It is currently Sat Sep 28, 2024 8:45 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Thu Mar 05, 2020 3:25 pm
As the operating system is in high memory &FFFF downwards, (by neccessity, the hardware vectors are there), it makes sense for the operating system zero page to be in high memory, &00FF downwards.
JGH - http://mdfs.net
PostPosted: Thu Mar 05, 2020 4:59 pm
Which is the exact opposite of how most 65xx-oriented OS's are implemented.
Something to consider if you "reverse" zero page that way is adding new locations may become more of a chore. If zero page usage starts at some low address X, ending at higher location Y and new locations are added in a future revision, they can be added as Y+1, Y+2, etc. The converse would effectively be Y-1, Y-2, etc., which if multiple zero page locations are used as pointers, can lead to complication in making assignments.
Incidentally, and to be a little pedantic, the MOS Technology/WDC assembly language standard for the 65xx family is to notate hexadecimal values as $xxxx, not &xxxx. More than a few assemblers interpret & as the logical AND operator, which would likely make &FFFF ambiguous or lead to an assembly-time error.
PostPosted: Thu Mar 05, 2020 6:16 pm
The ampersand prefix is the BBC BASIC way of signifying hexadecimal.
