Hello! I've been trying to use the .LQ extension in WinCUPL to define an input latch for my '816 bank address. According to Atmel's WinCUPL User's Manual:
According to the Devhelp.pdf file in WinCUPL's installation, my ATF1508 indeed supports this extension:
However, I haven't found any examples showing how to configure this latch, specifically its clock. I've tried the following (also with .IOCK and .CKMUX for good measure), which results in the fitter not producing any output / crashing.
PIN 1 = CLK ;
PIN = [DBA0..7];
PIN = [A16..23];
[A16..23] = [DBA0..7].LQ;
[DBA0..7].CK = CLK;
Here is the output from the fitter
Atmel ATF1508AS Fitter Version 1.8.7.8 ,running Tue Jun 27 00:03:46 2023
fit1508 C:\WINCUPL\WINCUPL\BB816.tt2 -CUPL -dev P1508C84 -JTAG ON
****** Initial fitting strategy and property ******
Pla_in_file = BB816.tt2
Pla_out_file = BB816.tt3
Jedec_file = BB816.jed
Vector_file = BB816.tmv
verilog_file = BB816.vt
Time_file =
Log_file = BB816.fit
err_file =
Device_name = PLCC84
Module_name =
Package_type = PLCC
Preassign_file =
Property_file =
Sleep_mode =
Preassignment =
Security_mode = OFF
Pin_keep_mode = ON
Dedicated_input_clock =
Dedicated_input_reset =
Dedicated_input_oe =
supporter = CUPL
optimize = ON
Soft_buffer =
Xor_synthesis = OFF
Foldback_logic = on
Expander =
Cascade_logic = OFF
Dedicated_input =
Output_fast = OFF
Power down pin 1 = OFF
Power down pin 2 = OFF
power_reset = OFF
JTAG = ON
TDI pullup = ON
TMS pullup = ON
MC_power = OFF
Open_collector = OFF
ITD0 = ON
ITD1 = ON
ITD2 = ON
Fast_inlatch = off
Replacing the two lines with only "[A16..23] = [DBA0..7];" gives me an output in the fitter, so I'm pretty sure this extension is the problem.
Has anyone looked into this before? I'm worried about the "Contact Atmel PLD applications" prompt, if it means you need some special incantation to use the functionality.
