It is currently Sun Nov 24, 2024 9:27 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Fri Mar 07, 2008 5:44 pm
From Lambda the Ultimate blog: http://www.uni-koblenz.de/~laemmel/expression/
PostPosted: Sun Mar 09, 2008 3:37 pm
dclxvi wrote:
I agree. One thing I've done when writing self-modifying code is only make one change at a time from non-self-modifying to self-modifying, then test that change. Then, if it goes off into the weeds and pretty much clobbers everything in RAM (hey, it happens :)), I know where to look, and it's usually not too difficult to spot my error. On a related note, another principle I try to adhere to is don't get too clever too quickly. In other words, if it's really wild, start with something simpler and make small changes. Using those principles, self-modifying code doesn't seem (to me) to be significantly more difficult to debug than other code.
Yeah, I take it in steps as well. I usually write out the code in unoptimized easy to understand version, then rewrite it from scratch for self modifying version. The emu debugger I use is great though and very accurate.
 Post subject: Re: Self modifying code
PostPosted: Thu Oct 29, 2015 7:07 am
I was looking around to see what others have done with self-modifying code, toying with the idea of writing a 6502/816-oriented article on it. [Edit, 6/17/19: Written and posted.] The more I look, the more I think there's a good amount of power available there that most of us have only scratched the surface of. Besides needing to finish up some other things, I need a rest from writing, and I need to get back to building. But if someone else will write a good 6502/816-oriented article on self-modifying code, I would definitely like to link to it on my links page, because this material needs to be clearly documented and available to everyone. It should gather and organize as much knowledge as possible on the subject, and give links and credits. This topic here can be a collection point, although it will lack organization.
PostPosted: Thu Oct 29, 2015 1:27 pm
Coming from AVR, it's almost ironic to call it "Self Modifying Code" at all. I see the 6502 as being a processor with 256 fast registers and 65280 slow registers!
Code, or data... it doesn't matter. It's just 64K that can be used to accomplish a given task.
On the AVR, writing to the Program Memory does have its consequences, since you are dealing with Flash. Slow write times, wear leveling, etc.
I am just a 6502 newb, but in my fresh opinion, "Self Modifying Code" makes absolute sense when you consider how much optimization it offers - both speed and code size. Is it more complex?... garbage in, garbage out!
Brad
PostPosted: Thu Oct 29, 2015 2:54 pm
Most of the code I write is intended for ROM so self modifying code is not really applicable but I have used it a few times.
PostPosted: Thu Oct 29, 2015 2:55 pm
When I was first working with 6502 assembly, I didn't know any better, so, I wondered why anyone would bother using STA ($00),y unless the code was in ROM. I always used STA $0000 and changed the operand bytes to my destination location.
As a matter of principal, I just don't do that anymore.
Once in a while, I think about using it to effectively JSR indirect, but, I never actually end up doing it.
PostPosted: Thu Oct 29, 2015 3:35 pm
One place where I used self-modifying code extensively was in a graphics library for the PC. Rather than have a conditional to determine the raster op, I had the code hardcoding the raster op using self modification. It sped up the graphics enormously (by eliminating all the branches).
http://www.finitron.ca
PostPosted: Thu Oct 29, 2015 7:46 pm
Mike Naberezny did something like that to scroll a window that was only part of the screen on the PET.
The CMOS 6502 does have STA(zp), an indirect without the indexing, taking 5 clocks rather than 4 like STA abs.
PostPosted: Thu Oct 29, 2015 9:54 pm
I've been guilty of using self-modifying code over the years, but am always mindful of the potential booby traps such code can bring. Indeed, modifying an absolute address so as to avoid the time penalty of indirect access is an excellent way to speed up video access. The 65C816 in native mode lessens the value of such a tactic, however, since one can cover a 64K address space with a 16 bit index using something like LDA $00,X.
In the UNIX environment, self-modifying code is not allowed, although it was at one time. An attempt to write into the code segment of a running process causes a memory access violation, followed by a core dump and forced termination of the process.
PostPosted: Mon Nov 02, 2015 2:33 am
Self-modification can speed up dispatch points, and I don't think that's a problem.
I also have some round-robin code in one of my projects. Each routine gets a pass per frame or per interrupt, depending on whatever's active. The first instruction of the routine is "BIT nextRoutine" when enabled, which gets self-modded to "JMP nextRoutine" when disabled. I do similar in interrupting AcheronVM. Rerouting flow of control is really low overhead this way, as no checks are involved in the standard case. Changing a single instruction opcode costs exactly the same as setting a variable/flag to a particular value.
PostPosted: Thu Nov 12, 2015 6:19 am
Why wouldn't you use a macro that takes parameters instead of self modifying code? It is much cleaner and safer.
PostPosted: Thu Nov 12, 2015 6:35 am
A macro is an assembly-time function. Self-modifying code is a run-time function.
PostPosted: Thu Nov 12, 2015 5:05 pm
I've used loads of self-modifying code in my time, the target platform being the BBC Micro, running code out of RAM.
One example was a sprite routine which ran in the zero page which self-modified plenty of its own operands (the self-modified address being in zp as well, saving another cycle). Here's a snippet of the innermost bit of the loop:
innerloop:
read:
    LDA $FFFF,Y    ; self-modified
    STA maskindex+1
maskindex:
    LDA masktable  ; page-aligned table
write:
    AND $FFFF,Y    ; self-modified
    ORA maskindex+1
    STA (write+1),Y
    INY
etc
That reads sprite data (from (read+1)), looks up a mask for it in a pre-prepared table, masks the screen background, ORs the data over the masked screen data, and writes it back. I figure that the self-modification there saves 4 cycles per byte, which for this particular game saved up to 4900 cycles per frame from just that, plus other more modest savings elsewhere - not bad!
I also remember using them to self-modify the branch destination when entering an IRQ service routine, so that consecutive timer interrupts would go to different places in the code without needing to explicitly check it.
PostPosted: Thu Nov 12, 2015 6:04 pm
That inner loop looks pretty intense, Rich! A self-modifying ISR is a cool idea as well, as long as you stay on top of things and don't get out of sync.
Mike B.
Users browsing this forum: John West and 3 guests
