Apple IIGS GSOS 6.0.1 source
handyandy
Post by handyandy »
At the request of someone from another family of 6502-based computers (Atari) with a retro-fitted 65816 hardware enhancement, I searched for and found the source for the 16 bit operating system GSOS for the Apple IIGS:
https://archive.org/details/GSOS_6.0.1_source
If nothing else, it's a good resource for writing code for the 65816 in assembly language.
Andy
Re: Apple IIGS GSOS 6.0.1 source
Oh yes, always good to see a big chunk of solid code. Here's a snippet from HS.FST.src indicating both a calling convention and a documentation convention:
*	 Name:	Appl_call
* Description:	Entry point for	all application	calls.	Called by GS/OS	only.
*		Validates call before passing control to call handler.
*     Created:	Oct 6, 1987
*    Modified:	Mar 5, 1991
*      Author:	Bryan Atsatt
*	Entry:	jml
*	Input:	A = undefined
*		X = call number	times 2
*		Y = class number times 2
*		P = nvmxdizc
*		    ..000...
*      Output:	A = error code if carry	set
*		X = undefined
*		Y = undefined
*		P = nvmxdizc
*		    ..000..1 = error
*			   0 = no error
*	 Exit:	jml sys_exit
*	 Uses:	Everything!
and a simpler example:
*	 Name:	add_separator
* Description:	This routine will insert a class 0 or 1	separator at the
*		beginning of the gstring pointed to by X and Y.
*     Created:	Nov 6, 1987
*    Modified:	Nov 6, 1987
*	Entry:	jsr
*		X = low	byte of	pointer	to gstring
*		Y = high byte of pointer to gstring
*		P = nvmxdizc
*		    ..000...
*		B = K
*		class			;class of call.
*      Output:	A = undefined
*		X = undefined
*		Y = undefined
*		P = nvmxdizc
*		    ..000...
*		B = K
*	 Exit:	rts
*	 Uses:	all registers
*		input_string
*		length
