It is currently Fri Nov 22, 2024 9:43 am
Post new topic Reply to topic  [ 245 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17  Next
PostPosted: Tue May 30, 2023 3:38 pm
Arlet wrote:
It's possible to optimize in various directions. Using more/less ZP, code size, cycles, or period/quality. Let me know what you care about most.
Thank you for your kind attention. In VTLC02, code size is primary, and cycles are secondary. Everything else is a distant #3, but in this case, I also need a guarantee that all possible values are eventually visited (you and White Flame both appear to have that covered already). That's the main problem with VTLC02's current PRNG.
PostPosted: Tue May 30, 2023 4:39 pm
If code space is at a premium, you might use the 8 bit version of my code, and call the routine twice to obtain 16 bits. While strictly not guaranteeing that every possible value will be visited, the fact that it passes good randomness tests into the gigabytes means that in practice it must have equal chance for each value. Keep in mind that it is possible that certain 16 bit values will occur multiple times while other values are not yet seen.
If you need 16 bits output where each value occurs exactly once per 64k calls, let me know. I can make that too, but it will require a different approach.
PostPosted: Tue May 30, 2023 6:27 pm
Improved code, now 77 cycles and 5 state bytes, and passes 8GB random test. Output is stored in o+0 and o+1
    CLC
    LDA #$45
    ADC s+0
    STA s+0
    ADC s+1
    STA s+1
    ADC s+2
    STA s+2
    ADC s+3
    STA s+3
    LDA s+4
    ROL A
    ROL A
    STA s+4
    ADC s+2
    STA o+0
    ADC s+4
    STA s+4
    ADC s+3
    STA o+1
    ADC s+1
    ADC s+4
    STA s+4
    ADC o+0
    STA o+0
    ADC s+4
    STA s+4
    RTS
working example
PostPosted: Wed May 31, 2023 6:13 am
More improved code, now 71 cycles and 5 state bytes, and passes 4GB random test. Output is stored in o+0 and o+1. I've also added this code to my github repository.
    CLC
    LDA #$45
    ADC s+0
    STA s+0
    ADC s+1
    STA s+1
    ADC s+2
    STA s+2
    ADC s+3
    STA s+3
    LDA s+4
    ROL A
    STA s+4
    ADC s+2
    STA o+0
    ADC s+3
    STA o+1
    ADC s+1
    ROL A
    ADC o+0
    STA o+0
    ADC s+4
    STA s+4
    ADC o+1
    STA o+1
    RTS
Note that the last STA o+0 and STA o+1 are optional. You can modify the program to store the two output bytes somewhere else. For instance, you could return the 16 bit value in X,A pair by replacing the STA o+0 with TAX and removing the STA o+1.
owlet link
PostPosted: Wed May 31, 2023 6:22 am
    LDA s+4
    ROL A
    STA s+4
can be replaced by
    ROL s+4
    LDA s+4
and we save a precious byte. :)
PostPosted: Wed May 31, 2023 6:37 am
I've only tested this with $45 constant at the beginning. It will still work with other odd constants, but quality of random output may vary a bit. For instance with constant 1, it still passes 1GB of output. If you happen to have an even constant in A, you can replace the CLC by SEC.
PostPosted: Wed May 31, 2023 7:01 am
If you just wanted something super simple that produces every single 16 bit value exactly once, in random order, you could use something like this. 16 bit output in A,X:
    CLC
    LDA #1 ; any odd value
    ADC s+0
    STA s+0
    ADC s+1
    STA s+1
    ASL A
    ADC s+0
    TAX
    EOR s+0
    RTS
Good enough for games where you need a random action for a monster, but it's not going to pass any randomness tests. It's very easy to generate these kinds of random generators. You start with some code that iterates through every single 16 bit number, which is the part between CLC .. STA s+1. You then have two bytes in s+0 and s+1, which have a bit of randomness, but not too good. You then mix these bytes together to improve quality. If you mix with any bijective (invertible) function, then you guarantee that every 16 bit value still occurs exactly once. If you have two bytes A and B, you can create bijective functions by taking any arbitrary function f(), apply it to A, and then apply that to B in an invertible way, for instance with ADC or EOR. So, A = A + f(B), or B = B ^ g(A). Just be careful that you don't add unknown carry flag. You can also use any invertible operation on A or B by itself, such as a bit rotate. These bijective mixers can be stacked.
PostPosted: Wed May 31, 2023 7:36 am
    CLC
    ADC s+0
    STA s+0
    ADC s+1
    STA s+1
    ASL A
    ADC s+0
    TAX
    EOR s+0
    RTS
The "exactly once" part isn't strictly necessary, but it is acceptable. The winning attributes for me are the tiny code and ZP footprint, so I'll splice it in (with attribution) and run some informal tests. Thank you.
PostPosted: Wed May 31, 2023 8:18 am
The "exactly once" comes naturally if you want tiny code and ZP footprint, but don't want a bunch of missing/duplicate values.
PostPosted: Wed May 31, 2023 3:49 pm
https://xkcd.com/221/
Grin, duck, run...
PostPosted: Thu Jun 01, 2023 1:45 pm
a few other random generators :
batari8 (0)
   Type:         galois8 lfsr
   6502 author:  Fred Quimby
   RAM:          1 byte
   Cycles:       11-12
   Period:       255
   References:   https://github.com/batari-Basic
   Notes:    This is the rand routine included with the 2600 development
      language batari Basic. It's main strength is it's compactness
      and speed.
   Sample:       (2a) 15 be 5f 9b f9 c8 64 32 ...
        LDA randv0
        LSR
        BCC noeor
          EOR #$B4
      noeor:
        STA randv0
batari8rev (1)
   Type:         galois8 lfsr
   6502 author:  (forward) Fred Quimby, (reversal) Mike Saarna
   RAM:          1 byte
   Cycles:       11-12
   Period:       255
   Notes:    This is a reversed version of the LFSR included with batari
      Basic.  Reversal allows the pseudorandom sequence to be
      rewound at any point, without requiring additional storage.
   Sample:       (32) 64 c8 f9 9b 5f be 15 2a ...
        LDA randv0
        ASL
        BCC noeor
          EOR #$69
      noeor:
        STA randv0
batari16 (2)
   Type:         galois8 extended to 16 bits
   RAM:          2 bytes
   Cycles:       19-20
   Period:       65535
   Notes:    This is the rand16 routine included with the 2600 development
      language batari Basic, and the default rand routine in
      7800basic. Its quick and compact for a 16-bit LFSR.
   Sample:       (2a2a) 41 a3 e3 fd d2 d8 ba 19 ...
        LDA randv0
        LSR
        ROL randv1
        BCC noeor
          EOR #$B4
      noeor:
        STA randv0
        EOR randv1
batari16rev (3)
   6502 author:  (forward) Fred Quimby, (reversal) bogax
   RAM:          2 bytes
   Cycles:       22-23
   Period:       65535
      7800basic, run backwards
   Sample:       (a124) 19 ba d8 d2 fd e3 a3 41 ...
        LDA randv1
        LSR
        LDA randv0
        ROL
        BCC skip_eor16
        EOR #$68
      skip_eor16:
        STA randv0
        ROR randv1
        EOR randv1
pitfall8left (4)
   Type:         fibonacci8 lfsr
   6502 author:  David Crane
   RAM:          1 byte
   Cycles:       30
   Period:       255
   References:   https://samiam.org/blog/20130606.html
   Notes:   This is the left-travelling LFSR from the Atari 2600
      game Pitfall. It's at the core of the game's algorithmic
      level generation.
   Sample:       (2a) 95 4a a5 52 29 14 8a 45 ...
        LDA randv0
        ASL
        EOR randv0
        ASL
        EOR randv0
        ASL
        ASL
        ROL
        EOR randv0
        LSR
        ROR randv0
        LDA randv0
pitfall8right (5)
   RAM:          1 byte
   Cycles:       30
   Period:       255
   Notes:   This is the right-travelling LFSR from the Atari 2600
      level generation.
   Sample:       (45) 8a 14 29 52 a5 4a 95 2a ...
        LDA randv0
        ASL
        EOR randv0
        ASL
        EOR randv0
        ASL
        ASL
        EOR randv0
        ASL
        ROL randv0
        LDA randv0
xorshift16 (6)
   Type:         xorshift16 lfsr
   6502 author:  Veikko
   RAM:          2 bytes
   Cycles:       30
   Period:       65535
   References:   http://www.retroprogramming.com/2017/07/xorshift-pseudorandom-numbers-in-z80.html
   Notes:   This is an efficient 6502 implementation of the xorshift16
      algorithm.
   Sample:       (2a2a) 0a ad 77 8b 50 37 06 75 ...
        LDA randv1
        LSR
        LDA randv0
        ROR
        EOR randv1
        STA randv1
        ROR
        EOR randv0
        STA randv0
        EOR randv1
        STA randv1
xhybrid24 (7)
   Type:         hybrid xorshift16+galois8
   6502 author:  (hybrid code) Mike Saarna, (base xorshift16) Veikko
   RAM:          3 bytes
   Cycles:       48-50
   Period:       16711425
   References:
   Notes:   A bit sampling on the xorshift16 upper-byte cranks a galois8
      lfsr forward. This results in an atypical lfsr period.
      xhybrid24 passes and scores well on most "dieharder"
      randomness quality checks. This level of rand quality probably
      isn't needed on 6502 based systems, but it's nice that it can
      be done with relative efficiency.
   Sample:       (010101) f4 c5 d0 ae 75 6b 70 d2 ...
        BIT randv1
        BVS skipupperlfsr
          LDA randv2
          LSR
          BCC skipuppereor
            EOR #$B4
      skipuppereor:
          STA randv2
      skipupperlfsr:
        LDA randv1
        LSR
        LDA randv0
        ROR
        EOR randv1
        STA randv1
        ROR
        EOR randv0
        STA randv0
        EOR randv1
        STA randv1
        EOR randv2
overlap24 (8)
   Type:         ??
   6502 author:  ??
   RAM:          3 bytes
   Cycles:       73
   Period:       16777215
   References:   https://wiki.nesdev.com/w/index.php/Random_number_generator/Linear_feedback_shift_register_(advanced)
   Notes:   Has an XOR-feedback that contains only four bits, but by
      shifting and feeding back 8 bits at once, a more complex
      overlapped result is obtained.
   Sample:       (010203) 1b 36 2d 45 8a d4 81 43 ...
        LDY randv1
        LDA randv2
        LSR
        LSR
        LSR
        LSR
        STA randv1
        LSR
        LSR
        EOR randv1
        LSR
        EOR randv1
        EOR randv0
        STA randv1
        LDA randv2
        ASL
        EOR randv2
        ASL
        ASL
        EOR randv2
        ASL
        EOR randv2
        STY randv2
        STA randv0
riverraid16 (9)
   Type:         ??
   6502 author:  Carol Shaw
   RAM:          2 bytes
   Cycles:       27
   Period:       57337
   References:   http://www.bjars.com/source/RiverRaid.asm
   Notes:   "randomHi is very random, randomLo is NOT when more than one
      bit is used, because: randomLo[x+1] = randomLo[x]*2 + 0/1, but
      randomLo is used more often [in the game] [...]"
         --Thomas Jentzsch
   Sample:       (a814) 0a 05 b6 5b 99 f8 7c 3e ...
        LDA randv1
        ASL
        ASL
        ASL
        EOR randv1
        ASL
        ROL randv0
        ROL randv1
        LDA randv1
PostPosted: Thu Jun 01, 2023 3:42 pm
Very nice little collection there, Alex1. Thank you!
PostPosted: Fri Jun 02, 2023 11:24 am
Nice 32 bit random generator, with 7 bytes of state, and 4 bytes of output. Period is guaranteed to be at least 2^48 words, so for all practical purposes will never repeat. The four output bytes are written only once, and not read back, so you can modify the code to put them somewhere else instead of in the RAM array. Note that the random quality is on the low side, but at 20 cycles/byte, it is quite fast. It is possible to shorten the 6-stage ADC/STA sequence at the beginning to reduce footprint, code size, and cycle time, at the cost of lowering the random quality even more.
(I'm playing around with PRNG for Arduino, and it has a very nice SWAP instruction that swaps the high and low nibble of a register. It's very effective in combination with ADC chains to create good randomness. Unfortunately, doing a nibble swap on 6502 is quite expensive, and probably not really worth it)
    CLC
    LDA #$45
    ADC s+0
    STA s+0
    ADC s+1
    STA s+1
    ADC s+2
    STA s+2
    ADC s+3
    STA s+3
    ADC s+4
    STA s+4
    ADC s+5
    STA s+5
    ADC s+3
    STA o+0 ; first output byte
    ADC s+6
    ASL A
    STA s+6
    ADC s+2
    STA o+1 ; second output byte
    ADC s+6
    ASL A
    STA s+6
    ADC s+4
    STA o+2 ; third output byte
    ADC s+5
    STA o+3 ; fourth output byte
    RTS
owlet code
PostPosted: Tue Jun 20, 2023 7:38 am
By the way my LFSR64+LCG64 still good after 16TB data...
RNG_test using PractRand version 0.94
RNG = RNG_stdin8, seed = unknown
test set = core, folding = standard (8 bit)
rng=RNG_stdin8, seed=unknown
length= 8 megabytes (2^23 bytes), time= 2.9 seconds
  no anomalies in 76 test result(s)
length= 16 megabytes (2^24 bytes), time= 6.5 seconds
  no anomalies in 84 test result(s)
length= 32 megabytes (2^25 bytes), time= 12.9 seconds
  no anomalies in 93 test result(s)
length= 64 megabytes (2^26 bytes), time= 24.8 seconds
  no anomalies in 99 test result(s)
length= 128 megabytes (2^27 bytes), time= 47.7 seconds
  no anomalies in 108 test result(s)
length= 256 megabytes (2^28 bytes), time= 92.1 seconds
  no anomalies in 118 test result(s)
length= 512 megabytes (2^29 bytes), time= 180 seconds
  no anomalies in 126 test result(s)
length= 1 gigabyte (2^30 bytes), time= 355 seconds
  no anomalies in 135 test result(s)
length= 2 gigabytes (2^31 bytes), time= 706 seconds
  no anomalies in 144 test result(s)
length= 4 gigabytes (2^32 bytes), time= 1406 seconds
  no anomalies in 151 test result(s)
length= 8 gigabytes (2^33 bytes), time= 2821 seconds
  no anomalies in 159 test result(s)
length= 16 gigabytes (2^34 bytes), time= 5661 seconds
  no anomalies in 167 test result(s)
length= 32 gigabytes (2^35 bytes), time= 11312 seconds
  no anomalies in 173 test result(s)
length= 64 gigabytes (2^36 bytes), time= 22845 seconds
  no anomalies in 181 test result(s)
length= 128 gigabytes (2^37 bytes), time= 45338 seconds
  no anomalies in 189 test result(s)
length= 256 gigabytes (2^38 bytes), time= 91090 seconds
  no anomalies in 195 test result(s)
length= 512 gigabytes (2^39 bytes), time= 186524 seconds
  no anomalies in 202 test result(s)
length= 1 terabyte (2^40 bytes), time= 366013 seconds
  no anomalies in 208 test result(s)
length= 2 terabytes (2^41 bytes), time= 729582 seconds
  no anomalies in 213 test result(s)
length= 4 terabytes (2^42 bytes), time= 1470769 seconds
  no anomalies in 218 test result(s)
length= 8 terabytes (2^43 bytes), time= 2981457 seconds
  no anomalies in 222 test result(s)
length= 16 terabytes (2^44 bytes), time= 6061817 seconds
no anomalies in 225 test result(s)
PostPosted: Tue Jun 20, 2023 9:49 am
Arlet wrote:
Unfortunately, doing a nibble swap on 6502 is quite expensive, and probably not really worth it.
http://6502.org/source/general/SWN.html
Eight bytes and 12 cycles, so not terrible. Depends on your definition of "expensive", I suppose. :D
