Justin wrote:
sci4me wrote:
I would like to start working on a SBC with probably a 6502, because the more I get into the 6502 the more I want to actually create a computer with one. Hope I can do it for 150 bucks... or so.
You certainly can. I just built one. The parts order from Jameco was just over $100. Most of that cost was wire wrap sockets & hardware. The chips are cheap.
Strangely enough, even though I wasn't trying to be economical when I designed it, POC V1.1 worked out to about 150 dollars a copy, including the PCB. I used ExpressPCB's four-layer Proto-Pro service to get the PCBs made, which at the time (spring of 2012) cost about 202 dollars per order. Four boards are made per order, so the per-board cost was $50.50. Total on all the parts, including the pricey Dallas 1511 RTC/watch-dog, was a hair over 100 dollars, including shipping. I have parts to build more copies.
File comment: POC V1.1 PCB Layout
Additional cost was incurred with the SCSI host adapter, but that item isn't needed to make the computer operate.
File comment: POC V1.1 w/SCSI Host Adaptor
I followed Garth's tutorials and it worked the first time (minus a small issue with the reset circuit). Just be patient and careful. I built mine over a couple of weeks and made sure to do lots of checking both of the schematic on paper and continuity testing of the wiring before inserting the chips.
In other words, no haste resulted in no waste.
