Keenid2 wrote:
Bill:
I stumbled across your work when I was getting LUCIDATA PASCAL running on a FLEX emulator (SWTPCemu.exe), and I am very impressed by what you have been able to accomplish.
Thank you.
Keenid2 wrote:
I am focused more on the 6800 implementation, a couple of questions:
1. What emulator did you use? Reason I ask is when I try to run the PASCAL compiler in SimH (with the --swtpc option, it can't seem to write the .SCR files. SWTPCemu.exe worked correctly.
2. Do you have a complete disassembly of the runtime system for LUCIDATA PASCAL version 1?
Regards,
Keenid
1. I use my own emulator.
2. I did not disassemble the code for "paged mode" to run programs in limited memory. There are a couple of P-codes which are apparently for use by the compiler. I do not understand those yet.
I put a copy of my document for what I know so far on GitHub:
https://github.com/BillGee1/P-6502Attached is the latest listing of my disassembly. *** Well, I cannot seem to be able to attach the file ***
