It is currently Thu May 23, 2024 10:04 am
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Sat Aug 20, 2022 11:52 pm
jeffythedragonslayer wrote:
Oh, ok thx, so that doesn't require fiddling with DB, but the 24-bit address does have to be on the stack and isn't hardcoded in the instruction stream like it is with absolute long addressing.
Like Proxy says.
Direct page can be anywhere in bank $00 RAM, which is also true with the stack. If the two are coincident, direct page addressing may be used to access stack elements, which means the stack can be used as an ephemeral direct page inside subroutines. The ability to do so is aided by the fact that SP (stack pointer) can be copied directly to the 16-bit accumulator and arithmetic performed on whatever address is therein. Here’s some simple code that demonstrates how it works:
;using the stack as temporary direct page
;registers: .C — 16-bit accumulator
;           .Y — Y-index
;           DP — direct page (16 bits)
;           SP — stack pointer (16 bits)
;Entry SP = $B7FF in this example.  We need 3 bytes for a long DP pointer.
target   = $028000             ;target address for data fetch/store
         rep #%00100000        ;16-bit accumulator
         sep #%00010000        ;8-bit index
;        Reserve stack space & relocate direct page...
         phd                   ;save current DP (SP = $B7FD)
         tsc                   ;copy SP to .C
         sec                   ;reserve 3 stack bytes
         sbc !#3               ;!# means 16-bit immediate
         tcs                   ;SP is now at $B7FA
         inc A                 ;starting address of the reserved space
         tcd                   ;point DP to reserved space (DP = SP+1 or $B7FB)
;        Set up direct page pointer...
         lda !#target & $FFFF  ;$8000
         ldx #target >> 16     ;$02
         sta $00               ;set up long...
         stx $02               ;direct page address
;        Do data fetch, process & store...
         rep #%00010000        ;16-bit index
         ldy !#$1234           ;some random index value
         lda [$00],y           ;fetch from target address + .Y...
;        The above instruction is effectively LDA $028000,Y or
;        LDA $029234, even though $028000,Y is not a supported
;        addressing mode.  Bytes will be loaded from $029234 &
;        $029235.
;        ...data gets processed...
         iny
         iny
         sta [$00],y           ;store processed data at $029236 & $029237
;        Clean up stack & restore DP...
         clc
         tsc                   ;SP to .C ($B7FA)
         adc !#3               ;relinquish reserved stack space
         tcs                   ;SP is now $B7FD
         pld                   ;restore DP (SP is now $B7FF)
         ...program continues...
The above illustrates a concept whose simplicity belies the flexibility it offers to the programmer.
