ATF1504 Development Board - Any interest? http://forum.6502.org/viewtopic.php?f=10&t=6771 |
Page 1 of 1 |
Author: | cbmeeks [ Wed Sep 08, 2021 10:07 pm ] |
Post subject: | ATF1504 Development Board - Any interest? |
Fingers crossed that my ATF1508 Dev Board is going to work OK (Rev 1 works with some snafus). If it does, I'm probably going to be done with that design unless I decide to go with the TQFP-100 version. Anyway, I can see the need of creating a 1504 version specifically for glue type logic. Something that could be mounted on a breadboard. However, I could always use my 1508 version and just keep the designs small (or use one of the PLCC-44 to DIP44 adapters) on a breadboard. What are your thoughts? Any interest in something like that or do you guys use them in a different way? Thanks |
Author: | plasmo [ Thu Sep 09, 2021 10:30 pm ] | ||
Post subject: | Re: ATF1504 Development Board - Any interest? | ||
Prototype board based on EPM7064S (same as ATF1504) get lots of use; many designs can easily solved with 64-macrocell CPLD. I'm on my 4th batch of ProtoRC3 (10 boards per batch). Bill
Author: | BigDumbDinosaur [ Sun Aug 14, 2022 8:09 am ] |
cbmeeks wrote: Anyway, I can see the need of creating a 1504 version specifically for glue type logic. Something that could be mounted on a breadboard...Any interest in something like that or do you guys use them in a different way? Bump. Whatever happened with this? |
Author: | cbmeeks [ Wed Oct 19, 2022 6:52 pm ] |
I personally created a couple ATF1508 dev boards that actually worked. The first one had a stupid mistake where I got the JTAG header backwards...lol. But it still worked when I added it to the back of the board. The second one worked as well. However, I put my CPLD activities on-hold because I was tired of using Windows in a virtual machine just so I could use WinCUPL. I found a P4 laptop for $10 or so a while back so I might load it up just for WinCUPL. But I have a confession....I'm contemplating using a Raspberry Pi Pico for some glue logic. Mainly because I have some. |
Author: | gfoot [ Wed Oct 19, 2022 7:05 pm ] |
cbmeeks wrote: However, I put my CPLD activities on-hold because I was tired of using Windows in a virtual machine just so I could use WinCUPL. I found a P4 laptop for $10 or so a while back so I might load it up just for WinCUPL. For what it's worth, I run WinCupl through Wine and it works almost fine. Quote: But I have a confession....I'm contemplating using a Raspberry Pi Pico for some glue logic. Mainly because I have some. I've considered it too, they are very cheap and quite easy to deploy. |
Author: | akohlbecker [ Wed Oct 19, 2022 7:07 pm ] |
For breadboard use, I recently ordered one from the gerbers provided by user banedon here viewtopic.php?f=10&t=5055 |
Author: | cbmeeks [ Wed Oct 19, 2022 8:10 pm ] |
gfoot wrote: For what it's worth, I run WinCupl through Wine and it works almost fine. I tried several times and for whatever reason, it just didn't work. I've been holding off using a micro-controller on my build because I just don't feel they fit the "spirit" of the retro designs I like. But I'm starting to get over that obsession. I'm interested in playing around with the PIO's of the Pico for various things. And at $4 each, it's hard to beat. The downsides being 3.3V and only 26 GPIO. But that's not the end of the world for me. |
Page 1 of 1 | All times are UTC |
