It is currently Fri Sep 20, 2024 7:36 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Jan 17, 2019 1:04 pm
Well that took me some effort! First I replaced the SC26C92 with the SC28L92. In order to make use of the 16 bit FIFO, I had to enable it by setting the MR0A[3] bit to ‘1’. This made no difference in playback performance.
Then I implemented a circular 256 byte software buffer together with interrupt based writing to the UART. That was indeed a bit fiddly because of the distinction between the UART and TIMER interrupts. Eventually I got it sort of working. The MIDI file is playing exactly as before, including the lag at those specific areas, but it also misses several MIDI events which of course is even less desirable. I suspect my mistake is that I’m not clearing the interrupt status register bit that indicates the UART interrupt because I don’t know if or how I have to disable it. (I don’t think I have to clear it, because it’s cleared automatically when reading the interrupt status register?)
I’m using the title music of the game Duke Nukem 3D, which is a standard MIDI file from the 90’s, specifically arranged to be played on a Roland Sound Canvas. On a PC, playing that MIDI file over a conventional MIDI interface with a 5-pin MIDI cable, it plays without any lag. It even plays perfectly after setting the tempo to 250 BPM. That should prove that the MIDI file isn’t hogging a physical PC MIDI interface nor the MIDI synthesizer itself.
I’ve analyzed the MIDI file with an event viewer and the moment my player starts to lag is when various MIDI events are to be played at the same time, i.e. when their delta times are 0. After that, when events are streamed with delta times other than 0, it resumes playing at normal speed.
What I will do next is to 1) change the delta times in those areas to 1, eliminating the fact that they have to be send in one interrupt cycle. 2) Replace frequently used subroutines with macros to speed up the code. 3) Perform some code optimizations suggested previously.
Marco
PostPosted: Thu Jan 17, 2019 5:12 pm
Perhaps we should take a look at your code.
PostPosted: Thu Jan 17, 2019 7:14 pm
OK, this is the interrupt code:
I’ve also appended the whole source, it’s too long to put it in the post.
interrupt
      pha
      phx
      phy
      lda   isr
      and   #%00001000      ;check if interrupt is caused by C/T
      beq   HandleUart      ;no? goto uart irq
HandleTimer
      lda   tc         ;is binvlq = tc?
      cmp   binvlq
      bne   IncTc         ;no, increment tc and end irq
      lda   tc+1
      cmp   binvlq+1
      bne   IncTc
      lda   tc+2
      cmp   binvlq+2
      bne   IncTc
      lda   tc+3
      cmp   binvlq+3
      bne   IncTc
ExEv      jsr   DecodeEvent      ;yes, decode a track event (midi/sysex/meta)
      jsr   GetVarLength      ;get variable length quantity
      lda   binvlq         ;is binvlq zero?
      ora   binvlq+1      ;no, reset tc and end irq
      ora   binvlq+2
      ora   binvlq+3
      bne   ResetTickCounter
      bra   ExEv
IncTc
      inc   tc         ;increment tick counter tc
      bne   +
      inc   tc+1
+      bne   +
      inc   tc+2
+      bne   +
      inc   tc+3
      bra   EndTimerIrq
ResetTickCounter
      stz   tc         ;Reset Tick Counter tc  and end irq
      stz   tc+1
      stz   tc+2
      stz   tc+3
EndTimerIrq
      jsr   buf_dif         ;are there bytes to send?
      beq   ClearCountReady      ;no, exit
      lda   imr
      ora   #%00010000      ;enable transmitter TxEMT interrupt according to FIFO level in mr0b
      sta   imr
ClearCountReady
      lda   rop12         ;clear counter ready interrupt status bit
      ply
      plx
      pla
      rti
HandleUart
      lda   isr
      and   #%00010000      ;check if interrupt is caused by transmitter buffer empty
      beq   EndIrq         ;no? exit irq
-      jsr   buf_dif         ;are there bytes to send?
      beq   +         ;no, disable TxEMT interrupt, exit
      jsr   rd_buf         ;read next character to send
      sta   txfifob         ;put character to port
      lda   srb         ;get status reg B
      and   #%00000010      ;is transmit buffer full?
      bne   EndIrq         ;yes, exit
      bra   -
      lda   imr
      and   #%11101111      ;disable transmitter TxEMT interrupt according to FIFO level in mr0b
      sta   imr
EndIrq
      ply
      plx
      pla
      rti
Player27 cleanup.asm [21.23 KiB]
Downloaded 71 times
Marco
PostPosted: Fri Jan 18, 2019 12:09 am
I can see one potential problem:
                lda     imr
                sta     imr
The interrupt mask register on your UART is not a read-modify-write register, but write-only; it shares its address with the interrupt status register, which is read-only. So when this code is executed, the timer interrupt will be masked unless it has already fired and not been reset. In practice you are only resetting that interrupt after this code, but it's still bad practice. You should be resetting the timer interrupt very soon after entering the timer ISR, and certainly before unmasking the CPU interrupt (for the "better timer").
To solve this properly, you need to keep a shadow copy of the IMR somewhere. One possibility is to use the "uncommitted" UART register (ureg) at offset $C, which effectively acts as a byte of RAM. The above would then become:
                lda     ureg
                sta     ureg
                sta     imr
…and similarly for disabling the interrupt later.
That MIDI events are lost indicates that your send buffer is overrunning itself. To guard against that, you need to put a check in your midiout routine for the tail pointer becoming equal to the head pointer. To begin with you could make that an abort condition (busy-loop) so that you become aware of the first time it occurs. With the "better timer" routines I suggested, you would be filling the buffer concurrently with the UART handler draining it, so you could simply busy-wait until space appears in the buffer. I would therefore suggest modifying your buffer routines as follows:
init_buf:       stz     rd_ptr                  ;setting wr_ptr equal to rd_ptr initializes
                stz     wr_ptr                  ;the buffer, showing it to be empty.
                rts
midiout:        ldx     wr_ptr                  ;start with a containing the byte to put in the buffer.
                sta     buffer,x                ;get the pointer value and store the data where it says,
                inx
-               cpx     rd_ptr                  ;wait for space in the buffer,
                beq -
                stx     wr_ptr                  ;then increment the pointer for the next write.
                rts
rd_buf:         ldx     rd_ptr                  ;ends with a containing the byte just read from buffer.
                lda     buffer,x                ;get the pointer value and read the data it points to.
                inc     rd_ptr                  ;then increment the pointer for the next read.
                rts
buf_empty:        lda     wr_ptr
                cmp     rd_ptr                  ;ends with Z set if the buffer is empty.
                rts
rd_ptr  !byte   0                               ;reserve one byte of ram for the read pointer
wr_ptr  !byte   0                               ;and one for the write pointer.
PostPosted: Fri Jan 18, 2019 6:18 am
Turning the TxD IRQ on and off during run time is not a recommended procedure. Instead you should disable the transmitter when there is nothing to transmit and re-enable it when data to transmit becomes available. Disabling the transmitter will automatically cancel a pending TxD IRQ, and is accomplished with a single write to the channel command register—also the case when re-enabling the transmitter. I've given you working code in the past, Marco, on how to correctly handle this stuff—you should refer to it to avoid having to re-invent the wheel.
As for the timer, reading the ISR to determine if the timer is responsible for an IRQ only tells if that is the case. It doesn't cancel the IRQ. A timer IRQ is cleared by issuing a "stop timer" command. If the timer is in free-run mode it continues to run despite the "stop timer" command.
Lastly, subroutines in interrupt service handlers are not advisable. Unless there is a really compelling reason to use a subroutine, all ISR code should be linear to avoid the stack activity required with subroutines.
Last edited by BigDumbDinosaur on Fri Jan 18, 2019 7:37 am, edited 1 time in total.
PostPosted: Fri Jan 18, 2019 6:33 am
I suspect he's trying to learn by doing, rather than by following a recipe. In context, I don't think subroutines or the precise method by which interrupts are turned off are that big a deal.
But yes, he needs to move the timer IRQ reset much earlier in the routine. That in itself should give him some more margin.
PostPosted: Fri Jan 18, 2019 7:37 am
They matter in code that has to meet processing deadlines in order to function in a satisfactory fashion—MIDI playback, I opine, qualifies as such a case. In the 28L92 (and other NXP UARTs of that type), manipulating the interrupt mask register (IMR) is somewhat cumbersome, since it's a write-only register, necessitating the overhead of maintaining a shadow somewhere. Stopping a transmitter involves a single write that requires no shadow, since a separate write command is used to start the transmitter.
As for subroutine usage, when the interrupt rate starts getting up there, the additional cycles represented by a JSR/RTS pair become significant. In my 65C816 interrupt processing article, I noted the following:
    The use of subroutines in an interrupt service routine can substantially hurt performance, as each JSR – RTS pair will consume 12 clock cycles, or 14 cycles if using JSL – RTL. If your interrupt handler includes three calls to the same subroutine and is processing a 100 Hz jiffy interrupt, 3600 clock cycles will be consumed per second just in executing JSR and RTS instructions. A lot of foreground processing can be completed in 3600 cycles! Only use subroutines if you have to squeeze every last byte out of the available address space.
So yes, it can be a big deal.
PostPosted: Fri Jan 18, 2019 8:06 am
Can be, I'll grant you. But I don't think @lordbubsy is at the level of worrying about that just yet; those are optimisations he can make in due course.
PostPosted: Sat Jan 19, 2019 12:47 pm
@Chromatix
Indeed I am. I just began writing this MIDI player by reading the MIDI implementation. It worked out very quickly and very well, but I must admit that I have a hard time to make sense of what happens when the code in the interrupt routine takes more time than it’s given for one interrupt period. Especially when there is more than one interrupt involved.
The interrupt mask register on your UART is not a read-modify-write register...
OK, that’s what BDD also said about the MRxx registers, I just have forgotten to implement it. However, that made no difference. It still loses events and stalls.
Done that.
I tried your suggestion but it made no difference, events still got lost. So I tried this to stop the program if the buffer would get full.
                inx
                beq +
                rts
+               stp
...but it doesn’t stop, so the buffer isn’t overrun???
I suspect that my UART interrupt routine is not functioning well in conjunction with the timer routine.
I think I’ll revisit the "better timer" routines you suggested, because I haven’t implemented or even understood them.
@BDD
I replaced the TxD IRQ on and off with disabling / enabling the transmitter with:
      lda   #%00000101      ;enable Tx enable Rx
      sta   crb
      lda   #%00001010      ;disable Tx disable Rx
      sta   crb
Unfortunately no change.
Yes you did, but back then I got it working on MARC-2 by copy and paste. A few months back I tried to get it working on MARC-4 but I failed. Perhaps I should give it another try. I’m rather new to the interrupt thing, I got several things working on a VIA handshake interrupt, the VDP scanline interrupt and the DUART timer interrupt. But I’ve still got to figure out the UART interrupt a bit more.
As far as I know I’m doing that by reading register “duart_base + $f”, right?
That’s definitely an easy thing to do next, but I don’t think it will save the day.
Here is how I initialize the timer and UART interrupt:
Initialize the MIDI UART channel B:
acia_b_init
      lda   #%10110000      ;set MR pointer to 0
      sta   crb
      lda   #%00000000      ;MR0 Normal mode
      sta   mr0b
      lda   #%00010011      ;No parity, 8 bits per char.
      sta   mr1b
      lda   #%00001111      ;Stop bit length 2.000
      sta   mr2b
      lda   #%11101110      ;receiver clock select IP5-16X transmitter clock select IP5-16X
      sta   csrb
      sta   crb
      rts
Setup the interrupts:
SetupDUARTInterrupt
                sei                             ;disable interrupts
                lda     #<interrupt             ;set interrupt vector
                sta     $fffe                   ;RAM on MARC-4
                lda     #>interrupt
                sta     $ffff
                lda     #>$1000                 ;set c/t for 192Hz or 5208us
                sta     ctpu
                lda     #<$1000                 ;deviser = 3.6864MHz / (2*192) = 9600 = $2580
                sta     ctpl
                lda     #%01100000              ;enable timer (square wave) X1 mode
                sta     acr                     ;clear bit 4 and set bits 6 & 5
                lda     #%10110000              ;set MRB pointer to 0
                sta     crb
                lda     #%00000000              ;MR0[5] MR0[4] Transmitter FIFO Interrupt Fill Level
                sta     mr0b                    ;8 bytes empty TxEMPTY
                lda     #%00011000              ;enable counter ready interrupt and transmitter interrupt
                sta     imr
                lda     sop12                   ;start timer by reading register 14
                cli                             ;enable interrupts
                rts
The interrupt routine itself:
interrupt
                pha
                phx
                phy
                lda     isr
                and     #%00010000              ;check if interrupt is caused by C/T
                beq     HandleTimer             ;no? goto uart irq
                jmp     HandleUart
HandleTimer
                cmp     binvlq
                lda     tc+1
                cmp     binvlq+1
                bne     IncTc
                lda     tc+2
                cmp     binvlq+2
                bne     IncTc
                lda     tc+3
                cmp     binvlq+3
                bne     IncTc
                ora     binvlq+2
                ora     binvlq+3
                bra     ExEv
IncTc
                bne     +
                inc     tc+1
+               bne     +
                inc     tc+2
+               bne     +
                inc     tc+3
                bra     EndTimerIrq
ResetTickCounter
                stz     tc+1
                stz     tc+2
                stz     tc+3
EndTimerIrq
                sta     crb
ClearCountReady
                ply
                plx
                pla
                rti
HandleUart
                lda     isr
                bra     -
                lda     #%00001010              ;disable Tx enable Rx
                sta     crb
EndIrq
                ply
                plx
                pla
                rti
Thanks for all the patience, I hope it isn’t getting too boring. :oops:
Marco
PostPosted: Sat Jan 19, 2019 3:53 pm
If x or y is not needed on the interrupt handler then there is no need to stack them.
The HandleUart code can be before the interrupt handler then you wouldn't need the Jmp.
PostPosted: Sat Jan 19, 2019 5:06 pm
Instead of AND for checking bits, you can use BIT. This doesn't destroy contents of A.
PostPosted: Wed Jan 23, 2019 7:24 am
I think I see a bug here. The bit tested is the one for Receive FIFO Full, but you want the one for Transmit FIFO Ready. The following should fix it:
                bit     #%00000100              ;is transmit buffer ready?
                beq     EndIrq                  ;no, exit
PostPosted: Wed Jan 23, 2019 2:59 pm
@Chromatix
Thank you! It’s working now, that is, the MIDI file is playing back as previously. All events are being send, but there where’re multiple events with delta time 0, it starts stalling. i.e. the player behaves as if there were no software buffer or transmitter interrupt. :(
I’m not sure if I said this before, but the tempo restores to normal when the MIDI stream is less busy. What I didn’t notice until now is that there is a difference in playback speed during those stalls while playing them back with 8MHz or 1MHz.
Could it be that a PC MIDI interface is better in handling those dense MIDI streams?
There is also something called intelligent mode, which I haven’t implemented.
@BDD
I’m trying to figure out the SC26C92 routines you gave me years ago. It’s going slowly...
Marco
PostPosted: Wed Jan 23, 2019 5:45 pm
In all honesty, this is good practice for me as well. It might even give me an excuse to get interrupts and some devices working in my emulator. Perhaps you could upload the code as it presently stands, as its misbehaviour would be a good test case for emulation.
I recall previously you said the tempo didn't vary with CPU speed, so I think we're making progress, in that the bottleneck has moved. That means we've solved one problem and uncovered another. Previously the UART was blocking progress, now we're simply taking too long to process each flood of MIDI events in software. The outcome is similar; we miss timer interrupts, so the beat slows.
The solution will probably be that "better timer" I described previously. Implementing that correctly will require a relatively deep understanding of how interrupts really work on the 6502, but it will then count the number of missed timer interrupts, and allow the MIDI routine to catch up once it's finished processing the current tick.
Optimising your code is also likely to help, but only on the quantitative level (like increasing the CPU speed), not qualitative (avoiding perceptible slowdowns entirely). The PC benefits here from having a vastly more powerful CPU, but that is overkill for the simple task of decoding a MIDI file, and much of the extra power is absorbed by increasingly inefficient layers of "modern" software. There are, however, one or two hints at reasonable optimisations in the pseudocode I posted earlier, such as counting down from the delta value to zero, instead of counting up to it from zero. This means you can perform the test against reaching the deadline more efficiently. This is a standard transformation that you can often apply in low-level coding, and which compilers often apply behind the scenes.
As it happens, while counting down a single-byte variable to zero is easy and fast on the 6502, for multi-byte variables it's more efficient to bitwise-invert the value and then count up to zero. Consider this variant on your main loop:
HandleTimer
               ; insert mutex test etc here
IncTc
                inc     tc                      ; increment tick counter tc and test against zero
                bne     EndTimerIrq
                inc     tc+1
                bne     EndTimerIrq
                inc     tc+2
                bne     EndTimerIrq
                inc     tc+3
                bne     EndTimerIrq
ExEv
                jsr     DecodeEvent             ; decode a track event (midi/sysex/meta)
                jsr     GetVarLength            ; get variable length quantity
                lda     binvlq                  ; is binvlq (delta ticks) zero?
                ora     binvlq+1
                ora     binvlq+2
                ora     binvlq+3
                beq     ExEv
                lda     binvlq                  ; transform binvlq into count-up-to-zero form
                eor     #$FF
                sta     tc
                lda     binvlq+1
                eor     #$FF
                sta     tc+1
                lda     binvlq+2
                eor     #$FF
                sta     tc+2
                lda     binvlq+3
                eor     #$FF
                sta     tc+3
                bra    IncTc                      ; complete the negation by incrementing it
PostPosted: Wed Jan 23, 2019 6:53 pm
lordbubsy wrote:
@BDD
Is your MIDI machine running on a 65C02 or 65C816?
