Bregalad wrote:
Wire-wrapping is nothing new or revolutionary and had been there for decades.
Yeah, I was sort of making a joke. Sarcasm.
![Smile :-)](./images/smilies/icon_smile.gif)
Bregalad wrote:
It's great but the main 2 problems are that 1) you need sockets for everything,
Sockets are needed and like stated before, they can be very expensive. Especially PLCC sockets.
Bregalad wrote:
2) it's extremely though to debug.
I don't see how it could be any more difficult than point-to-point soldering. Whenever I finish a run of wire, I always test it with my multimeter. Plus, I check the entire bus frequently as I go along to make sure I didn't break something.
Bregalad wrote:
However you still need to solder at least 2 pins on each socket so that they hold mechanically, don't you ?
I started a wire-wrapped computer a while back and I did that. I soldered a pin on each wire-wrap socket. I *really* wished I hadn't done that. I've started another wire-wrapped computer and so far I haven't soldered any sockets at all. I find the wire-wrapping is so strong, that the socket actually feels soldered on. Think about it, you typically have 16, 24, 28, 40, etc. pins each with a solid connection. The first wire I put on the pin, I try to make sure it's flush with the board. That keeps it from flopping around.
Now, going back to my first wire-wrapped computer...the one with the soldered pins. I've been trying to take it apart for hours. I've cut wires, "un-wrapped" them with my wire-wrapping tool, etc. It's incredible how secure those wires are.
When trying to de-solder the pins, I've managed to break a couple of them. Which REALLY sucks since some of these sockets are $5 each.
Fortunately, you can buy a row of pins from Jameco for a few dollars. I can then pull the pin out of those and repair the more expensive sockets.
So, in my new wire-wrapped computer, I haven't soldered anything *except* for a few sockets. But NONE OF THE SOCKETS are soldered to the board.
What I did was take some 8 pin wire-wrap sockets and soldered 3.3k resistors on the pins. I then wire-wrap this socket and use it for pull-up lines. I've done the same thing with capacitors.
I find that works pretty well. And, the great thing is that I can reclaim the sockets even easier the next time because none of them are soldered to the board.
Bregalad wrote:
You could also make them hold in place using a different strategy such as paste, though.
No need.
If my computer were going to be moved around a lot, in an environment with lots of vibration, then I might do something different. But like I said, once the sockets are wire-wrapped, they're not going anywhere.
