Atmel Porgammer upload software http://forum.6502.org/viewtopic.php?f=10&t=7389 |
Page 1 of 1 |
Author: | A0CBM [ Thu Nov 03, 2022 10:52 am ] |
Post subject: | Atmel Porgammer upload software |
I purchased a program platform from Atmel and would like to find out if there are any open source programs to upload to the programmer. I have WinCUPL and wanted to see how the ATF1504AS works, but I can't upload my PLD file to the programmer. Am I at the mercy of Atmel or is there an alternative? I have an ATDH1150USB-K Download platform. I found something on NuMicro ISP Progamming Tool, but I don't know if that works with my setup. Thank you. |
Author: | 8BIT [ Thu Nov 03, 2022 3:36 pm ] |
Post subject: | Re: Atmel Porgammer upload software |
I'm not absolutely sure about this, but it looks like you need to download the ATMISP software to program the device using that cable. here's a link to a PDF I found on the cable which has a link to the software in it. https://ww1.microchip.com/downloads/en/ ... rGuide.pdf My guess is you compile your logic using WINCUPL and then you would select the .JED output file within the ATMISP software to program the device. best wishes! Daryl |
Author: | BigDumbDinosaur [ Thu Nov 03, 2022 7:07 pm ] |
What Daryl said.
Within ATMISP, you will need to set up a programming “chain” for the ATF1504AS. Just follow the prompts. Attachment: Attachment:
Page 1 of 1 | All times are UTC |
