It is currently Sun Sep 29, 2024 7:25 am
PostPosted: Wed Nov 14, 2018 6:28 pm
So, was the difficulty figuring out what commands to send? or just getting it work once you knew that?
Are these high level commands to the controller, vs USB Block Mode (or whatever it is) commands?
PostPosted: Thu Nov 15, 2018 9:22 am
Both. The PDF doesn't do a good job of stating what each command does or the the order in which they must be used.
Its a bit of a mixture. Some are high level commands working at the level of files and directories. Others access LBA addressed sectors, however ...
After more head scratching last night I released I'm not reading LBA 0 for the flash disk (e.g. the first partition MBR). Instead I'm reading the first sector of the first FAT32 partition e.g. the boot sector.
My goal was to access the whole physical device so I could implement my own filing system. The addressing scheme I was going to use meant a large physical disk would have to be subdivided into lots of smaller partitions.
If I stick with the CH376 then I could work within FAT32 partition overwriting its contents or place my filing system inside a big file in the root directory -- attractive in that I can inspect and alter the file with a C or Java app under windows but potentially slower as all random access to the sectors has to be mapped through the FAT table.
Or I could go back to SPI accessing SD cards directly.
PostPosted: Thu Nov 15, 2018 10:47 am
After more research I discovered that my USB flash drive was formatted in USB-FDD mode so there is no partition table. The whole drive is a single FAT32 partition.
I used a RPi and 'gparted' to reformat the drive in USB-HDD mode with a partition table and added a couple of small partitions . Now the contents of LBA 0 look like a MBR.
PostPosted: Thu Nov 15, 2018 7:31 pm
I haven't looked at it to deeply, so I was curious if you were going to be able to do, effectively, sector level I/O at a higher level than the raw USB protocol. (Not that I have much of an idea of what that entails.)
Because, in the end, while that chip is conscious of the FAT file system, its also a universal USB connector -- so you can use that not just for a DOS USB FOB, but for all sorts of other USB things.
