DerpymanMT wrote:
Hey all! I’ve just gotten my parts, but now I’m in more of a doozy, I have check Garth’s primer as everyone suggests to, and the clock circuit needs a 68pf capacitor and a 5.6k resistor, but with the limited budget and me forgetting to get it, I don’t have it, I have a 1mhz 4 pin crystal oscillator but it just won’t output clock for the w65c02s and I was told that the CPU can take that.
Be sure to read the notes under the circuit there at the top of the circuit potpourri page. There are several clock options. The 68pF and 5.6K are only for if you're using an RxC clock. You won't want them if you're using a crystal oscillator.
The resistors that I have only go up to 3k and my capacitors say 22 and 104. If the primer was asking for electrolytic capacitors, are only 100uf and 10uf is there anything I could do to remedy this situation, I do have things I could take parts out of but I wouldn’t count on it...
If you have a 5V regulator right near the computer circuit, you probably won't need the electrolytics. Their value is not critical anyway, and you stray quite a ways in either direction and not notice any effect. (That's not the case with the 68pF above though. If you use the RxC oscillator (which WDC no longer recommends), the frequency will be approximately inversely proportional to the value of that capacitor.)
