Up/Down counter With CUPL http://forum.6502.org/viewtopic.php?f=10&t=8099 |
Page 1 of 1 |
Author: | GlennSmith [ Tue Jun 11, 2024 3:31 pm ] |
Post subject: | Up/Down counter With CUPL |
Hello all, I'm posting 'cos I'm at my wits end... I'm playing with an idea to have a USER stack pointer managed in a CPLD that's also doing some sneaky things like a USER ZP at $0200 (the usual undocumented opcodes & address substitution techniques). The ZP stuff should be OK, I have a state machine that looks like it should work. Where I'm stuck is that I need an 8-bit bidirectional counter so that I can increment or decrement by 1 each time I POP or PUSH my user stack. I've tried many examples found on the web - most of them just do not work. (BTW I use wincupl, as its free and directly supports the Atmel "GAL" type chips 16v8 / 22v10 and the ATF150x chips). I tried going through wiring an U/D counter in digital and using it's CUPL output, but that didn't seem to be correct either... Have any of you programmed such a thing, and can anyone point me in the right direction so that I can make a definite decision as to whether it's worthwhile pursuing on not. The super-fast prop delays of the CPLDs is very enticing, and I'm glad I took the learning curve to already use SPLD for address decoding on my POC-WBC. Thanks, in advance, for any help or insights. |
Author: | GlennSmith [ Tue Jun 18, 2024 8:54 am ] |
Post subject: | Re: Up/Down counter With CUPL |
Hi Gregorio Quote: Do you have something in mind that would work this way? Yes, that's the sort of thing I was looking for. I actually went back "to the drawing board" with digital (the logic design/simulation thingy) and managed to get a working and intelligible routine for the whole 8-bits. Thanks! I'm now pushing the limits of my newly-learned SPLD/CPLD knowledge to try and create my stack management (in page 3), and a "user" page zero (in page 2) in one CPLD device. I have been much inspired by George Foot's (gfoot) post about creating the special Acorn Turbo functions in a 22V10 - thanks George. Garden, motorcycles, sunshine... all keeping me away from my thinking hat at the moment - but I'll be back! |
Author: | GlennSmith [ Wed Jun 19, 2024 6:05 pm ] | |||
Post subject: | Re: Up/Down counter With CUPL | |||
Well, as promised - I'm back! Some success with my project, there are still a few gotchas I need to iron-out, but I thought that I'd publish here anyway to (hopefully) help a few others. Resume: my goal is to have one programmable device to handle a few 'trick' features :
How it (should) work : Three NOP opcodes (0x0B, 0x1B, 0x2B) are used to trigger ZP2, stack PUSH, stack POP respectively. The actual reading/writing is performed using normal ZP instructions, the CPLD logic handles the address 'phishing' and the stack load/save/increment/decrement stuff. The logic became VERY complex if I tried to include the load/save logic in the state machine - so I've reverted to using a single register to read/write the value as an I/O location. Now I need to add the rest of the logic to cope with load/save, and look at the *REAL* timing in real life... (EDIT: added some info on the workings) Here is how I hope the system will work : Code: PUSH (value on stack) State cycles uP Data Bus Signals uP Addr Bus Next State ================================================================== Push0 1cyc Magic Opcode SYNC R N/A Push1 Push1 1cyc Opcode (*) SYNC R N/A Push2 (*) STA, STX, STY : ZP - decrement stack counter Push2 1cyc ZP Address N/A R N/A Push3 - substitute Addr A9=1, A8=1, + Low byte from stack pointer [b] Push3 1cyc data value N/A W (stack ptr) Idle - data is written to ZP3 location. [c] POP (value from stack) State cycles uP Data Bus Signals uP Addr Bus Next State ================================================================== Pop0 1cyc Magic Opcode SYNC R N/A Pop1 Pop1 1cyc Opcode (*) SYNC R N/A Pop2 (*) LDA, LDX, LDY : ZP Pop2 1cyc ZP Address N/A R N/A Pop3 - substitute Addr A9=1, A8=1, + Low byte from stack pointer [b] Pop3 1cyc Mem. data N/A R ZP Address Idle - data is read from ZP3 address. Increment stack counter. [c] ZP2 (user zero page) State cycles uP Data Bus Signals uP Addr Bus Next State ================================================================== Zp0 1cyc Magic Opcode(s) SYNC R N/A Zp1 Zp1 1cyc Opcode (*) SYNC R N/A Zp2 (*) any ZP instruction ? Zp2 1cyc ZP Address N/A R N/A Zp3 - substitute A9=1 on the system AB. [d] Zp3 ?cycles : Actual execution, but in "false" ZP Idle [a] Isolate system DB from uP, place CPLD data on uP DB. ( CPLD <= DB => uP ) [b] The uP adress bus is piped through the CPLD. ( CPLD >= AB => System (+ A9, A8) ) [c] No isolation required, the LDx/STx will read/write from/to the 'false' address in ZP3. [d] Force just A9, hold in place for ?? cycles (depends on the instruction !) use SYNC ? ... and I know that I have also to make sure that I avoid interrupts happening, and all sorts of other gotchas... but a few months ago I didn't have a clue about even SPLDs!
Page 1 of 1 | All times are UTC |
