It is currently Sat Nov 16, 2024 12:09 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jan 02, 2015 8:09 pm
Found a copy of the schematic:
http://web.archive.org/web/201206281353 ... _schem.pdf
PostPosted: Sat Jan 03, 2015 2:41 pm
Cool, thanks!
PostPosted: Mon Jan 05, 2015 10:56 pm
ArnoldLayne wrote:
Unfortunately, the link to the schematics seems to be dead.
If this can't be resolved then I'll upload the schematic myself. I'm out of town right now but have a copy on my machine at home.
Personally I find the VIA-SPI idea very appealing. It`s just a small amount of hardware, judiciously applied, and it solves the only problem not soluble by software -- namely, the bottleneck on transmission of the datastream itself.
I have to look up where I stored it, but you can use the VIA to actually easily use for SD-Cards with only a small variation: an additional output to XOR the shift out register. Make sure the last BIT shifted out is always 1, and before you shift out the byte, if the first BIT shifted out is zero, invert the output with the XOR, and also XOR the output BYTE, then shift it. This way you can also work with SPI modes that expect the data on the leading clock edge (and not the following as the VIA/CIA shift registers usually do).
André
PostPosted: Tue Jan 20, 2015 8:36 am
Yay! I noticed our little Project has been added to the homebuilt page! Thanks a lot for that!
In other news: We are concentrating on creating PCB layouts right now, so we will have a (hopefully) stable base for further development without wobbly connections.
Not that much Steck anymore, but still a lot Schwein then.
PostPosted: Tue Feb 24, 2015 11:05 am
Goodbye steck, hello schwein:
http://8bit-gefriemel.blogspot.de/2015/ ... bande.html
Video and sound will follow soonish.
