It is currently Sat Nov 23, 2024 7:11 am
PostPosted: Wed Jan 26, 2022 8:04 pm
I want to get into CPLDs (and later FPGAs) but am finding getting going to be difficult.
Initially I’d like to tackle address decoding.
I thought I might start with the ATF15xx. But what toolchains do people recommend? I’m platform agnostic (ie, Windows, Linux and Mac all work for me - I’d probably draw the line at System/360).
Are there other CPLDs that are good for beginners (eg, well supported with software)? I’d prefer to go with chips that are still in production.
I like it when things smoke.
BlogZolatron 64 project
PostPosted: Wed Jan 26, 2022 11:25 pm
If you're interested in the Microchip (Atmel) ATF parts—which are in current production—you can snag a copy of WinCUPL from their site to do you development and simulation. WinCUPL runs on any version of Window$ from 2000 onward. The package is a bit buggy here and there, but does work. If you have any trouble getting hold of the software please contact me via PM and I'll try to help.
PostPosted: Thu Jan 27, 2022 8:26 am
Thanks. I've now got WinCUPL installed. It's kinda ... um ... early 1990s, but I guess it does the job.
PostPosted: Thu Jan 27, 2022 3:16 pm
Just about.
I use the following Cygwin bash script to wrap the command line tools, as the GUI is quite awful!
#!/bin/bash
WINCUPL_SHARED="c:/WinCupl/Shared"
# These are documented in http://ee.sharif.edu/~logic_circuits_t/readings/CUPL_Reference.pdf
cuplopts=-jaxf
usage()
   echo "Usage: $0 <pld> <outdir>"
   echo "    where <pld> is the PLD source file"
   echo "          <outdir> is an output directory"
   echo
   echo "The output directory will contain copies of the source files"
   echo "along with all output files, including compiler console output"
   echo "(errors, etc) in <pld_basename>.out."
   echo
   echo "If a corresponding <pld_basename>.si file exists, the simulator"
   echo "will also be run after a successful compile."
f="$1"
if [ ! -e "$f" ]; then
   usage
   exit 1
fi
f_base=`basename "$f" .pld`
outdir="$2"
if [ "$outdir" == "" ]; then
   usage
   exit 1
fi
if [ ! -d "$outdir" ]; then
   mkdir -p "$outdir"
      echo "Output directory '$outdir' is not a directory"
      exit 1
   fi
fi
cp "$f" "$outdir"
if [ -f "$f_base".si ]; then
   cp "$f_base".si "$outdir"
   # Adding the 's' option makes it also run the simulator - it's not in the docs, but
   # I read about it somewhere.  I can't manage to get the simulator to run standalone.
   cuplopts="$cuplopts"s
fi
# Some bits of cupl only work if the files are in the current directory
f=`basename "$f"`
f_base=`basename "$f_base"`
cd "$outdir"
# Remove old output files
for ext in abs doc jed lst out pla sim so wo; do
   rm -f "$f_base.$ext"
done
export LIBCUPL="$WINCUPL_SHARED"/atmel.dl
"$WINCUPL_SHARED"/cupl $cuplopts "$f" > "$f_base".out
# Check and report errors
if [ "$?" -gt 0 ]; then
   # The compiler outputs errors mixed in with its other output, print them here
   grep '^[[]' "$f_base".out
   # If the .so file exists, then the compile succeeded and the simulator was run but failed
   if [ -e "$f_base".so ]; then
      # The simulaton doesn't output errors to the console, only to the .so file
      cat "$f_base".so
      echo
      echo "ERROR: Simulation failed, see errors above"
      exit 1
   else
      # No .so file means the simulator didn't run, i.e. the compile failed
      echo "ERROR: Compilation failed"
      exit 1
   fi
fi
PostPosted: Thu Jan 27, 2022 5:54 pm
That's because it is early 1990s. It's a DOS program that got Windowfied.
PostPosted: Fri Jan 28, 2022 12:09 pm
I'm going to jump in with a question: What if I'm NOT platform agnostic? I see that WinCUPL is Windows (only?) and I'm a Linux guy. Though Windows might be possible, it's not preferable. Likewise Wine has not been my best friend in the past.
Any thoughts on Linux based CPLD/FPGA programming for beginners like me? I'm currently using Quartus 13.0sp1 with EPM7128S CPLD's. I like it well enough, so just asking around.
PostPosted: Wed Feb 23, 2022 4:33 am
You can try the Lattice Diamond package... if you want to stick to Lattice devices... and Red Hat Linux... and version 6.9 or 7.4.... and the 64-bit version. Some people seems to run it under Ubuntu, and I think I tried it a few years ago.
It might not be a good idea, but the package is free and has a simulator bundled with it (at least under windows).
Users browsing this forum: Google [Bot] and 12 guests
