It is currently Fri Nov 22, 2024 12:19 pm
PostPosted: Mon Apr 11, 2011 9:37 am
Name mux ;
PartNo 00 ;
Date 11/04/2011 ;
Revision 01 ;
Designer Engineer ;
Company University of Tulsa ;
Assembly None ;
Location ;
Device V2500C ;
PIN 1=clk ; /* */
PIN 3=x ; /* */
PIN 4=r1 ; /* */
PIN 5=r2 ; /* */
PIN 6=r3 ; /* */
PIN 7=r4 ; /* */
PIN 9=z ; /* */
PIN 12=q0 ; /* */
PIN 13=q1 ; /* */
PIN 14=q2 ; /* */
PIN 15=q3 ; /* */
PIN 16=q4 ; /* */
PIN 24=q5 ; /* */
PIN 25=q6 ; /* */
PIN 26=q7 ; /* */
/*mux*/
z=!q6&!q7&r1 # !q6&q7&r2 # q6&!q7&r3 # q6&q7&r4;
/*shift Register */
q0.d=x;
q1.d=q0;
q2.d=q1;
q3.d=q2;
q4.d=q3;
q5.d=q4;
q6.d=q5;
q7.d=q6;
on my program when i change q6 and q7 i only get the vlaues of R1 on my out put Z, can any one please help me with it ???? :( :( :(
juda
PostPosted: Mon Apr 11, 2011 1:02 pm
I have not used that device, but have used WinCUPL.
So, if I read this right, serial data is being shifted in on the x input using the clk input as the shift clock. Bits move from Q0 to Q7.
The z output is Q6 AND'ed with Q7, using R1 thru R4 to select all combinations of inverted/non-inverted Q6's and Q7's.
Only one of R1 thru R4 should be held high at any given time.
So, in order to test this, you need to clock data into x to fill Q6 and Q7. (8 clocks total)
Then, stop clocking and sequentially set R1 thru R4 high and read the results on z.
Here's one example:
With Q6=0 and Q7=1, you should see this:
R1 z=0
R2 z=1
R3 z=0
R4 z=0
Does this help?
Is this what you are doing, or are you doing it differently?
PostPosted: Tue Apr 12, 2011 5:01 am
jude00 wrote:
/*mux*/
Adding some whitespace here and there helps old eyes like mine read your code, e.g.:
/* mux */
z = !q6 & !q7 & r1 # !q6 & q7 & r2 # q6 & !q7 & r3 # q6 & q7 & r4;
It may be necessary to parenthesize expressions, e.g.:
/* mux */
z = (!q6 & !q7 & r1) # (!q6 & q7 & r2) # (q6 & !q7 & r3) # (q6 & q7 & r4);
You should check WinCUPL's evaluation precedence rules to make sure the compiler is seeing your logic the way you want it.
PostPosted: Tue Apr 19, 2011 7:18 am
thanks
juda
