Just wanted to share something I put together for a project of mine. I've been using it for some time, so it has been tested.
A binary search is an amazingly efficient search algorithm for large, pre-sorted tables of data. The maximum number of iterations is 1+log<base2>N, meaning that searching a full table of 32,768 unique values would take a maximum of 12 comparisons (or would it be 11... I don't know how to round logarithms :).
The code I use in production actually searches for data referenced by a table of pointers, so there is one more level of indirection than in the code presented below.
Feel free to tear apart my coding... I love to find out better ways of doing things.
The source is formatted for the ACME cross-compiler.
; BINSRCH
; searches sorted table of 16-bit values (table must be aligned
; on two-byte boundary).
; prior to entry,
; .low should point to first entry in the table.
; .high should point to last entry in the table.
; .value should contain the search target.
; on exit,
; if carry set, value was found, and .mid contains pointer.
; if carry clear, value not found, and .low points to where
; target value should be inserted.
; zero page pointers
.low = $10
.high = $12
.mid = $14
.value = $16
.size = 2 ; element size (must be power of 2)
BINSRCH
.loop
SEC ; calculate high - low
LDA .high
SBC .low
TAX ; preserve LSB of difference in X
LDA .high+1
SBC .low+1
BCC .done ; if low > high, not found
LSR ; calculate (high - low) / 2
TAY
TXA
ROR ; carry cleared because multiple of 2
AND #$100 - .size ; align to element size
ADC .low ; mid = low + ((high - low) / 2)
STA .mid
TYA
ADC .low+1
STA .mid+1
LDA .value+1 ; load target value MSB
LDY #1 ; load index to MSB
CMP (.mid),Y ; compare MSB
BEQ .chklsb
BCC .modhigh ; A[mid] > value
.modlow ; A[mid] < value
LDA .mid ; low = mid + element size
ADC #.size - 1 ; carry always set
STA .low
LDA .mid+1
ADC #0
STA .low+1
JMP .loop
.chklsb
LDA .value ; load target value LSB
DEY ; set index to LSB
CMP (.mid),Y ; compare LSB
BEQ .done
BCS .modlow ; A[mid] < value
LDA .mid ; high = mid - element size
SBC #.size - 1 ; carry always clear
STA .high
LDA .mid+1
SBC #0
STA .high+1
JMP .loop
.done
RTS
