It is currently Sat Sep 21, 2024 4:38 am
 Post subject: Kestrel-2 Updates
PostPosted: Sat Jan 19, 2008 6:56 am
Well, I've been hacking on my Kestrel-2 emulated environment again. I'm finding the Forth firmware image to be extremely buggy. The bugs didn't manifest themselves until fairly recently, as I was attempting to write Forth storage drivers.
Oh, I also have implemented the first (emulated) SerBus peripheral for the Kestrel, too -- a 64MB capacity direct access storage device (DASD) with 1024-byte 'sectors.' In other words, it's purpose-built for Forth.
However, I'm finding that the Forth image in ROM has entirely too many bugs for my liking, so I'm planning on starting the Forth environment over yet again. I've also been considering ditching Forth in favor of another language, such as a small Lisp environment. An APL-inspired language is also not outside the question.
Currently, I'm working on some ROM-resident code to implement a nice graphical operating system. My current inspiration is GEOS/64, where I've just finished implementing the HorizontalLine clone. However, there are some differences from the GEOS code:
1) my code is MUCH faster than the GEOS code. It's completely 16-bit for starters, and also does a lot less work inside its inner loops.
2) my code supports drawing into off-screen bitmaps and even sub-bitmaps (a bitmap within a larger bitmap), which makes implementing course-grained windowing a cinch.
3) All parameters are passed on the stack, so there are no global direct-page locations used by the code.
UPDATE Below is a screenshot. Here is the code that was used to produce that screenshot:
.import drawHorizontalLineFrom_to_onRow_usingPattern_onBitmap_
.proc stupidDialogBox
    pea solidBlackPattern
    pea frameBufferBitmap
    pea 288+8
    pea 576+8
    pea 96+8
    pea 64+8
    jsl drawFilledRectangleFrom_to_onBitmap_withPatternBitmap_
    pea 288
    pea 576
    pea 96
    pea 64
    pea solidWhitePattern
    pea 287
    pea 575
    pea 97
    pea 65
    pea 284
    pea 572
    pea 100
    pea 68
    pea 281
    pea 569
    pea 103
    pea 71
    clc
    tsc
    adc #60
    tcs
    rts
.endproc
    .rodata
frameBufferBitmap:
    .word 0, $FE
    .word 480
    .word 40
    .word 640
backdropPattern:
    .word backdropPattern_bits, 0
    .word 4
    .word 1
    .word 16
backdropPattern_bits:
    .word $AAAA, $5555, $AAAA, $5555
solidBlackPattern:
    .word solidBlack_bits, 0
    .word 1
    .word 1
    .word 16
solidBlack_bits:
    .word $0000
solidWhitePattern:
    .word solidWhite_bits, 0
    .word 1
    .word 1
    .word 16
solidWhite_bits:
    .word $FFFF
Broken external image link
http://www.falvotech.com/tmp/screenshot-dialog-2.png
This is generated by alternating between $AAAA and $5555 for the pattern when filling the whole screen. Then, I used $0000 to render the dropshadow, and finally $FFFF for the white index card.
Users browsing this forum: Google [Bot] and 15 guests
cron
