It is currently Fri Nov 22, 2024 11:35 am
PostPosted: Tue Oct 28, 2008 9:48 pm
how would you write a machine language program that adds the numbers 1,2,3,4,5 and 6 together and place the sum into location 0280h?
PostPosted: Tue Oct 28, 2008 10:06 pm
Should I assume this is homework? How much help will the teacher approve of? There are several ways you could do it. Without just giving it away, I might suggest starting with 0 in A and storing your number in address 280. Every time you add the contents of address 280 to A you decrement address 280 until it reaches 0. When that's done looping, store A in 280.
 Post subject: machine language program
PostPosted: Tue Oct 28, 2008 10:34 pm
Thank you for the quick reply. I am the teacher and my grandson is the student who is home schooled. We are a little confused about his computer class problem and any help would be appreciated.
Thanks,
Carol
PostPosted: Tue Oct 28, 2008 11:28 pm
Start with your number in 280H. It must be in the range of 1 to 22 decimal (1 to 16H) to avoid errors. Then:
        LDA   #0
        CLC
loop:   ADC   280H
        DEC   280H
        BNE   loop
        STA   280H
PostPosted: Tue Oct 28, 2008 11:37 pm
Thanks soooooo much
Carol
