It is currently Sun Nov 24, 2024 10:39 am
 Post subject: Atf16v8, atf22v10
PostPosted: Sun Aug 07, 2022 4:13 pm
Hi,
just another short question. I’m just playing around with the named devices.
Does anyone know the Output current on High and Low for the output pins?
I find some in the data sheet,but I’m not sure, if they are right.
I try to implement a double bin2hex converter, directly driving 2 7-Segments LED Displays.
The Displays, I have, can be driven with 30mA, but 10mA is sufficient. But the cathode will than have 80mA and as one pin will be the cathode for that display, so it must absorb all the current. ( ok, only fr half of the time, as the other pin will take the second display) otherwise I have to use a single FET Switch.
don't count on me, i'm engineer (Animotion)
my arduino pages: http://rcarduino.de
 Post subject: Re: Atf16v8, atf22v10
PostPosted: Sun Aug 07, 2022 4:27 pm
Is there some reason you doubt the Atf16v8 and atf22v10 data sheets? Just curious.
As for your display, I gather you'll have two 7-segment digits of the common Cathode type. So, there are two signals -- those which drive the common cathodes -- which must supply the high current. This can be accomplished by using some sort of buffer between the CPLD and the common cathodes. A couple of discrete transistors -- one for each signal -- would do the trick. :)
Alternatively, there are various ICs which could do the job. Example: A 74AC240 or '244. On each half, you'd connect the four inputs together and the four outputs together in order to quadruple the current capability.
PostPosted: Mon Aug 08, 2022 8:45 am
For me it's not clear, if the term:
IOS(1) Output Short Circuit Current VOUT = 0.5 V -130 mA
is the term per Output pin?
or
ICC Power Supply Current, Standby ?
I simply have problems if this terms means per pin or overall?
I have both types, 8 with common cathode, but a little bit too small, some with common anode, bigger ones. But that's not a problem with the CPLD. Simply negate all output pins... The question is still, can an output of the ATF22V10 handle 80mA current in both directions?
Thats what i meant with
But with common anode it's not so easy, because i have no P-Channel FET in stock...
I wanted to avoid that. I didn't want to place another order. :mrgreen:
Meawhile i have done this without any other parts involved. Simply a ATF22V10C, 2 common anode 7-segmant displays, and 7 150Ohm resistors. works, the chip even get warm.
Just put the actual wpld as attachment, for anyone who likes to use it.
dualhex7seg.zip [1.01 KiB]
Downloaded 86 times
PostPosted: Tue Aug 09, 2022 12:16 am
I haven't looked at the ATF22V10C specs, but the outputs are probably quite a lot stronger when pulling low than when pulling high. That suggests that you'd do "better" using common cathode displays. (I'm assuming you only use the parts you have on hand, and aren't willing to add a FET, a BJT or an IC to act as a buffer.)
But you've already gotten the project working, so maybe "better" doesn't matter! :P Common cathode displays will probably allow you to achieve the same brightness with higher resistor values (thus allowing the CPLD to run cooler), but.... :?:
PostPosted: Tue Aug 09, 2022 4:45 am
The footnote (1) explains that short circuit current is only allowed for 1 pin at a time, and only for 30 seconds.
PostPosted: Wed Aug 10, 2022 8:09 am
I have a lot of stuff here. FET, BJT or ULN2003/2803 are availble. But i haven't got enough 7-seg commen cathode displays...
:roll:
It was just a spare time project, until I found the bug in my 6502 SBC. Sometimes you just need a sense of achievement.
So, with the actual design i have max -80mA on average on the output col pins and 20mA on the other. (with all segments on) The chip is getting warm but not hot.
If i get the common cathode displays, i will use some kind of FET driver for the cols. (As i do this in my 3x3x3 cube)
PostPosted: Wed Aug 10, 2022 10:44 am
You're probably ok with that. The 80 mA has to go through the VSS pin, and the 20mA through the VDD. So, maximum peak current is the 80mA, well below the 130mA.
Note that the chip not getting hot isn't necessarily a sign that all is well. There will be very localized heating in the output driver, so it could very well overheat while the rest of the chip is still cool. High temperatures at the pad might lead to defects in the gold/aluminium transition layer, and cause damage over time.
https://en.wikipedia.org/wiki/Gold%E2%8 ... ermetallic
cron
