My new verilog 65C02 core. http://forum.6502.org/viewtopic.php?f=10&t=6332 |
Page 1 of 16 |
Author: | BigEd [ Tue Oct 20, 2020 10:17 am ] |
Post subject: | Re: My new verilog 65C02 core. |
Off to a very good start! I'll watch this with interest. |
Author: | Arlet [ Tue Oct 20, 2020 11:13 am ] |
Strange. After adding support for I and D flags, including CLI/SEI/CLD/SED, the slice count dropped to 55. Adding support for CLV, and overflow detection in the ALU, kept it at 55. |
Author: | Arlet [ Tue Oct 20, 2020 11:21 am ] |
A cute feature when running the simulator is that it will print the 3-letter name of the opcode that it is working on. That makes it easier to track with the assembly code of test programs. Code: 0 00.0f8 AB:0400 DB:f8 AH:00 DO:02 PC:0000 IR:00 SYNC:1 BRK WE:0 R:02 M:00 ALU:02 CO:0 S:ff A:41 X:02 Y:03 AM:0 P:--I--- 0 F:00000000
1 01.078 AB:0401 DB:78 AH:f8 DO:fa PC:0000 IR:f8 SYNC:1 SED WE:0 R:02 M:f8 ALU:fa CO:0 S:ff A:41 X:02 Y:03 AM:0 P:--I--- 0 F:01000000 2 01.008 AB:0402 DB:08 AH:78 DO:7a PC:0000 IR:78 SYNC:1 SEI WE:0 R:02 M:78 ALU:7a CO:0 S:ff A:41 X:02 Y:03 AM:0 P:-DI--- 0 F:00100000 3 10.116 AB:0403 DB:d8 AH:08 DO:fe PC:0000 IR:08 SYNC:0 PHP WE:0 R:ff M:08 ALU:fe CO:1 S:ff A:41 X:02 Y:03 AM:4 P:-DI--- 0 F:00000000 4 11.103 AB:01ff DB:2c AH:08 DO:2c PC:0403 IR:08 SYNC:0 PHP WE:1 R:02 M:d8 ALU:da CO:0 S:fe A:41 X:02 Y:03 AM:2 P:-DI--- 0 F:00000000 5 01.0d8 AB:0403 DB:d8 AH:08 DO:da PC:0403 IR:08 SYNC:1 PHP WE:0 R:02 M:d8 ALU:da CO:0 S:fe A:41 X:02 Y:03 AM:0 P:-DI--- 0 F:00000000 6 01.058 AB:0404 DB:58 AH:d8 DO:da PC:0403 IR:d8 SYNC:1 CLD WE:0 R:02 M:d8 ALU:da CO:0 S:fe A:41 X:02 Y:03 AM:0 P:-DI--- 0 F:01000000 7 01.028 AB:0405 DB:28 AH:58 DO:5a PC:0403 IR:58 SYNC:1 CLI WE:0 R:02 M:58 ALU:5a CO:0 S:fe A:41 X:02 Y:03 AM:0 P:--I--- 0 F:00100000 |
Author: | rwiker [ Tue Oct 20, 2020 12:55 pm ] |
This is great! Will this be possible to get running on other FPGA architectures, or will it be completely tied to Spartan 6 & 7? |
Author: | Arlet [ Tue Oct 20, 2020 1:17 pm ] |
rwiker wrote: Will this be possible to get running on other FPGA architectures, or will it be completely tied to Spartan 6 & 7? The goal is to make it generic so that it can be targeted for any architecture, but with the structure of the FPGA in mind. For instance, each little combinatorial block is made so that it fits in 6-input LUTs. It will still work on an older 4-input LUT, but it won't be so efficient. If I need 7+ inputs, I try everything I can to push some of the logic somewhere else. Likewise, when I need less than 6, I try to add some functionality. That's the reason I ended up with a block RAM, because I could not figure out a (good) way to do the instruction decoding with only 6 inputs (especially not with the irregular 65C02 extensions thrown in). When the generic model is ready, I want to try to hand optimize for Spartan, by providing an alternative implementation of some of the modules (that's the main reason for the current, small, modules, such as the ALU, ABL, and ABH), so you can simply remove the generic version of the model, and replace it with the Spartan-6 specific. Somebody else may be able to provide targeted code for other FPGAs. For example, the adder/logic block in the ALU should fit in a single LUT per bit on Spartan 6/7, using 2 inputs for the R/M inputs, and 3 for the operation select bits. When using the carry chain logic, you need two signals (Generate and Propagate). The Spartan 6 can split the LUT6 into a pair of LUT5s to generate those two signals, as long as you restrict yourself to total of 5 inputs. Code: always @(*)
case( op[2:0] ) 3'b000: adder = R | M + CI; 3'b001: adder = R & M + CI; 3'b010: adder = R ^ M + CI; 3'b011: adder = R + M + CI; 3'b100: adder = R + 8'h00 + CI; 3'b101: adder = R + 8'hff + CI; 3'b110: adder = R + ~M + CI; 3'b111: adder = ~R & M + CI; endcase |
Author: | Arlet [ Tue Oct 20, 2020 3:08 pm ] |
More strangeness. Adding one more flop results in now needing 52 slices. Another example of designing with LUT6 constraints: I had a problem with the logic for the C flag update, that required adding an extra input to the mux. The LUT had a free input, but I had already used up all the possible cases for the select signals: Code: always @(posedge clk) if( sync ) casez( {plp, flags[1:0]} ) 3'b001 : C <= 0; // CLC 3'b010 : C <= 1; // SEC 3'b011 : C <= alu_co; // ALU carry out 3'b1?? : C <= M[0]; // PLP endcase But then I realized that the CLC/SEC options are not necessary. Instead, I can use the microcode to instruct the ALU to calculate 00+00+0 for CLC, or 00+FF+1 for SEC, and then combine the first 3 cases by grabbing ALU carry out. |
Author: | Arlet [ Tue Oct 20, 2020 6:28 pm ] |
All NMOS 6502 opcodes have been added, as well as overflow flag handling. Plenty of room left in the microcode ROM. Next step is running Klaus Dormann's test suite (without BCD), and see what's still broken/missing. Update: test suite revealed a couple of errors, mostly in the flag handling. Bugs have been fixed, and it now passes the test (BCD tests still disabled). Reset handler has been added as well. Whenever reset is detected, control is transferred to dedicated microcode address. As soon as reset is released, microcode is executed which copies the reset vector to the address bus. Only a single cycle reset pulse is needed. |
Author: | Arlet [ Thu Oct 22, 2020 6:54 am ] |
I've added support for IRQ. One small quirk is that the SEI/CLI instructions have 1 cycle pipeline delay to setting/clearing the I flag. The effect is that SEI instruction, immediately followed by IRQ on the next cycle will allow the IRQ to be taken. However, the SEI is not lost. The I flag will be set on the stack, so it will return from the interrupt handler with further interrupts disabled. I don't think this should impact any real world code. Had the IRQ arrived one cycle earlier, it would be taken anyway. The only difference is that the interrupt handler may be surprised to find I=1 in the saved status register. I'm just going to leave it like this for now. |
Author: | BigEd [ Thu Oct 22, 2020 8:27 am ] |
Probably true, but perhaps worth checking that CLI; SEI will catch a pending interrupt. |
Author: | Arlet [ Thu Oct 22, 2020 8:33 am ] |
I did check that, and it works. Both CLI and SEI have the same behavior, so that leaves a single cycle opportunity for IRQ to be taken. Code: 5 -I 10.058 MD:0 AB:0405 DB:58 AH:ea DO:ea PC:0404 IR:ea SYNC:1 NOP WE:0 R:02 M:ea ALU:ea CO:0 S:ff A:41 X:02 Y:03 P:--I--- 0 F:00000000 The 'I' at the left means interrupt is pending. The 'I' near the right reflects the flag bit. In cycle 7 the I flag is cleared, and in cycle 9, it starts pushing the PC to the stack.6 -I 10.078 MD:0 AB:0406 DB:78 AH:58 DO:5a PC:0405 IR:58 SYNC:1 CLI WE:0 R:02 M:58 ALU:5a CO:0 S:ff A:41 X:02 Y:03 P:--I--- 0 F:00100000 7 -I 10.0ea MD:0 AB:0407 DB:ea AH:78 DO:7a PC:0406 IR:78 SYNC:1 SEI WE:0 R:02 M:78 ALU:7a CO:0 S:ff A:41 X:02 Y:03 P:------ 0 F:00100000 8 -I 01.189 MD:a AB:0408 DB:ea AH:ea DO:fe PC:0407 IR:ea SYNC:0 NOP WE:0 R:ff M:ea ALU:fe CO:1 S:ff A:41 X:02 Y:03 P:--I--- 0 F:00000000 9 -I 01.18a MD:a AB:01ff DB:04 AH:ea DO:04 PC:0407 IR:ea SYNC:0 NOP WE:1 R:fe M:ea ALU:fd CO:1 S:fe A:41 X:02 Y:03 P:--I--- 0 F:00000000 10 -- 01.18b MD:a AB:01fe DB:07 AH:ea DO:07 PC:0407 IR:ea SYNC:0 NOP WE:1 R:fd M:ea ALU:fc CO:1 S:fd A:41 X:02 Y:03 P:--I--- 0 F:00000000 11 -- 10.18c MD:c AB:01fd DB:24 AH:ea DO:24 PC:0407 IR:ea SYNC:0 NOP WE:1 R:fe M:07 ALU:ff CO:0 S:fc A:41 X:02 Y:03 P:--I--- 0 F:00000000 12 -- 10.18d MD:e AB:fffe DB:1f AH:ea DO:07 PC:0407 IR:ea SYNC:0 NOP WE:0 R:02 M:07 ALU:07 CO:0 S:fc A:41 X:02 Y:03 P:--I--- 0 F:00000000 13 -- 10.18e MD:6 AB:ffff DB:05 AH:1f DO:1f PC:0407 IR:ea SYNC:0 NOP WE:0 R:00 M:1f ALU:1f CO:0 S:fc A:41 X:02 Y:03 P:--I--- 0 F:00000000 14 -- 10.040 MD:0 AB:051f DB:40 AH:05 DO:05 PC:0407 IR:ea SYNC:1 NOP WE:0 R:00 M:05 ALU:05 CO:0 S:fc A:41 X:02 Y:03 P:--I--- 0 F:01100000 Edit: SYNC:1 means it's starting a new instruction decode. During the IRQ handling it shows IR=ea (NOP), but that's not valid, because the IRQ handling is done in microcode. The instruction shown is the next one in the stream. There's not even a real IR. That register only exists in simulation for debugging. |
Author: | Arlet [ Thu Oct 22, 2020 8:45 am ] |
Slice count still about the same. It moves up and down a bit doing re-synthesis, probably because the tools are not deterministic. I took a quick look at the timing output. It's showing about 15 ns delay, but most of that appears to be routing/fanout. I'm not going to worry about timing right now. The synthesis is running with 'optimize for area' settings. I think that with manual instantiation/placement, both area and speed should improve at the same time. |
Author: | Dr Jefyll [ Thu Oct 22, 2020 12:27 pm ] |
Arlet wrote: Update: test suite revealed a couple of errors, mostly in the flag handling. Bugs have been fixed, and it now passes the test (BCD tests still disabled). Congrats on the progress, Arlet! Following this project with interest. -- Jeff |
Author: | ttlworks [ Thu Oct 22, 2020 1:34 pm ] |
Nice progress. Arlet wrote: One small quirk is that the SEI/CLI instructions have 1 cycle pipeline delay to setting/clearing the I flag. Reminds me to HuC6280: "a change in the interrupt flag with SEI/CLI will only prevent/allow interrupts AFTER the next instruction is executed" |
Author: | Arlet [ Thu Oct 22, 2020 2:09 pm ] |
Pfff... just spent hours trying to get the code to run on real hardware. Turned out I had copied all my verilog sources to the ISE directory, but not the microcode ROM hex file. And because I changed the format, the old code was no longer functional. It looks like it's finally working now. I can see the expected signals on the address bus. Now, let's see if I can write some code to blink an LED. |
Page 1 of 16 | All times are UTC |
