Joined: Sat Dec 30, 2017 3:19 pm Posts: 116 Location: Detroit, Michigan, USA
This thread is starting to sound eerily similar to the problems I had with the 28L92 in my build last year, where for some reason the wrong baud rate table is selected, and so instead of 115.2k bps I was getting 9600 bps. I never did figure it out, and in fact the problem persists even after a complete rebuild (including new breadboards, a different 28L92, and a different PLC44->DIP44 adapter). I ended up just using 38.4 kbps since it's the same on all baud rate tables.
One thing I never did try is port B...my build is on hold right now while I work on an automation project for the house,but once it's back on the bench I may have to give port B a shot.
