It is currently Sat Sep 21, 2024 2:29 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: CA65: .org in .macro
PostPosted: Fri Aug 15, 2014 9:06 am
My As65 assembler adds an alphabetically sorted (left column) and numerically sorted (right column) symbol dump to the end of the listing file
Portable 65xx Assembler [14.05.19]
Symbol Table
ACIA_CMND                        0000FE02  | MB_IMP                           00000000
ACIA_CTRL                        0000FE03  | MD_IMP                           00000000
ACIA_DATA                        0000FE00  | NUL                              00000000
ACIA_STAT                        0000FE01  | OP_NUL                           00000000
ACK                              00000006  | __6501__                         00000000
A_REG                            000000F0  | __65816__                        00000000
BEL                              00000007  | __65832__                        00000000
BRKHandler                       0000F039  | __65C02__                        00000000
BS                               00000008  | __65SC02__                       00000000
Bits                             0000F466  | MB_ACC                           00000001
BumpPtr                          0000F591  | MD_ACC                           00000001
BumpRx                           0000FF54  | SOH                              00000001
BumpTx                           0000FF5C  | __6502__                         00000001
External refernces show as zero (as they are unknown at assembly time) and relocatable symbols will show as the offset to the section start address. The map file generated by the linked shows where the external symbols and sections were finally placed.
Global Symbol Map
GetChar           0000F5F8 in boot.obj
Sections:
.page0           : 000000F0 - 000000FD in boot.obj
.bss             : 00000200 - 00000300 in boot.obj
.code            : 0000F000 - 0000F6A8 in boot.obj
                   0000FC00 - 0000FDFF in boot.obj
                   0000FE00 - 0000FEFF in boot.obj
                   0000FF00 - 0000FF64 in boot.obj
                   0000FFFA - 0000FFFF in boot.obj
PostPosted: Fri Aug 15, 2014 4:06 pm
But note my subsequent post!
Noted. I saw it after the fact. :oops:
PostPosted: Fri Aug 15, 2014 4:08 pm
Symbol Table
Global Symbol Map
Sections:
One of these days I'm going to see about getting your assembler up and running on my (one and only) Windows box. I'm not a fan of Java, as it tends to be quite the resource hog. However, your assembler's design is well thought out and has plenty of functionality.
PostPosted: Fri Aug 15, 2014 7:37 pm
Java runs on other operating systems, not just Windows. It works very nicely on Linux.
PostPosted: Fri Aug 15, 2014 8:02 pm
Works on OSX too, with a suitable command line:
java -cp ../65xx.jar uk.co.demon.obelisk.w65xx.As65 IsDigit.asm
PostPosted: Fri Aug 15, 2014 9:29 pm
Attached is a ZIP with the latest JAR and some example files configured for *NIX.
File comment: *NIX version of Dev65
Dev65.zip [494.18 KiB]
Downloaded 66 times
PostPosted: Fri Aug 15, 2014 11:27 pm
Ooh, I like the two column idea. HXA puts those one after the other, which seemed reasonable but I like your idea better. I will investigate how easy it would be to...uh...borrow that :P
PostPosted: Sun Aug 17, 2014 7:22 pm
I emailed the author but didn't expect a response since he has stopped maintaining it. He explained that the address in the listing is the address before the command is evaluated. The macro changes the address with .org but it is already too late at that point.
It doesn't look like there is any way to do what I'm trying to do, at least with this assembler.
Sure there is. The answer is right there. Here's your original macro:
.macro var name,address
name=address
.org address
.res 1 ;reserve one byte
.endmacro
.org $2000
var foo,$3000
var bar,$3001
When "foo" is invoked the value of the program counter is $2000, so that's what it is when "name=address" is encountered. So that's what you see in the listing.
"foo" then sets the program counter to $3000 and adds one by virtue of ".res 1". So when "bar" is invoked the value of the program counter is $3001 when "name=address" is encountered. So that's what you see.
You see? "bar" shows the value you expect not because it does anything differently than "foo", but because a side effect of invoking "foo" is to set the program counter to that value.
You should re-arrange the body of the macro so that the program counter has the value you want when "name=address" is encountered. Say, by moving the ".org" line before it.
PostPosted: Sun Aug 17, 2014 7:47 pm
Edit - ignore this post, I was mistaken!
Unfortunately, it seems not to be that easy. The address as reported in the listing doesn't respond to changes to * within macros, even though all the machinery is proceeding as it should:
000000r 1               .feature pc_assignment
000000r 1
000000r 1               .macro var name,address
000000r 1                  .local tmp_star
000000r 1                  tmp_star=*
000000r 1                  *=address
000000r 1                  .res 1 ;reserve one byte
000000r 1                  .export name:=*
000000r 1                  *=tmp_star
000000r 1               .endmacro
000000r 1
000000r 1               *=$2000
002000  1
002000  1               .data
002000  1  xx           var foo,$3000
002000  1  xx           var bar,$3001
002000  1
002000  1               tmp_star=*
002000  1               *=$3002
003002  1  xx           .res 1
003003  1               .export baz:=*
003003  1               *=tmp_star
002000  1
002000  1               .code
002000  1
002000  1               start:
002000  1  EA            nop
002001  1  AD 01 30      lda foo
002004  1  8D 02 30      sta bar
002007  1  60            rts
PostPosted: Sun Aug 17, 2014 7:49 pm
Oops, sorry, you're quite right - I was being too clever in restoring * within the macro.
Edit: double oops, this actually shows that there's still a problem. The listing shows the address before the macro executes.
000000r 1
000000r 1                  *=address
000000r 1               ;  *=tmp_star
000000r 1               .endmacro
000000r 1
000000r 1               .data
000000r 1  xx           var foo,$3000
003001  1  xx           var bar,$3001
003002  1
003002  1               tmp_star=*
003002  1               *=$3002
003002  1  xx           .res 1
003003  1               *=tmp_star
003002  1
003002  1               .code
003002  1
003002  1               *=$2000
002000  1
002000  1               start:
002000  1  EA            nop
002007  1  60            rts
002007  1
PostPosted: Sun Aug 17, 2014 8:07 pm
This has no effect. Remember when I said this:
By command I meant the macro itself. In the example the address $2000 is output to the file even before the macro is evaluated.
PostPosted: Sun Aug 17, 2014 10:29 pm
Okay, I see the problem. But first, I think this:
000000r 1                  *=address
000000r 1               .endmacro
should be this:
000000r 1                  *=address
000000r 1               .endmacro
in order to match the original macro. As written these values seem one higher than they ought:
002000  1               start:
002000  1  EA            nop
002007  1  60            rts
I note that this (non-macro) code shows exactly the behavior I suggested, as far as addresses go:
003002  1               tmp_star=*
003002  1               *=$3002
003002  1  xx           .res 1
003003  1               *=tmp_star
003002  1
Presumably the macro invocations are doing the same thing internally, but the only address that gets shown is the value at the start of the macro invocation. Which is a reasonable choice; the program counter can have multiple values during the expansion, but on one line the listing can only show one in any case.
So I amend my suggestion to include displaying all the lines of the macro expansion, not just the one that invoked it. I don't see any obvious way to do that with ca65, but I don't know it intimately so there may be one.
PostPosted: Mon Aug 18, 2014 12:48 am
Indeed, a more verbose form of listing would do the trick, but I didn't see how to do that.
