It is currently Thu Sep 19, 2024 5:09 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jan 09, 2016 3:32 pm
If you're interested in the floating point routines I wrote for VM02, The Apple II Java VM, the opcode implementation is here:
http://vm02.cvs.sourceforge.net/viewvc/ ... iew=markup
Search for FLOATING_POINT. It implements the Java IEEE 32-bit format, but doesn't handle exceptional cases. Good enough for playing around, though.
Dave...
PostPosted: Tue Jan 12, 2016 1:15 pm
Thanks, I'm sure it will come in handy. I haven't tried it but VM02 looks amazing.
PostPosted: Tue Jan 26, 2016 11:07 pm
Worked on the 265SXB API over the weekend. There are routines for printing text, keyboard input, and I/O ports. The demo project (subject to change) currently prints some text and flashes an LED when a button is pressed:
https://github.com/mikeakohn/java_grind ... nkLED.java
Printing signed integers was a challenge. I borrowed an algorithm from a stack overflow answer (lost the link, sorry), which uses repeated subtraction to divide by 10000, 1000, 100, 10, etc. It's still pretty rough, but here it is anyway:
https://github.com/mikeakohn/java_grind ... B.cxx#L155
Edit: found the algorithm:
http://electronics.stackexchange.com/qu ... 2633#12633
