It is currently Fri Sep 20, 2024 5:51 pm
 Post subject: Need a table help code
PostPosted: Sat Apr 19, 2008 2:17 am
FINALLY back into the pinball program after 2 years. Main jobs got me too busy as heck, got laid off again a month ago, bleah. Had ntoes and new ideas.
One was a text display table which has 128 entries of 8 bytes each. I can create the proper base table address but I cannot pick up the data as needed. Help!
DisplayShapeTable            = $FC00 ; shapes here
DisplayTextTable            = $F800 ; text data here from $f800-fbff
DisplayTextTablePointerLow         = $20   ; The calculated pointers to the text table
DisplayTextTablePointerHigh         = $21
DisplayTextString            = $22   ; User sets this pointer to the DisplayTexttable
; The above are the memory locations referenced:
MessageCenterMessageInit
; To use, load DisplayTextString with the string number to show.
; Then load MessageCenterstatusFlag with #$01
; These point to the base address in the table
; DisplayTextTablePointerLow   = $20
; DisplayTextTablePointerHigh   = $21
; These are loaded from the table:
; MessageCenter1
; MessageCenter2
; MessageCenter3
; MessageCenter4
; MessageCenter5
; MessageCenter6
; MessageCenterTimer
; MessageCenterFlickerRate Make MessageFlickerRate higher than MessageCenterTimer to make solid
; (Message Flicker Rate is 0-127; d7 is the MessageClear At End flag:
; d7 = 0 Dont clear message at end
; d7 = 1 Clear message at end
; All displayed graphics and text are messages
   CLC
   STZ DisplayTextTablePointerHigh      ; Zero the upper base number
   LDA DisplayTextString         ; Get the pointer
   STA DisplayTextTablePointerLow
   ASL DisplayTextTablePointerLow      ; Shift everything 3 times over
   ROL DisplayTextTablePointerHigh
   CLC
   LDA DisplayTextTablePointerHigh
   ADC #$F8            ; Add in the upper base address
   STA DisplayTextTablePointerHigh      ; And put it back. The table is now prepped.
   LDY DisplayTextTablePointerLow
   LDA ($20), y             ; Get MessageCenter1, $20 is hi, y is low
   STA MessageCenter1
   STA Display1
   INY
   LDA ($20), y             ; Get MessageCenter2
   STA MessageCenter2
   STA Display2
   INY
   LDA ($20), y             ; Get MessageCenter3
   STA MessageCenter3
   STA Display3
   INY
   LDA ($20), y             ; Get MessageCenter4
   STA MessageCenter4
   STA Display4
   INY
   LDA ($20), y             ; Get MessageCenter5
   STA MessageCenter5
   STA Display5
   INY
   LDA ($20), y             ; Get MessageCenter6
   STA MessageCenter6
   STA Display6
   INY
   LDA ($20), y             ; Get MessageCenterTimer
   STA MessageCenterTimer
   INY
   LDA ($20), y             ; Get MessageCenterFlickerRate
   STA MessageCenterFlickerRate
; and the table so far....
   *= $F800
;DisplayTextTable
   .DB $00, $4E, $55, $4C, $4C, $00, $FF, $FF   ; $00 = NULL character
   .DB $00, $00, $00, $00, $00, $00, $80, $00   ; $01 = Blank
   .DB $00, $54, $45, $53, $54, $00, $80, $FF   ; $02 = TEST
   .DB $50, $41, $53, $53, $45, $53, $80, $FF   ; $03 = PASSES
The memory in play during single stepping shows that the create base add4ress is working, that I get the $F810 created and placed into memory.
(want it to show the "test" string first off)
The problem is the LDA ($20),y command. I need it to reference from the low and high pointers to grab 8 bytes in a row.
Going bananas, as always. Thanks if any ideas can work out here :)
PostPosted: Sat Apr 19, 2008 3:15 am
I'm sorry, but, can you restate the problem, from the beginning, a bit more clearly? I truely can't understand one word of what you're saying, or what is going on. What is this code actually doing, and what is it's desired output?
PostPosted: Sat Apr 19, 2008 3:30 am
A friend helped me out. What it is doing, it takes a value in DisplayTextString (1-255) and uses it to calculate a table entry point, $F800. Each entry is 8 bytes long and 128 entires for 1K.
the first part of the code calculates the base address of the test string I want to grab. That part works correctly.
The LDA ($20),y is where I had my problem. I preloaded the y register with the low data, not realizing that it added it together. So the $10 loaded in would actually point to $F820, blank space.
So going to give it a shot. Been ages.
This is for the same pinball I've been doing. After it grabs the entries from the table, it uses them to show on a display.
the older version works great in hardware, I wanted to get it working easier with a text string table.
NOW I have to work with some real wierdness, I commended out the JSR to the power up self test. If I put the code back in, the display routine refuses to work and the CPU action is slower or something. If I leafve out the post, the display routine works perfectly. Bleah....
PostPosted: Sat Apr 19, 2008 10:46 am
It's much simpler if you put each of the 8 values in each own table. You avoid having to multiply with 8 and can access everything directly with Y.
   LDA (DisplayTextTableEntry1), y       ; Get MessageCenter1
   STA MessageCenter1
   STA Display1
   LDA (DisplayTextTableEntry2), y       ; Get MessageCenter2
   STA MessageCenter2
   STA Display2
   LDA (DisplayTextTableEntry3), y       ; Get MessageCenter3
   STA MessageCenter3
   STA Display3
   LDA (DisplayTextTableEntry4), y         ; Get MessageCenter4
   STA MessageCenter4
   STA Display4
   LDA (DisplayTextTableEntry5), y       ; Get MessageCenter5
   STA MessageCenter5
   STA Display5
   LDA (DisplayTextTableEntry6), y         ; Get MessageCenter6
   STA MessageCenter6
   STA Display6
   LDA (DisplayTextTableEntry7), y       ; Get MessageCenterTimer
   LDA (DisplayTextTableEntry8), y         ; Get MessageCenterFlickerRate
   RTS
   *= $F800
   .DB $00, $00, $00, $50
   .DB $4E, $00, $54, $41
   .DB $55, $00, $45, $53
   .DB $4C, $00, $53, $53
   .DB $4C, $00, $54, $45
   .DB $00, $00, $00, $53
   .DB $FF, $80, $80, $80
   .DB $FF, $00, $FF, $FF
(untested code)
PostPosted: Tue Apr 22, 2008 1:48 am
Hi Thowilly, that was my previous incarnation of the code revision. It worked fine, no problem. I found that each display column being a seperate table was a tad hard to read for debugging purposes. This form of table makes the entries far easier to understand. The shifting routine for the pointer is used only once during each load, and my program already has a whole slew of time delays to ensure proper operation of some 74LS374 latches.
My mistake was in loading the Y register with the lower value which was ALREADY taken from the offset, so I was doubling the lower pointer which went to blank space at the time.
Here is the working load code. Note that I am not using a loop to load into things because the final 2 values are for seperate display variables.
Also, the reason for multiplying by 8 is because each table entry has 8 entries.
   STA DisplayTextTablePointerHigh      ; And put it back. The pointer is now prepped.
   LDY #$00
   LDA (DisplayTextTablePointerLow), y    ; Get MessageCenter1
   STA MessageCenter1
   STA Display1
   INY
   LDA (DisplayTextTablePointerLow), y    ; Get MessageCenter2
   STA MessageCenter2
   STA Display2
   INY
   LDA (DisplayTextTablePointerLow), y    ; Get MessageCenter3
   STA MessageCenter3
   STA Display3
   INY
   LDA (DisplayTextTablePointerLow), y    ; Get MessageCenter4
   STA MessageCenter4
   STA Display4
   INY
   LDA (DisplayTextTablePointerLow), y    ; Get MessageCenter5
   STA MessageCenter5
   STA Display5
   INY
   LDA (DisplayTextTablePointerLow), y    ; Get MessageCenter6
   STA MessageCenter6
   STA Display6
   INY
   LDA (DisplayTextTablePointerLow), y    ; Get MessageCenterTimer
   STA MessageCenterTimerTemp
   INY
   LDA (DisplayTextTablePointerLow), y    ; Get MessageCenterFlickerRate
and the part of the table.
   *= $F800
;DisplayTextTable
   .DB $00, $4E, $55, $4C, $4C, $00, $80, $00   ; $00 = NULL character
   .DB $00, $54, $45, $53, $54, $00, $80, $00   ; $02 = TEST
   .DB $50, $41, $53, $53, $45, $53, $80, $03   ; $03 = PASSES
you see how it is MUCH more readable for testing and debugging here!
