It is currently Sat Nov 23, 2024 2:05 pm
PostPosted: Sat Mar 18, 2017 4:33 am
I think I understand this, but want to be sure I know exactly what's happening with a hardwired NOP test.
Tell me if this is right:
CPU comes on. I presume the first thing it does is look in a specific address for directions to first instruction. Since $EA is what it finds at this "address", it puts the instruction pointer at address location $EAEA. Thinking it's at this address, it executes the data it finds (NOP). It then advances the program counter, always finding a NOP instruction. It did this until it reaches the last address, after which I presume it starts over, this time at $0000.
Do I have that sequence correct?
Next, if I want to observe the addresses incrementing, can I hook the address bus directly to the GPIO pins of a microcontroller without some sort of buffer? I can't see why not. I'd like to use an Arduino to read the bus, and display the results in a serial terminal.
Can I hook the bus directly to the Arduinos GPIO pins? I figure since everything is CMOS, no real current gets sourced by the CPU, and all is safe. It's this correct?
PostPosted: Sat Mar 18, 2017 4:56 am
Yes.
You can do it that way, but you will probably have to slow the 6502's clock down to really see anything. Otherwise the high digit of a hexadecimal address display will change 122 times per second using $EA. If the 6502 is running at 1MHz, it will be at each address for 2µs if you use $EA, or 1µs for something like A9 (LDA #$A9). The Arduino will read invalid inputs at those time that the address happens to be changing between the Arduino port's set-up time and the hold time. If you can sync them, that won't be a problem; but maybe it's not anyway because the display will be changing too fast to see anything anyway.
PostPosted: Sat Mar 18, 2017 5:10 am
I would have the Arduino do a new line every advance. That way I'd get a list I could read by stopping the computer. I'd probably use a signal generator as my clock in this test, so I could arbitrarily select a slow speed.
PostPosted: Sat Mar 18, 2017 4:26 pm
When I did this several years ago using a 40-pin PIC & serial terminal, each press of the space bar would generate a single clock cycle (starting and ending with clock = high). I would display the contents of the address & data bus as well as the state of the R/W line. Instead of hard-wiring the data bus to 'EA', however, the PIC drove the data bus.
Good luck with your project.
Cheerful regards, Mike
