VGA6448, text-based VGA in ATF1504AS CPLD http://forum.6502.org/viewtopic.php?f=10&t=6502 |
Page 1 of 5 |
Author: | maded2 [ Sat Feb 20, 2021 6:48 am ] |
Post subject: | Re: VGA6448, text-based VGA in ATF1504AS CPLD |
very nice. |
Author: | BigEd [ Sat Feb 20, 2021 8:11 am ] |
extra points for using the back of an envelope |
Author: | plasmo [ Sun Feb 21, 2021 2:36 pm ] | ||
Post subject: | Re: VGA6448, text-based VGA in ATF1504AS CPLD | ||
Attached is schematic of VGA6448 prototype. This will be prototyped first on a ProtoRC3. The dual port RAM is mapped to memory 0xD000-0xDFFF. Currently there are RAM in that area already, so I make the DPRAM write only from 6502 side; write to 0xDxxx will write to both DPRAM and system RAM; read from 0xDxxx will read the system RAM. I will utilize 100% of the CPLD I/O pins. A possible alternative is use a 74ACT138 to decode 6502 memory map to free up 6 CPLD I/O pins which could be use for PS/2 keyboard function. This all depends on whether there are spare macrocells after the VGA function is implemented. Bill
Author: | plasmo [ Mon Feb 22, 2021 12:56 pm ] | |||
Post subject: | Re: VGA6448, text-based VGA in ATF1504AS CPLD | |||
Here is the VGA6448 prototype board, all wired up and even smoke tested. So far so good. I only have 3 ATF1504AS but have plenty of EPM7064S, so for hardware development I will use EPM7064S; afterward I can convert .POF file to .JED file to program ATF1504AS.
Author: | cbmeeks [ Mon Feb 22, 2021 10:03 pm ] |
+2 points for literally using the back of an envelope. Now put some glue on it and throw against a wall and see if it sticks. LOL Seriously, this is a great idea. Been looking for some "easy" VGA solutions using CPLD's. |
Author: | plasmo [ Tue Feb 23, 2021 1:52 pm ] |
cbmeeks wrote: +2 points for literally using the back of an envelope. Now put some glue on it and throw against a wall and see if it sticks. LOL Seriously, this is a great idea. Been looking for some "easy" VGA solutions using CPLD's. I don't mind getting junk mails because I reuse the envelopes, and the rest can go into the fireplace. It is an expensive way of delivering paper & fuel, but it is not MY money I'm burning ![]() |
Author: | plasmo [ Tue Feb 23, 2021 1:53 pm ] | ||
This is first cut of the VGA output from VGA6448. The CPLD design is not optimal, but it still fits within the 64-macrocell EPM7064S. PS2 keyboard function is not in the design because all CPLD I/O pins are in use. An external 74138 decode may free up sufficient pins to do PS2 keyboard function. VGA6448 design is fairly generic so can be easily adopted for other 8-bit microprocessors. The left of the picture shows a 5-slot RC2014 backplane with CRC65 (6502 SBC) in the front and VGA6448 behind. This is a 24-second YouTube video shows the "Matrix" screensaver running on CRC65+VGA6448. The ability to read/write video RAM directly at anytime simplifies the software significantly. The "Matrix" animation code is lesser than 256 bytes. https://youtu.be/rQiBJkjPg44 Bill
Author: | okwatts [ Tue Feb 23, 2021 3:36 pm ] |
Looks good Bill, it would be nice to be able to add the PS2 keyboard interface for a standalone. |
Author: | plasmo [ Wed Feb 24, 2021 1:32 pm ] |
PS2 keyboard is highly desirable and I believe it is possible with the addition of 2 '138 decoders, one for the video RAM address select and the other for PS2 address select. Multiple VGA6448 can be populated on a system; one is the system monitor & keyboard, but the others can shadow and display the activities of certain region of memory. Example, the first 2K of memory where zero page and stack are located is a region of interest. Bill |
Author: | maded2 [ Thu Feb 25, 2021 3:50 am ] |
great job. Just wondering how much work to support standard fast sram (10ns) instread of dualport sram. |
Author: | Martin A [ Thu Feb 25, 2021 9:28 am ] |
maded2 wrote: great job. Just wondering how much work to support standard fast sram (10ns) instread of dualport sram. Quite a bit. The data and address busses need to be switched, and possibly latched depending on the relative speeds of the CPU and VGA clocks. Those external components need controlling by the CPLD, and that requires both pins and logic resources. |
Author: | plasmo [ Thu Feb 25, 2021 3:53 pm ] |
Martin A wrote: maded2 wrote: great job. Just wondering how much work to support standard fast sram (10ns) instread of dualport sram. Quite a bit. The data and address busses need to be switched, and possibly latched depending on the relative speeds of the CPU and VGA clocks. Those external components need controlling by the CPLD, and that requires both pins and logic resources. Agree, quite a bit of buffers and tranceivers are needed to turn a single-ported RAM into dual port RAM. |
Author: | plasmo [ Thu Feb 25, 2021 4:25 pm ] |
plasmo wrote: Multiple VGA6448 can be populated on a system; one is the system monitor & keyboard, but the others can shadow and display the activities of certain region of memory. To brainstorm a bit on the notion of shadowing and displaying selected region of memory: VGA6448 is really invisible to the rest of the system. It is a write-only 4K chunk of memory where 1K is font tables and 3K are display memory. It's interface looks like a memory device, 12 lower address for 4K RAM, 8 data lines (input only), chip select, write enable, but no read enable; the upper addresses selects which 4K block that's displayed. It is just a ghost memory displaying content of selected 4K region on a VGA screen. A VGA6448 daughter board can be constructed that plugs into the system RAM socket; the daughter board is consists of the original system RAM, 4K dual port RAM, ATF1504AS CPLD, 25.175MHz osc, and VGA connector. The original system RAM is plugged back in on the daughterboard and the RAM's address, data, control, and power are now driving VGA circuits. This way a VGA capability is added by piggy backing on the existing RAM. Memory map can be programmed such that the top 1K memory is programmable font tables; the other 3K holds 64x48 character memory. Another application for the VGA6448 daughterboard is a memory activity monitor. The font table and character memory are located in two separate regions. Font is likely located in high memory and character memory can locate anywhere in memory space. Font table needs to represent 256 values instead of 128 ASCII character values, so it is 2K in size. The character memory is also 2K. The most likely memory region of interest is first 2K where zero page and stack are located. Program can also place variables in the first 2K to facilitate memory activity monitoring. Looks like an interesting project... Bill |
Author: | sark02 [ Fri Feb 26, 2021 6:36 pm ] |
This is a really nice piece of work. Have you considered using something like a Spartan-3A FPGA to replace both the CPLD and DP RAM combo? It's more of a challenge to solder, and requires multiple voltages, but AFAIK it's I/O can support 3.3V, which is ok for 65C02, and it gives you lots of scope for functionality. I was generally wondering whether home-brew 65C02 builds use lower voltage standards rather than the original 5V. |
Page 1 of 5 | All times are UTC |
