It is currently Sun Oct 06, 2024 7:39 pm
PostPosted: Tue Apr 26, 2016 3:54 pm
Some of the regulars here might remember me...I started designing and building my first 6502-based board back around 2004. And because of any number of things (mostly life events), I never got it finished.
Thankfully, things are better now. :)
I finally bought an oscilloscope about a month ago and started building up the breadboard again. A scope is an invaluable tool...I never would have been able to debug without it! I've learned a lot, both on my own and from the people I've spoken to on these forums. It was quite an amazing feeling to finally get characters echoed back to me after I typed them in the terminal.
Just wanted to thank everyone for helping and pointing me in the right direction. I would have had that much more trouble without you. :D
Next I'll go about testing my RAM chips, and then work on getting a cc65 target completed. After that I'll start working on an IDE interface and enough code to start a simple OS. I will be around here more often again, probably asking more questions...but hopefully I can give back too.
PostPosted: Tue Apr 26, 2016 5:08 pm
When will we being seeing some pictures? :)
PostPosted: Tue Apr 26, 2016 5:34 pm
I've attached the only pictures I've taken so far...I'll take some more as time goes on and it does things more interesting than just echoing characters!
The parts list:
  • Rockwell R65c02
  • WDC 65c51
  • CAT28C64 (8k ROM)
  • 74HC138 (memory decoding)
  • 74HC04 (Inverter)
  • Toshiba TC55328P (32k RAM)
  • 74HC00 (R/W signal)
  • 1.8432MHz oscillator (both PHI2 and ACIA input)
File comment: Finally some echoed output
File comment: The main breadboard - wiring nightmare
File comment: Too much for one board...
PostPosted: Tue Apr 26, 2016 5:42 pm
Great contrast there between the original board and the overflow board! Happy to hear that you got your project working - seems like you left off before some long-standing members even joined up here, including me.
PostPosted: Tue Apr 26, 2016 6:07 pm
Great job on solving the issues on wiring :)
And I can sign on the statement that oscilloscope is the tool for a hacker, you've gotten in to using it quite well in short span of time too ;)
Users browsing this forum: Google [Bot] and 4 guests
