I see mention of pulling BE up to Vcc, but no mention of doing so with RDY, IRQB and NMIB. None of these can be allowed to float.
Oh forgot to mention, I did put a pull-up 3k3 resistor for these pins too.
Welcome!
Hmm, A15 might be going at about 7Hz - that's very fast for a flicker but I think you should see it. It's much too low for a sound to be heard. But somewhere in the middle of the address bus, A6 to A9, maybe you should hear an audio tone?
Can you build a little divider out of TTL? Or do you have a frequency readout on a multimeter?
So i tie the higher address byte up until A15, and it does flicker. I also tested it with 1.8432Mhz oscillator can and it's indeed oscillates almost as twice faster.
I don't have an oscilloscope, but I do have an arduino, so I used the processing-oscilloscope to measure the frequency and look at the duty cycle for each of the signal, it does have a limitation being that it can't read past 1Khz properly, but so far the frequency from A15 to A8 doubles i.e. (A15 -> 7.4Hz, A14-> 14.8Hz and so on until A8).
At 1MHz, with LEDs on only the 8 address lsb's (since you said, "3. Connect the lower address bus to the 8 LED's."), the flashing will be too fast to see it, so yes, it will look like they're on all the time. At 1MHz, 2 cycles (for NOP) goes by in 2µs, meaning A0 will cycle on and off at 250kHz, A1 at 125kHz, ... and A7 at almost 2kHz!
Be sure to go through the 6502 primer, which about building your own 6502 computer, covering many aspects, at
http://wilsonminesco.com/6502primer/ .
Thanks for the link garth, there's still topics that I have yet to go through, but I've read the section that concerns with my progress so far.
So I took a leap of faith and venture to put an UART chip in it after burning the eeprom (atmel 28c256). Unfortunately, the ones I ordered is the latest w65c51 chip (with the lot no. A6A749.1 1016G015), and checking out the forum, there is a well known Xmit bug in it that prevents the bytes to stream to the receiver.
I am using an ft232rl usb to ttl chip to communicate with the UART, and I'm still referring to this schematic along with the code that was used
http://www.grappendorf.net/projects/6502-home-computer/acia-serial-interface-hello-world.html, but just to be sure, if I were to modify the code to circumvent the xmit bug in the 65c51, would the code below works?
.setcpu "65C02"
ACIA_DATA = $0000
ACIA_STATUS = $0001
ACIA_COMMAND = $0002
ACIA_CONTROL = $0003
.segment "VECTORS"
.word nmi
.word reset
.word irq
.code
reset: jmp main
nmi: rti
irq: rti
main:
init_acia: lda #%00001011 ;No parity, no echo, no interrupt
sta ACIA_COMMAND
lda #%00011111 ;1 stop bit, 8 data bits, 19200 baud
sta ACIA_CONTROL
write: ldx #0
next_char:
wait_txd_empty: lda ACIA_STATUS
and #$10
beq wait_txd_empty
lda text,x
beq read
sta ACIA_DATA
jsr delay_6551
inx
jmp next_char
read:
wait_rxd_full: lda ACIA_STATUS
and #$08
beq wait_rxd_full
lda ACIA_DATA
jmp write
delay_6551: phy
phx
delay_loop: ldy #1
minidly: ldx #$68
delay_1: dex
bne delay_1
dey
bne minidly
plx
ply
delay_done: rts
text: .byte "Hello World!", $0d, $0a, $00
and I compile it using ca65
ca65 -o firmware.o -l firmware.lst firmware.s65
cl65 --cpu 65C02 -C firmware.cfg -t none -o firmware firmware.o
