It is currently Thu Nov 14, 2024 9:45 pm
PostPosted: Fri Dec 30, 2016 6:42 pm
Hello.
My exercise is to understand how this program works. I have some concept how it works but I think my knowledge is not sufficient to explain it properly. I use xasm compiler, did 'Easy 6502 by skilldrick' and have some books but it's not enough. Comments are mine.
Thanks in advance for any ideas.
 opt f-g-h+l+o+
;F - fill the space between memory areas with $FF /255
;G - Atari 5200 mode for hardware register abbreviations
;H - generate Atari executable headers
;L - write to the listing
;O - write to the object file
;U - warn of unused labels
                org $1000 ;ORG - change value of the origin counter
start           equ *
                lda <text ;load the hex value low/high byte of a 16-bit word constant.
           ; czyli laduje 00?
                sta $80 /store value of a register in memory location 80
                lda >text ;high byte
                sta $81
                ldy #0
                lda #$a5  // load value A5 H   165 DEC   10100101 B
                jsr binary ; jump to subroutine
                lda <text
                ldx >text
                jsr $ff80 ;65 408
                brk
binary          sta byte
                ldx #7
bitslp          lda #'0'
                asl byte ;ASL (Arithmetic Shift Left)
                bcc pr   ;BCC (Branch on Carry Clear)
                lda #'1'
pr              sta ($80),y  ;the zero page address is dereferenced, and the Y register is added to the resulting address.
                iny
                dex
                bpl bitslp  ;BPL (Branch on PLus)
                rts          ; return from subroutine
byte            dta b(0)
                org $2000
text            equ *
                dta b(0),b(0),b(0),b(0)
                dta b(10) ; '\n'
                dta b(0)
                org $2E0
                dta a(start)
                end of file
PostPosted: Fri Dec 30, 2016 6:56 pm
The 'binary' subroutine converts the value in A on entry into a string of '0' and '1' characters in the memory area pointed to by $80/$81.
The start code initialises the pointer and loads a test value then calls binary to convert it. The value is stored in 'byte'. An arithmetic shift left is used to extract the most significant bit into the carry flag. It loads a '0' into A before shifting and changes it to a '1' if the carry is set after the shift. X is used to count 8 iterations of the loop. Y is used to index the indirect address in $80/81. When the conversion completes a ROM routine (at $ff80) is used to display the string.
The code could be better. Y is initialised by the caller rather than in the subroutine. The generated string is not terminated so the subsequent print could do something strange.
You could simplify the conversion from:
bitslp          lda #'0'
                lda #'1'
to
bitslp          lda #('0'>>1)
                rol a
Andrew Jacobs
PostPosted: Sat Dec 31, 2016 6:49 am
By changing direction (starting with bit 0 instead bit 7) of you can save an index register and some cycles & space:
start           equ *
                sta $80 ;store value of a register in memory location 80
                sta $81
                lda <text
                ldx >text
                jsr $ff80 ;65 408
                brk
binary        sta byte
                ldy #7 ;************
                lsr byte  ;shift right-most bit into carry********
                rol a      ;shift carry into a, result is either '0'=$30 or '1'=$31
                sta ($80),y  ;store the byte into the buffer that $80 points to
                dey;********
PostPosted: Sat Dec 31, 2016 7:10 am
If the routine is used for screen output only, then it can be done like that without tampering x/y:
binary
   sec
   rol    ;shift the msb out into carry while shifting in an extra index bit
loop   pha   ;save the value on stack
   lda #"0">>1
   rol
   jsr CHROUT;print character on screen
   pla   ;restore value
   asl   ;shift msb out into carry
   bne loop ;if msb was the extra index bit, a is now zero, otherwise continue loop
                    ;by this way all 8 bits of a are processed even if a=0
   rts
PostPosted: Sat Dec 31, 2016 2:09 pm
Thank you very much for an in-depth analysis of my problem. I programmed in high level languages a bit and change the way of thinking is really difficult for me. Now I have to, based on this program, display the hex 8-bit number. I know the relationship between binary and hex numeral system.
Is a good way to count ones and zeros in a loop and display the appropriate hex number? Any other idea doesn't come to my mind.
I have seen examples on the internet but were written in a completely different way. I expect that the task is trivial
Thanks.
PostPosted: Sat Dec 31, 2016 2:20 pm
It is
  1196                        ; Display the value in A as two hexadecimal digits.
  1197
  1198                        TxHex2:
  1199 00:0596: 48                           pha                             ; Save the original byte
  1200 00:0597: 4A                           lsr     a                       ; Shift down hi nybble
  1201 00:0598: 4A                           lsr     a
  1202 00:0599: 4A                           lsr     a
  1203 00:059A: 4A                           lsr     a
  1204 00:059B: 20 xx xx                     jsr     UartHex                 ; Display
  1205 00:059E: 68                           pla                             ; Recover data byte
  1206
  1207                        ; Display the LSB of the value in A as a hexadecimal digit using decimal
  1208                        ; arithmetic to do the conversion.
  1209
  1210                        UartHex:
  1211 00:059F: 20 xx xx                     jsr     HexToAscii              ; Convert to ASCII
  1212 00:05A2: 4C xx xx                     jmp     UartTx                  ; And display
  1213
  1214                        ; Convert a LSB of the value in A to a hexadecimal digit using decimal
  1215                        ; arithmetic.
  1216
  1217                        HexToAscii:
  1218 00:05A5: 29 0F                        and     #$0f                    ; Strip out lo nybble
  1219 00:05A7: F8                           sed                             ; Convert to ASCII
  1220 00:05A8: 18                           clc
  1221 00:05A9: 69 90                        adc     #$90
  1222 00:05AB: 69 40                        adc     #$40
  1223 00:05AD: D8                           cld
  1224 00:05AE: 60                           rts                             ; Done
Andrew Jacobs
PostPosted: Sun Jan 01, 2017 6:53 am
Thanks for showing that HexToAscii routine Andrew! It's 4 bytes shorter than my naive implementation:
  ; .write_hex4
f15a [ 29 0f    ]  and #$0f
f15c [ c9 0a    ]  cmp #$0a
f15e [ 18       ]  clc
f15f [ 10 04    ]  bpl +4 ($f165)
f161 [ 69 30    ]  adc #$30
f163 [ 10 02    ]  bpl +2 ($f167)
f165 [ 69 57    ]  adc #$57
f167 [ 4c 0d f0 ]  jmp $f00d    ; .write_char
  ; .write_hex4_andrew
f16a [ 29 0f    ]  and #$0f
f16c [ f8       ]  sed
f16d [ 18       ]  clc
f16e [ 69 90    ]  adc #$90
f170 [ 69 40    ]  adc #$40
f172 [ d8       ]  cld
f173 [ 4c 0d f0 ]  jmp $f00d    ; .write_char
Is the decimal flag cleared upon interrupt or should I be clearing it in my interrupt handlers?
PostPosted: Sun Jan 01, 2017 7:35 am
Happy New Year to everyone!
NMOS doesn't clear decimal flag on IRQ/NMI/BRK/Reset - if you use ADC/SBC in ISR you should clear it there. CMOS has corrected this "feature".
http://www.6502.org/tutorials/decimal_mode.html#5
PostPosted: Sun Jan 01, 2017 7:38 am
Hyc, did you have a look here:
http://www.6502.org/tutorials/ - the tutorials of this site
http://codebase64.org/doku.php?id=base:6502_6510_coding - this site might be useful, too (overall it's target is Commodore 64, but this section is 65xx-coding in general).
PostPosted: Sun Jan 01, 2017 9:24 am
A more traditional approach to converting a nybble would be
ora  #$30
cmp  #$3a
bcc *+4
adc  #$06
Andrew Jacobs
PostPosted: Sun Jan 01, 2017 10:26 am
BitWise wrote:
A more traditional approach to converting a nybble would be [...]
And better too, because you can actually understand what's happening.
PostPosted: Sun Jan 01, 2017 11:53 am
The traditional way to convert a hex nibble
   ora #"0"
   cmp #"9"+1
   bcc done            ;skip next op if no further adjustment is needed
   adc #"A"-"9"-2   ;one less because of carry is set
done
takes 8 bytes and 8 or 9 cycles - an alternative would be:
       CMP #$0A
       BCC SKIP
       ADC #$66 ; Add $67 (the carry is set), convert $0A to $0F --> $71 to $76
SKIP EOR #$30 ; Convert $00 to $09, $71 to $76 --> $30 to $39, $41 to $46
The way unclouded posted
   sed                 ;enter BCD mode
   clc
   ADC #$90        ;Produce $90-$99 (C=0) or $00-$05 (C=1)
   ADC #$40        ;Produce $30-$39 or $41-$46
   CLD                ;Leave BCD mode
takes 7 bytes and 10 cycles.
Smaller and faster would be
   SED
   CMP #$0A
   ADC #$30
   CLD
with 6 bytes, 8 cycles. It relies on 6502's treatment of illegal BCD numbers.
Even faster but a lot longer by using a table
   tax
   lda hextab,x
hextab .asc "01234567890ABCDEF"
with 19 bytes and 6 cycles. Or 7 if table is not properly aligned and crosses page boundary.
PostPosted: Sun Jan 01, 2017 12:03 pm
Keep in mind that on the 65C02 the ADC instruction takes an additional cycle in decimal mode.
