It is currently Fri Nov 22, 2024 4:17 am
 Post subject: Making use of BRK
PostPosted: Sat Dec 06, 2008 3:14 am
BRK is a two-byte instruction, but doesn't do anything with the second byte. Can anyone give me some code that will let me find out this second byte from inside the BRK handler, so I can do something with it? I want to use it as a function number for calling ROM routines, eg. BRK $03 could mean 'print the character in A'.
PostPosted: Sat Dec 06, 2008 4:27 am
For 8-bit architectures:
brkHandler:
  ; PRECONDITIONS:
  ;   6502 or 65C02 or 65816 operating in emulation mode
  ;   Stack image as follows:
  ;     (open)  <-- S points here
  ;     Y-saved
  ;     X-saved
  ;     A-saved
  ;     P-saved
  ;     PCL-saved
  ;     PCH-saved
  ;   PC points to byte _after_ the BRK operand byte.
  ;   Direct- or zero-page locations PCL and PCH adjacent each other to form a pointer
  ;   BRK operand specifies PCL-1 of a ROM jump table placed at EPV_ADDRESS.
  ;   Invoked procedure does NOT use RTI to return, but jumps to RETURN instead.
  tsx
  lda $0105,x
  sec
  sbc #1
  sta pcl
  lda $0106,x
  sbc #0
  sta pch
  lda #>EPV_ADDRESS
  pha
  txa
  tay
  lda (pcl),y
  pha
  rts
RETURN:
  pla
  tay
  pla
  tax
  pla
  rti
EPV_ADDRESS:
  jmp console_out
  jmp console_in
  jmp open_file
  ...etc...
For 65816-native operation:
brkHandler:
  ; PRECONDITIONS:
  ;   65816 operating in 16-bit native mode
  ;     YL-saved
  ;     YH-saved
  ;     XL-saved
  ;     XH-saved
  ;     AL-saved
  ;     AH-saved
  ;     P-saved
  ;     PCL-saved
  ;     PCH-saved
  ;     K-saved
  ;   BRK operand specifies byte offset into ROM jump table placed at EPV.
  phd
  tsc
  tcd
  dec 10
  lda [10]
  and #$00FF
  tax
  inc 10
  jmp (EPV,x)
RETURN:
  pld
  ply
  plx
  pla
  rti
EPV:
  .word  console_out
  .word  console_in
  .word  open_file
  ..etc..
In all honesty, though, it's much faster to simply JSR directly to the appropriate ROM JMP table instruction (for 6502) or to LDX the byte offset and JSR a common entry point into ROM.
I like how CP/M handles the entry point problem: CALL 5 always works to invoke a DOS API function, because locations $0005..$0007 are preset to a JP directly into an undisclosed OS dispatcher routine at the time a program is launched. An OS for the 65816 can do the same thing: place a JMP or JML instruction at location $00..$03; the extra indirection adds only 3 cycles to the call, not including the JMP (abs,X) inside the OS itself. It'll be much faster than using BRK.
