Thanks all for the warm welcome and quick replies!
Also, in case you're not connecting /DSR, /DCD, & /CTS lines anywhere (e. g. if you're probing your UART with a logic analyzer, or using USB-UART converter), you should tie them low, otherwise they will prevent you from sending/receiving the data.
Andrew, is this also the case for the W65C51N? I should have been more specific in my description. I am using all current production CMOS ICs from WDC. Either way, I will run my test program again after grounding those lines.
On the subject of the LCD, let met suggest going through
http://wilsonminesco.com/6502primer/LCDcode.asm which has LCD code in several forms, particularly the part about writing the functions set three times, to get an always-reliable setup. We had occasional problems at work until an applications engineer sent us code that showed this, which is information that you don't get in the data sheets.
Mr. Wilson, I
knew that you had example code for this somewhere but couldn't remember where when I was troubleshooting the LCD. Thanks for reminding me! Given that I was able to get it printing at all I was fairly sure that my problems were just software. I did wonder about using a MOSFET gated by the RESb signal to power down the LCD during reset to clear the LCD controller's internal state. But my experiments with that approach have proved unfruitful thus far.
As for your address decoding, I do notice one or two problems here. You've avoided the pitfall of qualifying the ACIA's CS lines with Phi2 (though really the RAM chip doesn't need this either), but the RAM chip is decoded to be active across all addresses below $8000 - and only the /OE line tied to A14 prevents it from conflicting the data bus when reading your devices.
Chromatix, Mr. Wilson is correct in that I am only using 16k of the 32k RAM as in his example SBC schematic. I followed the
address decoding example in the 6502 Primer so any errors in implementation here would be from my own ignorance/inexperience. But if I understand it correctly then I shouldn't have to worry about any bus contention between my RAM and IO.
There's another important point, which is that a normal RS-232 port (such as on the back of a PC) uses very different voltage levels than the ACIA. NEVER directly connect the ACIA to a serial port - it will be damaged.
This is a great reminder. I am aware of this and all of my testing has either been with a logic analyzer or a cheap TTL FTDI to USB adapter.
Thanks again to everyone for responding to my questions so quickly. I will try out the suggestions soon and report back.
