative
Conditionally negate
Note that subtracting two 8 bit unsigned numbers gives you a 9 bit result, so the carry bit would act as your sign bit.
Note your abs result is in the range 0 to 255. I'm not sure if a single byte result just falls out. When you do the comparison, you again get into 9 bit territory, but as you only want the sign, that's OK.
PostPosted: Fri Dec 14, 2012 6:34 pm
BTW, Welcome!
I just hacked some code and it seems to work.
As I have a thing about not doing people's homework for them, I'll show you the code if you can show that this isn't like that. Sorry for the inconvenience!
PostPosted: Fri Dec 14, 2012 6:43 pm
BTW, Welcome!
I'm 37 years old and haven't been to school since I was 18.. Not sure how to "prove" that to you. I'm a hobby programmer on the C64. Come to think of it, I'd be shocked to learn that any 6502 code is still being taught in school since as far as I know, nobody uses it anymore in current products.
I'm actually trying to code my own line-drawing routine for a game I'm working on using a modified form of "Bresenham's line algorithm" I have the routine working already but it only works when drawing from left to right.
PostPosted: Fri Dec 14, 2012 6:46 pm
I'm convinced! Here's what I have for 'abs':
$0603    a5 01     LDA $01
$0605    38        SEC
$0606    e5 02     SBC $02
$0608    b0 04     BCS $060e
$060a    49 ff     EOR #$ff
$060c    69 01     ADC #$01
$060e    60        RTS
PostPosted: Fri Dec 14, 2012 6:48 pm
If you're doing Bresenham, you'll probably also need to know if y1 > y0 and if x1 > x0. Maybe you can combine that with the 'steep' calculation.
PostPosted: Fri Dec 14, 2012 6:57 pm
Also, the V flag (overflow) tells if the sign of the result is wrong, like if you subtract a positive number from a negative one and the answer is so negative that the high bit (sign bit) is again clear. There's an article on the V flag at http://6502.org/tutorials/vflag.html
You might be pleasantly surprised to know that yes, it is being taught in schools, and that the 6502 is being produced in volumes of hundreds of millions of units per year today, although they're not very visible because the products are things like engine controls instead of desktop computers. The fastest ones are running over 200 MHz. This is according to the IP owner, Western Design Center, whose main business is licensing IP to manufacturers, rather than selling hardware. It is also my understanding that the 6502 is the only processor approved for certain life-support equipment, including human-body-implantable.
PostPosted: Fri Dec 14, 2012 7:06 pm
(Hmm, in this case I think V is no use, because it relates to signed 8-bit inputs. I took it from the problem description that we have unsigned 8-bit inputs)
(Indeed, I've seen two 6502-related elements to college courses!)
PostPosted: Fri Dec 14, 2012 10:21 pm
You might be pleasantly surprised to know that yes, it is being taught in schools...
6502 assembly language is an excellent model for teaching purposes. The nearly orthogonal instruction set is one of the cleanest in existence and is surprisingly complete for a such a low-cost device (when introduced, the 6502 was about one-tenth the cost of the Motorola 6800). The 65C816 instruction set is even more powerful than its eight bit brethren, with a set of very useful stack instructions.
That the 65C02 and 65C816 are both static core devices was the result of WDC seeking medical certification for the devices. One of the members of our large scale model railroad club has an implanted defibrillator designed around the W65C02S. He's on a list awaiting a heart transplant and that defib unit has rescued him several times when his ticker stopped ticking. I was...er...shocked to learn all this. :lol:
PostPosted: Wed Dec 19, 2012 3:18 am
The N flag XOR the V flag gives you a signed comparison (less than) result, as described here:
http://6502.org/tutorials/compare_beyond.html
PostPosted: Wed Dec 19, 2012 10:16 am
If you're doing Bresenham Line algorithms, I suggest you download the Acorn Atom MOS ROM disassembly from the net. (At this address http://www.atomclub.nl/atom_handleidingen/splitatom/F000.txt) This fully-annotated disassembly include a set of line algorithms optimised for speed that are still easy to understand. Since the Atom's maximum screen resolution was 256x192, these routines work in only 8-bits as you want.
These listings are in Atom assembler format rather than standard 6502 format and so use # to indicate a hex number and @ to indicate immediate addressing.
EDIT - The line plot routine starts at address F5B5
Shift to the left,
Shift to the right,
Mask in, Mask Out,
BYTE! BYTE! BYTE!
