It is currently Sun Nov 24, 2024 4:57 pm
 Post subject: Cupl .LQ extension
PostPosted: Mon Jun 26, 2023 10:12 pm
Hello! I've been trying to use the .LQ extension in WinCUPL to define an input latch for my '816 bank address. According to Atmel's WinCUPL User's Manual:
According to the Devhelp.pdf file in WinCUPL's installation, my ATF1508 indeed supports this extension:
However, I haven't found any examples showing how to configure this latch, specifically its clock. I've tried the following (also with .IOCK and .CKMUX for good measure), which results in the fitter not producing any output / crashing.
PIN 1     = CLK ;
PIN     = [DBA0..7];
PIN     = [A16..23];
[A16..23] = [DBA0..7].LQ;
[DBA0..7].CK = CLK;
Here is the output from the fitter
Atmel ATF1508AS Fitter Version 1.8.7.8 ,running Tue Jun 27 00:03:46 2023
fit1508 C:\WINCUPL\WINCUPL\BB816.tt2 -CUPL -dev P1508C84 -JTAG ON
****** Initial fitting strategy and property ******
 Pla_in_file = BB816.tt2
 Pla_out_file = BB816.tt3
 Jedec_file = BB816.jed
 Vector_file = BB816.tmv
 verilog_file = BB816.vt
 Time_file =
 Log_file = BB816.fit
 err_file =
 Device_name = PLCC84
 Module_name =
 Package_type = PLCC
 Preassign_file =
 Property_file =
 Sleep_mode =
 Preassignment =
 Security_mode = OFF
 Pin_keep_mode = ON
 Dedicated_input_clock =
 Dedicated_input_reset =
 Dedicated_input_oe =
 supporter = CUPL
 optimize = ON
 Soft_buffer =
 Xor_synthesis = OFF
 Foldback_logic =  on
 Expander =
 Cascade_logic = OFF
 Dedicated_input =
 Output_fast = OFF
 Power down pin 1 = OFF
 Power down pin 2 = OFF
 power_reset = OFF
 JTAG = ON
 TDI pullup = ON
 TMS pullup = ON
 MC_power = OFF
 Open_collector = OFF
 ITD0 = ON
 ITD1 = ON
 ITD2 = ON
 Fast_inlatch = off
Replacing the two lines with only "[A16..23] = [DBA0..7];" gives me an output in the fitter, so I'm pretty sure this extension is the problem.
Has anyone looked into this before? I'm worried about the "Contact Atmel PLD applications" prompt, if it means you need some special incantation to use the functionality.
BB816 Computer YouTube series
 Post subject: Re: Cupl .LQ extension
PostPosted: Mon Jun 26, 2023 10:33 pm
Looking at the macrocell, this definitely seems to be an option, which points to a cupl syntax problem. From this diagram, my inclination would be to use .CK to define the clock for that latch, but I must be missing something.
PostPosted: Mon Jun 26, 2023 11:19 pm
Just a guess, but since latches have a latch enable input rather than a clock input, does it want ".LE" (like it would for an output latch) rather than any type of ".CK"?
PostPosted: Tue Jun 27, 2023 12:15 am
Try .LE (latch enable).
PostPosted: Tue Jun 27, 2023 6:28 am
Doesn't do the trick:
[DBA0..7].LE = CLK;
Results in a blank output from the fitter
PostPosted: Tue Jun 27, 2023 6:46 am
In cases where the fitter crashes, you can often see a more helpful error message if you run it manually from a command prompt.
Can you post your complete example?
Dave
PostPosted: Tue Jun 27, 2023 12:49 pm
Alright, I've experimented a bunch, and I think I found a solution to my problem. I did not manage to make use of the .LQ extension, but I was able to implement it like this. The code below implements a simplified bank address latch and data bus buffer for a 65C816 (including BANK0 as an example of using the latched outputs). I'm still waiting on my adapter boards so I haven't tested it on device.
Name     test816 ;
PartNo   00 ;
Date     26/06/2023 ;
Revision 01 ;
Designer Adrien Kohlbecker ;
Company  - ;
Assembly None ;
Location  ;
Device   f1508ispplcc84 ;
/* Enable pull ups on JTAG interface */
PROPERTY ATMEL { TDI_PULLUP = ON };
PROPERTY ATMEL { TMS_PULLUP = ON };
PIN 1 = CLK;
PIN   = [DBA0..7];
PIN   = [A16..23];
PIN   = [D0..7];
PIN   = RWB;
PIN   = ! BANK0;
[D0..7] = [DBA0..7].IO;
[D0..7].OE = CLK & !RWB;
[DBA0..7] = [D0..7].IO;
[DBA0..7].OE = CLK & RWB;
[A16..23].L = [DBA0..7].IO;
[A16..23].LE = CLK;
BANK0 = !(A16 # A17 # A18 # A19 # A20 # A21 # A22 # A23);
By connecting A16.L to DBA0.IO, and setting A16.LE to CLK, it implements the correct latching. Now, it uses the latch located at the A16 pin, not the one at the DBA0 pin, but I'm not sure if that makes a difference? :?: I'm wondering if this could impact the propagation delay on downstream signals such as BANK0 when the latch is open. If BANK0's combinatorial inputs come through DBA0's input then internally through the latch at A16, rather than directly through the latch at DBA0. Is there an additional delay due to the path between DBA0 and A16?
Attached is the output of the fitter.
test816.txt [22.8 KiB]
Downloaded 81 times
PostPosted: Tue Jun 27, 2023 1:05 pm
In case this helps to figure it out, here are some of the steps I took. Thanks Dave for suggesting the command line, as the errors are indeed better reported.
A16 = DBA0.LQ;
Gives me a fitter error:
Error - Node DBA0 is latched and there is no .LE or .LH in .olb
If I add to this
DBA0.LE = CLK;
I get the same message, and also cupl.exe reports
[0014cc] Please note: unknown extension encountered:
If I then try to setup the input latch manually with
DBA0.L = DBA0.IO;
I get the same cupl extension error, and the fitter reports
Error on line 27 : Incorrect variable list (variable duplication)
With this PLA input file (line 27 is .phase)
#$ TOOL CUPL
# Berkeley PLA format generated using CUPL(WM) 5.0a
# Serial#  MW-10400000
# Created  Tue Jun 27 15:09:06 2023
#    Name        test816
#    Partno      00
#    Revision    01
#    Date        26/06/2023
#    Designer    Adrien Kohlbecker
#    Company     -
#    Assembly    None
#    Location
#$ TITLE  test816
#$ PROPERTY ATMEL TDI_PULLUP = ON
#$ PROPERTY ATMEL TMS_PULLUP = ON
#$ MODULE  test816
#$ JEDECFILE  test816
#$ DEVICE  f1508ispplcc84
#$ PINS  27 A16+ A17+ A18+ A19+ A20+ A21+ A22+ A23+ BANK0+ CLK+:1 D0+ D1+ D2+ D3+ D4+ D5+ D6+ D7+ DBA0+ DBA1+ DBA2+ DBA3+ DBA4+ DBA5+ DBA6+ DBA7+ RWB+
.i 5
.o 6
.type f
.ilb  CLK D0.PIN DBA0.PIN DBA0.L RWB
.ob   A16 D0 D0.OE DBA0 DBA0 DBA0
.phase 111111
.p 5
---1- 100000
--1-- 010010
1---0 001000
-1--- 000100
1---- 000001
.e
I'm not sure what that means.
