It is currently Sun Sep 22, 2024 2:33 am
PostPosted: Tue Jul 31, 2012 4:34 am
I need a routine to isolate the high bit of a byte.
so eg 80-FF should return 80, 40-7F should return 40, etc
Even 32 bytes for nibble wise LUTs seems excessive,
but I wouldn't rule it out if it there was enough of a
speed advantage.
this is the best I've come up with
HIBIT
 lda num
 and #$F0
 bne SKIP1
 eor num
SKIP1
 sta temp
 and #$CC
 bne SKIP2
 eor temp
SKIP2
 sta temp
 and #$AA
 bne SKIP3
 eor temp
SKIP3
 rts
Any better ideas?
PostPosted: Tue Jul 31, 2012 5:57 am
Warren's "Hacker's Delight" suggests
x=x | (x >> 1)
x=x | (x >> 2)
x=x | (x >> 4)
which would be
HIBIT
 lda num
 lsr
 ora num
 sta num
 lsr
 lsr
 ora num
 sta num
 lsr
 lsr
 lsr
 lsr
 ora num
I haven't fully tested this.
I thought I might find something in HAKMEM but no.
Edit: oops, that only makes a mask. To reduce to top bit set we must also do
sec
adc #0
ror
PostPosted: Tue Jul 31, 2012 6:22 am
How about:
HIBIT: LDA  #0
       SEC
       BEGIN
          ROR  A
          ASL  INPUT
       UNTIL_C_SET
or the same thing, non-structured:
HIBIT: LDA  #0
       SEC
 hb1:  ROR  A
       ASL  INPUT
       BCC  hb1
PostPosted: Tue Jul 31, 2012 6:25 am
Nice work, Bogax. It's a delightfully tidy algorithm -- not to be improved upon! (at least not by me).
The implementation can be tightened up a bit, though. A few of the instructions are eligible for substitution on a one-for-one basis, as follows:
HIBIT
 lda num
 and #$F0
 bne SKIP1
 lda num        ;was: eor num
SKIP1
 sta temp
 and #$CC
 bne SKIP2
 lda temp       ;was: eor temp
SKIP2
 sta temp
 and #$AA
 bne SKIP3
SKIP3
 rts
Using lda as a substitute for eor may seem odd but it's acceptable simply because A is known to be zero, owing to the immediately preceding bne instruction. (The substitution improves readability, IMO. But that's not the primary benefit.)
Now the value temp has nothing happening to it except simple move operations. It becomes feasible to keep the value in a register rather than a zero-page location (see below). This saves 4 bytes and up to 4 cycles.
HIBIT
 lda num
 and #$F0
 bne SKIP1
SKIP1
 tay              ;was: sta temp
 and #$CC
 bne SKIP2
 tya              ;was: lda temp    ;was: eor temp
SKIP2
 tay              ;was: sta temp
 and #$AA
 bne SKIP3
SKIP3
 rts
And I haven't fully wrapped my brain around this! Good one, Ed! But I won't be able to give it full concentration until tomorrow. It's past bedtime on this side of the pond, and I'm sleepy (whereas I'm guessing you just got up!)
cheers
PostPosted: Tue Jul 31, 2012 5:31 pm
Agreed, Bogax' code is very nice - and mine was wrong (is now updated)
PostPosted: Fri Oct 23, 2015 3:55 pm
Resurrecting an old thread, because it's the only mention of Hacker's Delight I could find. And I wanted to add a link to a related site, called Bit Twiddling, as recently noted over at the HP Museum:
https://graphics.stanford.edu/~seander/bithacks.html
via
http://www.hpmuseum.org/forum/thread-49 ... 44284.html
which mentions some other books which might be of interest.
PostPosted: Sat Oct 24, 2015 7:27 am
In addition to Dr Jefyll's saving with using TAY and TYA, you can shave 1 cycle off worse case execution in the first part of the routine.
Change this:
 lda num
 and #$F0
 bne SKIP1
 eor num
SKIP1
To this:
 lda num
 cmp #$10
 bcc SKIP1
 and #$F0
SKIP1
PostPosted: Sun Oct 25, 2015 2:54 pm
How about removing rightmost bits until you reach the last. NUM must be non-zero at the start and will contain the last bit at the end.
 lda NUM
Loop:
 dec a
 and NUM
 beq Done
 sta NUM
 bra Loop
Done:
Utterly untested
Andrew Jacobs
PostPosted: Sun Oct 25, 2015 3:10 pm
 lda NUM
Loop:
 dec a
 and NUM
 beq Done
 sta NUM
 bra Loop
Done:
Utterly untested
I see no requirement for NUM being non-zero here. If NUM is zero on entry, it will also be so on exit.
PostPosted: Sun Oct 25, 2015 3:22 pm
Agreed. I was playing safe.
Slightly smaller if you shuffle the instructions and put the initial value in A. Result still in NUM.
Loop:
 sta NUM
 dec A
 and NUM
 bne Loop
Andrew Jacobs
PostPosted: Sun Oct 25, 2015 4:32 pm
Nice, if memory economy is the goal. Of course the other potential priority is speed, which, judging from the lead post, is what Bogax was interested in. His algorithm has a very fast worst-case execution because there's no looping.
Good spot, Omegamatrix -- I missed that! The 2nd instruction tests the high 4 bits, but the test needn't be destructive as in my previous version. CMP and BIT are both capable of doing the test while at the same time preserving the contents of A. I've adopted your suggestion (below) but I prefer to use BIT since it's just as fast as CMP and IMO is slightly more readable.
HIBIT: ;previous version
 lda num
 and #$F0 ; <- destructive test
 bne SKIP1
 lda num
; [etc ]
HIBIT: ;improved version
 lda num
 bit #$F0 ; <- non-destructive test
 beq SKIP1
 and #$F0
SKIP1:   ;if any of bits 7,6,5,4 is set then bits 3,2,1,0 have now been cleared
 tay
 and #$CC
 bne SKIP2
 tya
SKIP2:   ;if any of bits 7,6,3,2 is set then bits 5,4,1,0 have now been cleared
 tay
 and #$AA
 bne SKIP3
 tya
SKIP3:   ;if any of bits 7,5,3,1 is set then bits 6,4,2,0 have now been cleared
 rts
PostPosted: Sun Oct 25, 2015 6:29 pm
I have only programmed for the 6502, and there's no BIT #IMM instruction for it. Looking at the 65C02 and 65816 I see there is. :)
cron
