It is currently Sat Nov 23, 2024 3:07 pm
 Post subject: = vs. :=
PostPosted: Wed May 25, 2022 6:19 pm
What is the motivation in ca65 behind having both = and := for numeric constants?
The documentation says := marks the symbol as a label "so it may be handled differently in a debugger"
https://cc65.github.io/doc/ca65.html#ss6.1
What does that mean; different how?
 Post subject: Re: = vs. :=
PostPosted: Wed May 25, 2022 9:36 pm
My understanding is that labels are present in the output files (before linking) and so a debugger can find them and you can refer to them when linking with other files.
Using = just creates a name while that file is being assembled an doesn't create the label for any subsequent debugger to find.
The upshot is (AIUI), using = will produce smaller .o files which may assemble and/or link faster, but it's not something I've really cared about.
If you want symbols to be global over several files, then use := else use =
PostPosted: Wed May 25, 2022 11:59 pm
Hmm, except it seems you can still export symbols even with defined with "=". In my monitor code, I have this in one file:
.export IBUFFSZ
IBUFFSZ = 256
and I am able to import and use that just fine. Honestly when I wrote it that way I didn't expect it to work, but it does, so I just left it alone.
In general I just tend to declare constants with "=" and actual addresses/symbols with ":=", but I think that's mostly just a personal thing for me and I'm not sure it really makes a difference.
Users browsing this forum: Google [Bot] and 45 guests
