It is currently Thu Nov 21, 2024 8:24 pm
 Post subject: commodore 64 basic v2
PostPosted: Wed Nov 03, 2010 7:22 pm
looking around i didn't find any kind of basic re-implementation using hi level languages or, better, actual languages.
so i start a post dinner lecture of the c64 rom disasm, for example this http://myoperatingsystem.org/Commodore/Annotated_ROM_Listings.htm
i was trying to figure out how much time it will costs to rewrite, for example in javascript or native c, the original rom without changing it too much.
(yes, i know that already exist a "porting" (see http://www.pagetable.com/?p=48) but that's not what i mean.
ehm, not so easy!
some topics:
* lot of float math...slow
* lot of jsr to jump to jsr to 2-3 instruct code...again slow but also strange
* not so much kernel subs independent code: forth is very clean about it
i'm not saying that it's easy to write a 8k basic in '80 (in that period i also write lot of spaghetti code) but now i'm really curious about the commodore basic genesis/porting and if someone can give me more info for realizing a good porting without becoming crazy.
btw:
i'm doing a bit of work also in js 6502 code, that forum seems death, so if someone is interested...
PostPosted: Thu Nov 04, 2010 3:38 am
Deeply-nested call-graphs (JSRs to JSRs to JSRs, etc) are a hallmark of writing software in a well-factored manner. You start out with basic primitives written in a stream of instructions, and you then can JSR to them as though they were a higher-level assembly instruction.
If you look at most high-level compiler output of the era, you'll notice that "subroutine-threaded code" like this was the norm, not the exception. Note that Forth is singularly famous for this style of code generation, although the technique technically predates Forth.
PostPosted: Thu Nov 04, 2010 4:40 pm
thank you for your reply, let me try to explain with some code.
...but anyway if basic was written with another high level language, i'm really curious about it!!!
here a piece of code, quite near the warm boot because it is used during the print of the banner using this core routine
; print string form AY
 AB1E   20 87 B4   JSR $B487
 ; print string from $22/$23
 AB21   20 A6 B6   JSR $B6A6
 AB24   AA         TAX
 AB25   A0 00      LDY #$00
 AB27   E8         INX
 AB28   CA         DEX
 AB29   F0 BC      BEQ $AAE7
 AB2B   B1 22      LDA ($22),Y
 AB2D   20 47 AB   JSR $AB47
 AB30   C8         INY
 AB31   C9 0D      CMP #$0D
 AB33   D0 F3      BNE $AB28
 AB35   20 E5 AA   JSR $AAE5
 AB38   4C 28 AB   JMP $AB28
look at jsr $AB47, that more or less is output one char.
it jump at:
; print character on CMD output file
 AB3B   A5 13      LDA $13
 AB3D   F0 03      BEQ $AB42
 AB3F   A9 20      LDA #$20   ; space
 AB41   .BY $2C
 AB42   A9 1D      LDA #$1D   ; csr right
 AB44   .BY $2C
 AB45   A9 3F      LDA #$3F   ; question mark
 AB47   20 0C E1   JSR $E10C
 AB4A   29 FF      AND #$FF
 AB4C   60         RTS
this is good, a little reuse of and #$ff
but now the jsr $e10c (kernel rom)
 E10C   20 D2 FF   JSR $FFD2
and..
FFD2   6C 26 03   JMP ($0326)   ; (F1CA) output char on current device
again: i dont wanna say that it's easy (better it was easy) to write code in 8k space, but now i can understand why a PRINT was so slow!
anyway i'd love to find out if there is a project for reimplement the original asm code in a new highlevel language, that's why i'm playing rom digging.
PostPosted: Thu Nov 04, 2010 9:06 pm
You would find the CHROUT routine at $FFD2 at all Commodore machines. This meant that various ML programs could run at various machines with different hardware. A large part of the $FF page was filled with these kind of vectors.
The indirect jump enabled you to redirect a vector to your own routines.
First CP/M and then IBM used these tricks as well. And it worked well. Until some programmers started to cut edges to speed up things. And then owners of some MS-DOS computers found out that some programs didn't run on their machines anymore: the now famous IBM incompatibility.
First after written the above I realise that I forgot an other, maybe more important argument. The JMP $FFD2 isn't slow at all; the interpretation of the Basic command PRINT is!
    ___
   / __|__
  / /  |_/     Groetjes, Ruud
  \ \__|_\
   \___|       URL: www.baltissen.org
PostPosted: Fri Nov 05, 2010 3:53 pm
I think I understand now. The indirect jump for CHROUT is used to implement redirected I/O.
To produce a hard-copy listing of a BASIC program, for example, you'd use the CMD command to cause output to route to device 4 (e.g., OPEN 4,4:CMD 4:LIST:CLOSE 4). It's like file redirection logic in Unix or Windows.
I once wrote a quick-n-dirty hack that patched into these routines to provide a hierarchical directory system on which device drivers and filesystems could be mounted. Without having that extra layer of indirection, such a feature would have required I reprogrammed the entire KERNAL ROM, which is clearly not feasible for anyone else who might want to use the code.
