11) Relative
This mode is used with Branch-on-Condition instructions. It is probably
the mode you will use most often. A 1 byte value is added to the program
counter, and the program continues execution from that address. The 1
byte number is treated as a signed number - i.e. if bit 7 is 1, the number
given byt bits 0-6 is negative; if bit 7 is 0, the number is positive. This
enables a branch displacement of up to 127 bytes in either direction.
eg bit no. 7 6 5 4 3 2 1 0 signed value unsigned value
value 1 0 1 0 0 1 1 1 -39 $A7
value 0 0 1 0 0 1 1 1 +39 $27
I took this from a reference document, but I wanted to check whether it was correct.
I was under the impression that the 6502 used 2's complement numbers, even in branches.
